It is currently Thu Jan 18, 2018 3:08 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Tue Oct 01, 2013 8:09 am
Is there any chain keepers that would keep the chain set to my single chainring, that mounts to the braze-on on the bike?
Thanks
PostPosted: Tue Oct 01, 2013 9:00 am
Plenty of them
look at cyclingnews pro's machines, every second seems to have them...
PostPosted: Thu Oct 10, 2013 4:34 am
Thanks
Are you running it as a single speed or 1x 9 or 10? If you are running geared get one of the "clutch" style rear derailleur and you shouldn't need a keeper at all.
Sent from my iPhone using Tapatalk - now Free
Pain is inevitable, suffering is optional.
PostPosted: Thu Oct 10, 2013 8:10 am
Taocat wrote:
Thanks
1x10!
What sort of road derailleur would that be? Standard double one?
PostPosted: Thu Oct 10, 2013 9:28 am
None of them will work, clutch mechs are 10 speed mtb only. And they have a different pull ratio road to mtb.
So unless you are running a flat bar set up, with mtb shifters. It won't work.
(You can space the mech out to correct the pull ratio if you really want.)
PostPosted: Thu Oct 10, 2013 11:59 am
single-speed-front
viewtopic.php?t=77854
PostPosted: Thu Oct 10, 2013 6:26 pm
SRAM MTB rear derailleurs work fine with road shifters/bar ends. All of their 10 speed components are compatible.
PostPosted: Thu Oct 10, 2013 7:30 pm
AFAIK jockster is running shimano.
PostPosted: Thu Oct 17, 2013 9:55 am
I had a look at the options that mounted to the braze-on tab on the frame, but are too worried that if it jams, the braze-on will tear off, so I ordered a Paul components chain keeper that hopefully will fit around the seat tube.
PostPosted: Sat Dec 07, 2013 10:34 pm
if your seat tube is round then a n-gear jumpstop will do the trick
If your seat tube isn't round then Canyon do a chain catcher that attaches to the bottle cage bosses, if you have them, but it is a chain catcher, not a inner guide plate so will probably be too low for a single ring setup.
Other than that, and an outside bet, would a BB-mounted Hope chain guide. It would need to be fitted to your BB obviously which might mess up your chainline and necessitate a different type of BB but it might do the trick....
PostPosted: Tue Dec 10, 2013 6:10 am
Don't mess with the keeper. I tried for my SuperX and failed during races. Used k edge braze on chain catcher. Switched after dropping the chain and having it jammed. Wolf tooth chainring or something comparable is the way to go. No clutch der necessary, just make sure there's no slack in chain. Raced in extremely muddy condition and bumpy course with no issues. I believe there's another brand out of Germany?
PostPosted: Tue Dec 10, 2013 2:15 pm
+1 thick/thin is the way to go on single ring setups. Best design of 2013 without a doubt.
There are 110mm BCD thick/thin rings - Works do them, and there are others too (tries to remember the name...)
PostPosted: Tue Dec 10, 2013 2:25 pm
... here you go http://absoluteblack.cc/cx-rings.html
130bcd too.
There are no new unread posts for this topic. Supersix - what chain keeper and what cage/bottle ?
island
Mon Apr 03, 2017 12:10 am
froze View the latest post
There are no new unread posts for this topic. Need someone to braze bosses: recommendations?
whydobearsxplod
Sat Sep 30, 2017 12:21 am
skimaxpower View the latest post
There are no new unread posts for this topic. Supersix Evo braze on replacement
nickf
Tue Aug 01, 2017 9:13 pm
androidavies View the latest post
There are no new unread posts for this topic. ISO: Centaur 10 Speed QS braze on front derailleur
in Wanted
VTR1000SP2
Wed Nov 08, 2017 2:43 am
VTR1000SP2 View the latest post
There are no new unread posts for this topic. eTap Red frt derailleur - will any braze-on adapter do, or must it be SRAM?
Digger90
Fri Jan 12, 2018 9:53 pm
liam7020 View the latest post
Users browsing this forum: No registered users and 3 guests
