Anyone try Shimano 9000 cables with 7900 groupset?
Ahillock
by Ahillock
Has anyone had a chance to try the new 9000 cables with their 7900 group? Any benefit and increase in performance? Thanks in advance.
tdudzik
by tdudzik
not with 7900, but I have with ultegra 6700. Works fine for me, just make sure to scrape off the slick coating on the cables where you clamp the brake down.
Weightcrazy
by Weightcrazy
I did. It smoothens the shifting on 7900 but don't expect it to turn into 9000.
Ahillock
by Ahillock
Thanks guys.
@Weightcrazy, I realize that 7900 won't be transformed into 9000. Was just curious to hear if it helped improve shifting performance. Sounds like it has helped a little.
ElDepo
by ElDepo
I installed 9000 shift and brake cables on my Ultegra 6700 (everything is internally routed) and it makes my bike shift and brake much, much better. I would say now my 6700 works better than Dua Ace 7800. I have never used 9000. Before using 9000 cables on my 6700, I would say the 6700 was always just a little off on the shifting and the brake power while good, was not nearly as strong as it is now.
Weightcrazy
by Weightcrazy
I have also put new 9000 cables on my other bike with 7800. The improvement is lesser than on 7900, perhaps its cable routing are more direct.
ms6073
by ms6073
I was using Gore RideOn Professional shift and brake cables but recently switched to DA 9000 shift cables with a drive train with FSA K-Force SRM, DA FD-9000, DA RD-7900, and Ultegra CS-6700 cassette. Although there was a very slight improvement in rear shifting, front was noticeably easier but the spacing on the SRM rings requires very close derailleur setup. The most noticeable difference was in braking with the 9000 cables, DA 7900 brakes, and Zipp 303 Firecrest clinchers - most notably brake lever feel - which is now very light and smooth. Note that the 'feel' may also be due to issues with Gore Ride On brake cables as it has been my experience that the Teflon coating will flake off over time clogging the liners thus degrading performance.
kode54
by kode54
tdudzik wrote:not with 7900, but I have with ultegra 6700. Works fine for me, just make sure to scrape off the slick coating on the cables where you clamp the brake down.
are the brake cables PTFE coated as well?
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
