It is currently Wed Jan 17, 2018 4:08 pm
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Thu Jan 30, 2003 2:13 pm
I have a Stock Enduro Comp 2002...
has anyone out there given one the weight weenie treatment ?
and if so ... how did it go.
I've compared some of the weights in the listings with the stock items on the bike and it seems to be an awful lot of expense sometimes to save a few grams !!
but obviously the few grams extra on each component add up to make the stock bike 30 lb - ish
What would you gents suggest first off ?
Any advice would be most appreciated.
(apart from "lose a stone" of body weight !!)
 Post subject:
PostPosted: Sat Mar 08, 2003 7:11 am
Very cool site!!
Well I do like the Enduro, and the comp is a good worthy frame to trick out, same frame as the upper end stuff.
I would first start out with a new set of wheels, get the lightest disc hubs you can afford, Chris King hubs are some of the best and easiest to rebuild. American Classic hubs dont cost as much but are even lighter, check out there web sight, wheels as low as 1400 grams. My CK/Mavic 317 wheelset is about 1624 grams, if money is a problem then just get some new XT hubs and lace them to 317 rims with double butted spokes and aluminum nipples, they weigh only 224 grams more than the King wheels. 1846 grams
Wheels will not only lighten the bike but also improve the ride.
Stans notubes and some tire's like WTB Mutanoraptors, this might lighten the load about 2 pounds! Price will be anywhere from 200 to over $600.
Next I would replace those forks with a Fox Float, then perhaps get a Thompson post and a WTB Laser seat.
 Post subject:
 Post subject:
PostPosted: Wed Jun 25, 2003 6:57 am
I had a pimped out 2002 Enduro Large frame with
Monkey lo rise , thomson stem, seat post, selle flite saddle, mavic xl crossmax, xt casette, xt rear , deore front, marzochi mxc air,
27.8 lbs.
last thing i put on was mechanical disc brakes with Ti levers, never got the weigh the bike.
There are no new unread posts for this topic. 2002 S-Works E5 50cm Cipo Edition - 6.3kg
dudemanppl
25
2932
Sat Dec 16, 2017 7:59 pm
dudemanppl View the latest post
There are no new unread posts for this topic. Budget Build: Single Speed 2002 Trek 5500 Conversion Build
chefczyk
7
1571
Fri Sep 22, 2017 6:01 pm
evan326 View the latest post
There are no new unread posts for this topic. Focus Izalco Max eTap starting weight 6.62kg current weight 6.46kg
btothec
9
2387
Thu Jun 22, 2017 3:24 am
btothec View the latest post
There are no new unread posts for this topic. Help me lose weight
in MTB
d36
16
1856
Mon Mar 06, 2017 3:29 am
alexdi View the latest post
There are no new unread posts for this topic. FMB Competition CX Weight
ab01ns
Fri Feb 10, 2017 7:07 pm
ab01ns View the latest post
Users browsing this forum: No registered users and 4 guests
cron
