It is currently Mon Dec 18, 2017 8:26 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Mon Oct 07, 2013 9:43 am
Whenever I have what I consider to be a really hard question, I always head over here...
The question is can 52/36 Q rings be run on a Quarq?
A 36t inner won't physically fit on a 130bcd spider, that much I know. So that means using a 110bcd. However, from what I have read and been told, a 110bcd Quarq requires the OCP3 version of Rotor's Q Rings. The "regular" Q rings don't fit onto a 110bcd spider.
That presents a second dead end, as Rotor don't make anything bigger than a 50t in OCP3 (at least that I've seen).
So the only compromise I can see is to use an OCP3 Q Ring 36t and a regular Q Ring 52t. But can that be done - in short, is the OCP3 stipulation for the 110bcd spider specific to both rings, or just the small one?
All insights and answers gratefully received...
PostPosted: Mon Oct 07, 2013 11:07 am
The OCP3 rings are only big rings, as there's no problems fitting the normal small rings on any crank. But yes, the OCP3 rings are only in 50/110 and 53/130.
PostPosted: Mon Oct 07, 2013 11:13 am
which crankset/crankarm do you have?
PostPosted: Mon Oct 07, 2013 3:31 pm
Ahhh! So it's the big ring. Got it.
In answer to what I have, I haven't, yet. I'm trying to work out what Q ring combos I can put on 110 and 130bcd before deciding which way to jump between 110 and 130. I have 50/34 Q rings on a Quarq at the moment, having come from 53/39 three years ago. Ideally I had wanted to go to 52/36 Q rings on a Quarq, but that looks to be a non-starter.
The closest I can get with a 130bcd is 52/39.
The closest I can get with a 110bcd is 50/36.
PostPosted: Mon Oct 07, 2013 4:15 pm
I thought that the newer quarqs with Omnical eliminates these ring limitations. Those cautions are for the older model quarqs no longer in production.
My RCA
PostPosted: Mon Oct 07, 2013 4:34 pm
As I understand it Omnical allows you to swap the rings without having to send the entire unit back to South Dakota to be calibrated (or if you have a Wahoo thing that plugs into an iphone, recalibrating it yourself).
The OCP3 requirement for 110bcd is, and remains, a physical limitation, I think.
PostPosted: Mon Oct 07, 2013 5:00 pm
I think you would find the 50T quite alright, especially if you get a cassette with an 11T cog. You'll have a bigger gear than a 52/12 and spend more of your time in the middle of the cassette when in the big ring.
PostPosted: Mon Oct 07, 2013 5:14 pm
I thought that the electronics pod shape changed as well.
My RCA
PostPosted: Mon Oct 28, 2013 6:02 pm
can anyone confirm this? Just ordered a pair of 52-38 Aero Qrings for my 110bcd Red Quarq (2012 edition)..
This is my Bike. There are many like it, but this one is mine. Without me, my bike is useless. Without my bike, I am useless.
There are no new unread posts for this topic. Quarq Dfour with Rotor QXL rings
TroyG
Fri Jul 28, 2017 6:13 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Cutting q-rings to fit quarq dzero?
dairic
Sun Sep 10, 2017 7:20 pm
There are no new unread posts for this topic. Quarq DFour with Rotor Q-Rings modification
lemkeg
7
996
Fri Sep 08, 2017 12:35 pm
TroyG View the latest post
There are no new unread posts for this topic. FC-9000 crank with 56-44 rings or just the rings
lactatehate
Tue Apr 18, 2017 3:13 am
FIJIGabe View the latest post
There are no new unread posts for this topic. Quarq DZero PM question
addictR1
11
559
Tue Nov 14, 2017 3:54 am
Users browsing this forum: 4371, Conza, corky, Ettore, TobinHatesYou and 22 guests
