It is currently Mon Jan 22, 2018 1:24 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Aug 07, 2013 7:17 am
Many here talk about road disc, but tandems actually use road disc, and have been for years.
Tandems generally use mechanical disc, and this has long been the Avid BB7. TRP, however, just released the dual-piston Spyre, and the weight weenie 146 gram Spyre SLC. Lots of info about the Spyre here.
Spyre SLC on our Calfee tandem:
Spyres get more braking engagement with less braking pull than the Avid BB7, which is important, as Campagnolo levers don't have the pull of Shimano, and a tandem has a looong cable.
The engagement I get now with the Campy levers is allright, but I wouldn't mind it to be tighter. I want to eliminate all compression and direct every millimeter of lever travel into brake power (I imagine this will be true as well for single road bikes with mechanical discs, so this topic is not just specific to tandems!).
The question is, what brake cable housing has the least compression? My LBS recommended Odyssey BMX cable, but my impression is that the ferrule weight weenie cable housing (e.g Nokon, i-Link, etc) also have very little compression (less than Jagwire?). If so, which of the ww housings have the least compression?
PostPosted: Wed Aug 07, 2013 11:50 am
I have long used jagwire ripcord on my mtbs (and now road/cx commuter). I don't know that it is the best, but it is certainly very good (and not crazy expensive).
PostPosted: Wed Aug 07, 2013 1:29 pm
Nokon works for me with Avid BB7. Unfortunately I don't have any other point of reference, though. One minor downside is that Nokons sometimes creak slightly, when turning the handlebars.
PostPosted: Wed Aug 07, 2013 2:20 pm
I have previously used Gore Ride On pro and sealed low friction on my cross bike which is currently equipped - that is until I can obtain a set of TRP Spyre SLC - with Shimano CX75 mechanical disc brakes which I found worked well initially but after 15-20 hours of cross racing, the teflon linerthat coats the cable started to flake off resulting in sticky/degraded action at the lever. Next I tried Yokozuna Reaction brake cables which are very good with slightly thicker brake cables than others and think those would do nicely but not sure if the housing or rear cable length would work for a tandem. Currently I use Jagwire Hyper Brake Kit with Braided housing on the cross bike and brake response/action with those cables is the best I have experienced but I think you might find the Yokozuna more suitable for braking on the tandem.
PostPosted: Wed Aug 07, 2013 4:05 pm
We've recently built a brake test jig and have tested a bunch of caliper brakes, once we write and publish the results we'll be using the same jig to do some testing on brake levers, cables and perhaps of more interest to you cable housing compression. My gut feeling is that Nokon will top the chart in compression.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Wed Aug 07, 2013 7:46 pm
Have you thought about trying shifter housing? If you cannot find larger shifter housing, I know bontrager/Trek makes smaller brake cable that will fit inside standard shifter housing. If there isn't enough compression you might be able to mix the two to fine tune the feel you are looking for.
There are no new unread posts for this topic. Fluo brake cable housing?
jever98
Wed Mar 15, 2017 7:11 pm
Kurets View the latest post
There are no new unread posts for this topic. Attachment(s) Disc brake pad compounds - best for road use?
Devon
29
1531
Fri Dec 08, 2017 6:49 am
TonyM View the latest post
There are no new unread posts for this topic. Jagwire XEX-SL and KEB-SL derailleur and Brake housing
tommasini
Mon Jan 01, 2018 4:44 am
Mep View the latest post
There are no new unread posts for this topic. Compressionless brake housing for internal routing
bikewithnoname
Sun Apr 16, 2017 7:43 am
bikewithnoname View the latest post
There are no new unread posts for this topic. Attachment(s) Routing rear brake cable
Lightweenie
19
931
Wed Nov 29, 2017 10:27 am
Fiery View the latest post
Users browsing this forum: CarlosFerreiro, elzilcho, Google Adsense [Bot], Titusrider and 44 guests
