It is currently Sun Jan 21, 2018 10:12 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Thu Aug 15, 2013 4:59 pm
I did search, but couldn't find a clearly definitive answer.
Which long cage rear derailleurs, for use with an 11-32 10-spd cassette, are compatible with DA 7800 and/or Ultegra 6600 series front road shifters for a road setup?
I think Shimano changed the cable-pull amount on their newer mtn derailleurs, right ?
I think the RD-M591 will work ?
any of the newer XT or XTR models ?
Thanks.
PostPosted: Fri Aug 16, 2013 11:03 am
I'm running an Ultegra 6700 GS rear mech ("long cage") with an 11-34 cassette here. Shimano RDs typically handle a bit more than said in the spec, to account for subtle differences in frame/hanger measurements.
You can also use any Shimano 9 speed MTB RD with a 10 speed road shifter and 10 speed cassette, the cable pull is the same. Running Ultegra flatbar 10-speed shifters with 9sp SLX RD and XT cassette on one of my bikes, works a treat.
PostPosted: Fri Aug 16, 2013 5:49 pm
Thanks. Please forgive my ignorance about mountain components.
If any 9-speed derailleur will work, then does that include the newer "Shadow" style, like the XT M772 ?
Is the "shadow" design a real improvement ?
PostPosted: Mon Aug 19, 2013 8:28 am
Turns out I'm even running a "shadow" RD -- RD-M662 SGS to be precise. Works flawlessly, the cable pull got to be the same as for the regular models, otherwise you'd need "shadow" shifters as well.
PostPosted: Mon Aug 19, 2013 3:49 pm
Shadow is only the design of the mech, tucking in away from damage, it doesn't effect the shifters at all.
PostPosted: Mon Aug 19, 2013 9:29 pm
OK....so I am actually going to try an XTR RD-M971 SGS
That's a long cage, conventional 9 speed.
I got a good deal on a new take-off on ebay.
They don't come with barrel adjusters any more, but IRD makes a barrel adjuster specifically for shimano's now-omitted part. So I will report back when I have tried it all together.
PostPosted: Tue Aug 27, 2013 4:58 am
shimano road shifters will work on any non-dynasys rear derailleur.
PostPosted: Fri Aug 30, 2013 7:29 pm
I have a 10sp 105 shifter and that worked well with an XTR M972 Shadow rear mech,
Blog http://andrewhowett.blogspot.com"
PostPosted: Mon Sep 02, 2013 1:02 pm
10 speed Road shifters will work properly with 9-speed designated MTB Rear Derailleurs.
I have run 7800 shifters even with a 9 speed 'shadow' XT RD before ( that's quite a few years ago, so I can't recall the RD number though...). It shifts perfectly.
There are no new unread posts for this topic. Clutched rear derailleur 2x
jfranci3
15
1181
Fri Aug 11, 2017 2:56 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. XT di2 rear derailleur Cassette Options
velobob
14
1509
Tue Aug 08, 2017 8:33 am
There are no new unread posts for this topic. eTap Rear Derailleur seems dead
Shrike
41
6199
Tue Jul 18, 2017 12:56 am
colnagoc59 View the latest post
There are no new unread posts for this topic. Campagnolo Chorus HO Rear Derailleur
stormur
Mon Aug 07, 2017 11:30 pm
ultimobici View the latest post
There are no new unread posts for this topic. SRAM etap rear derailleur
aerozy
10
858
Fri Nov 17, 2017 3:06 am
charlieboy52000 View the latest post
Users browsing this forum: burglarboycie and 8 guests
cron
