It is currently Sat Nov 25, 2017 9:06 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
 Post subject: Ridley X-Night 2013
PostPosted: Thu Sep 05, 2013 11:28 am
6.2 Kg wow :D
I couldn't believe my scale, will be posting some pics soon
 Post subject: Re: Ridley X-Night 2013
PostPosted: Fri Sep 06, 2013 9:06 pm
Cantilever, right?
Please so post some pictures.
--Max.
PostPosted: Sun Sep 08, 2013 9:47 pm
yes cantilever :thumbup:
6.6 kg with this wheelset and 6.2 kg with low profile carbon wheels. The only thing I do not like are the CB pedals and will probably go for the Look S-track or Time
PostPosted: Sun Sep 08, 2013 9:59 pm
:shock: The Bars?? How can you ever ride the drops like that?
Relevant question.. What is the chainring? Is that an absolute black wide/narrow? What is the tooth count and have you dropped a chain?
PostPosted: Mon Sep 09, 2013 6:02 am
JN2Wheels, what do you think is wrong with the bar setting ? :-(
Yes, it's an absolute black 42T. I haven't tested the bike yet on a cx field but I'm not able to take the chain out if I try to pull it, so it's pretty hard to believe that the chain can fall at some point, I've heard it can in deep mud. We will see
PostPosted: Mon Sep 09, 2013 4:03 pm
You can use a Sram X9 or X0 short cage type 2 RD for even more chain retention.
PostPosted: Mon Sep 09, 2013 11:08 pm
By running the levers so low on the bars, and then angling the bars so far up (in order to get a somewhat reasonable hood angle), you've got very little handlebar material below the hoods to use. It's probably fine for an occasional sprint, but if you like to ride technical sections in the drops you're asking to slip off.
As an aside, I think your hoods look on the low side for 'cross, but as long as you can get a straight wrist angle.
I'm not a fan of this relatively new trend of running levers super low on bars, I still think the lowest they should ever be is with the tip of the lever above a straight edge extended from the lowest section of the drop.
PostPosted: Mon Sep 09, 2013 11:19 pm
What don't you like about the pedals? Do you find them hard to clip in? CB are very sensitive to how high the lugs on the sole of your shoe are, relative to the cleat. Often it's just a matter of using the "shields" or the brass shims under the cleat to get them dialed in. You can also grind/trim the rubber lugs next to the cleat, but the shields also protect the sole of your shoe in a couple ways.
PostPosted: Thu Sep 12, 2013 6:18 am
What JBV said. That is not how bars are designed to be angled. The lowest part of the drops usually ends up parallel or slightly angled up relative to the ground. For CX, hoods are usually placed higher than level, resulting in the bar top being level into a slightly upward angled hood. That is the sweet zone for driving the bike. Flat hoods (especially old SRAM) will have you sliding off. Your setup has a crazy bar top hump right before the level hoods, leaving no drops to ride. To each his own, but I could never in a million years ride those.
Thanks for the chainring info. Ping this thread if you ever drop a chain! I'm gonna get a wide/narrow, and need some more reassurance before I leave off the jump stop and outer guard.
PostPosted: Sun Sep 15, 2013 10:35 pm
I was hoping it was the new frame but I need not have worried, it's gorgeous!
Interesting build, you'll certainly never have dry cables. You might want to trim the excess to the rear derailleur, a shorter run could save you a bit of friction.
Lastly, your levers are in a good position - so picture them staying where they are but the bars themselves pivoting down so the drops are angled up just a little bit.
Post some more pix when you're done.
PostPosted: Wed Dec 18, 2013 6:24 pm
I love it, the colour scheme on this frame is ace, I nearly purchased this model but missed out.
seeing this and at that weight I wish I'd got one.
That seat is it you have mounted btw ?
PostPosted: Mon Dec 30, 2013 5:13 pm
Hey VCNZ it's nice to see you switched bars and rotated them around a bit.
How does it ride now?
PostPosted: Wed Jan 01, 2014 3:23 am
Can you give us a full spec listing? That's a load of RD cable btw
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Wed Jan 01, 2014 6:35 pm
The bike looks ace and good job on the weight front too! :thumbup:
PostPosted: Wed Jan 01, 2014 11:52 pm
Best Ridley i have ever seen!! very well done :thumbup:
Cervelo t1
Cervelo s5 VWD Sram red- 7.2 kg
Cannondale CAAD 10 red- 6.5 kg
There are no new unread posts for this topic. Ridley X-Night 50, Dura Ace Di2, Shimano C24 tubular, Dugast
kolarzyk
Mon Oct 23, 2017 12:06 pm
kolarzyk View the latest post
There are no new unread posts for this topic. 2015 Ridley Helium SL new build & 2013 winter Helium SL
Monkeychunki
15
2869
Sun Feb 05, 2017 9:32 pm
Monkeychunki View the latest post
There are no new unread posts for this topic. Show us your Ridley!
in Catch all // Gallery threads
Tom06
7
1674
Tue Oct 17, 2017 8:53 pm
reedplayer View the latest post
There are no new unread posts for this topic. New build...Ridley Helium
dwn2sk8
9
2082
Fri May 26, 2017 12:20 am
beanbiken View the latest post
There are no new unread posts for this topic. Ridley Helium sizing help
dwn2sk8
7
908
Sun Jan 08, 2017 8:19 pm
Users browsing this forum: -Robin-, Alexa [Bot], Google Adsense [Bot], sib, Vuong05 and 11 guests
