It is currently Fri Nov 24, 2017 9:57 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Aug 09, 2013 10:29 pm
I have a Ritchey Superlogic Carbon 1-bolt Seatpost. I'm considering purchasing a MCFK Carbon Saddle. The MCFK's rails are 7x9mm, ovalized. However, on Ritchey's site they list two adaptor sizes, 8x8.5 and 7x9.6. Does anyone know whether I could shim the rails somehow and use the 7x9.6, or any viable solution?
Best.
PostPosted: Fri Aug 09, 2013 10:58 pm
The way the clamp works, I would expect the 7x9.6 to work fine.
PostPosted: Fri Aug 09, 2013 11:19 pm
+1
...If not some braided tape can add a little to the diameter
PostPosted: Fri Aug 09, 2013 11:38 pm
...7 mm is the width and 9.6 is the height...the width is the most important factor to be concerned about. You will be fine with a 7x9mm saddle rail.
EM3
______________
PostPosted: Sat Aug 10, 2013 1:17 am
thank you all for the help!!
best.
PostPosted: Sat Aug 10, 2013 10:06 pm
I have used the superlogic seatpost with romin pro saddle (also 7x9 carbon rails) with zero problems, of course with the adapter. I wrote: "used" because I need a zero setback post which I now use
PostPosted: Mon Aug 12, 2013 10:22 am
hmm,I have the same question which you have ,and my setpost and the adaptor which i got from wiggle is on my way,and I hope the adaptor will work!
There are no new unread posts for this topic. Attachment(s) alu bolts in saddle rail clamp
wwnick
Sat Jul 29, 2017 9:23 pm
donald View the latest post
There are no new unread posts for this topic. Saddle rail size/dimension
survivor
Fri Oct 20, 2017 3:35 pm
MXGimp View the latest post
There are no new unread posts for this topic. Attachment(s) Seat rail adapter for a carbon seat rail??
theyoungconnoisseur
Tue Jan 31, 2017 2:44 pm
theyoungconnoisseur View the latest post
There are no new unread posts for this topic. Salddles-carbon rail size
hatsunagi
Tue Jun 06, 2017 3:35 am
hatsunagi View the latest post
There are no new unread posts for this topic. Attachment(s) fizik braided carbon rail on selle italia monolink seatpost
seansis
Thu Oct 19, 2017 1:24 pm
seansis View the latest post
Users browsing this forum: albertop07, Bing [Bot], CP, ihaveabikeproblem, jgadd, shamrock134 and 34 guests
