It is currently Tue Nov 21, 2017 8:37 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed Aug 07, 2013 1:42 pm
I've been having some trouble with my DA9000 FD where it doesn't shift under heavy load (e.g. out-of-the-saddle climbing on the big ring and shifting to small ring). It seems like there isn't enough spring tension to shift it over when there is higher chain tension - I have to let up a bit to get it to shift.
Is this a faulty derailleur or is there some way to address this?
PostPosted: Wed Aug 07, 2013 1:48 pm
Could be cable friction. Also check the BB guide.
 Post subject:
PostPosted: Wed Aug 07, 2013 3:19 pm
What chain, what crankset/chainrings?
Sent from my EVO using Tapatalk 4
PostPosted: Wed Aug 07, 2013 3:49 pm
Oddly enough I had to use more front cable tension then I did with 7900. Works like a charm now.
Gramz
Failed Custom Bike
PostPosted: Wed Aug 07, 2013 4:15 pm
All standard DA9000 with 52/36 chainrings. Cables are brand new... (will check the BB guide)
Can't see how more cable tension would help. Wouldn't it be the opposite?
PostPosted: Wed Aug 07, 2013 9:08 pm
what frame? I didnt put a barrell adjuster in and was a bitch to setup that said its sorted now. did you use the cable guide tool to ensure the cable was routed into the mech the correct way as there are two ways to route cable?
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Wed Aug 07, 2013 9:18 pm
^That, also check the fd is correctly aligned in terms of height and rotation.
PostPosted: Wed Aug 07, 2013 9:46 pm
No, the shift should be snappy and fast. I wasn't getting the top trim position until I used a 2nd hand tool to take some cable tool slack. When its in the lowest trim position very lightly click it once. if it doesnt move into the 2nd position noticeably and produce chain rub in little/little then there is not enough tension. This is what was happening to me, but when diagnosing it I kept swiping to the big ring all the way and couldn't figure it out.
The rotation setup was more crucial for chain rub and trimming.
Gramz
Failed Custom Bike
PostPosted: Thu Aug 08, 2013 12:11 am
Even though it looks to be installed correctly,it may be a bit too close and not have enough leverage to shift the chain. It may need to be moved up a tad.
Will test it out. Thanks for the suggestion.
PostPosted: Thu Aug 08, 2013 5:01 am
You need to put more tension, the 11 speed front derailleurs need a lot tension.
PostPosted: Thu Aug 08, 2013 6:08 am
Another vote for tension.
I have been running the FD9000 since April, and set it up myself, rather than having the shop do it. The whole 9000 groupset is very sensitive to small errors in alignment and tension.
I fitted a barrel adjuster which was basically essential to get the tension dialed high enough for decent functionality.
PostPosted: Fri Aug 09, 2013 4:18 am
Is the mode converter in the correct position?
Check out the FD9000 Dealer Manual to make sure.
Turn down the suck knob.
There are no new unread posts for this topic. Weak front derailleur clamp
Daniel1975
15
1345
Mon Dec 19, 2016 2:03 am
Calnago View the latest post
There are no new unread posts for this topic. Campagnolo Front Derailleur Question
matty
16
1141
Sun Mar 19, 2017 11:10 am
matty View the latest post
There are no new unread posts for this topic. S2-system on Campagnolo front derailleur
Daniel1975
Thu Jan 05, 2017 10:16 pm
There are no new unread posts for this topic. Sram Etap Front Derailleur Height
goldmine848
Thu Jun 22, 2017 10:25 am
goldmine848 View the latest post
There are no new unread posts for this topic. SRAM eTap Front Derailleur Adjustment
goldmine848
Wed Sep 06, 2017 12:54 am
commendatore View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], scottmmw, Shortsocks and 48 guests
