It is currently Fri Nov 24, 2017 4:08 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Tue Aug 06, 2013 5:59 am
Out of curiosity and a bit off topic, as I am thinking buying new groups, how would you compare DA9000 / UG6800 vs Chorus or Record 11 in terms of shifting performance and overall feel?? DA seems to have better tech and niceties like coated cable and all that jazz.
PostPosted: Tue Aug 06, 2013 6:23 am
Without this turning the other thread in to a 'Campag vs Shimano' debate (which is why I split the topic), the difference will still come down to your personal preference. Ie: do you like thumb shifters, hood shape, brake modulation/power, are your other bikes Campag or Shimano, etc
9000 is the smoothest road grouppo I've ridden - and I have Campag on all my personal bikes. That said, my team is breaking a lot of RD cables due to the new lining. So 9000 is not, presently, without some drawbacks.
VeloKicks
The Gram
The Men of Steel
PostPosted: Tue Aug 06, 2013 8:04 am
Shimano rear shifting is much smoother than the Campy, less noisy too, Campy is a bit faster, the problem is in the front, Shimano requires 2 trim, the lower trim really bothers me, no trim is needed for Campy.
PostPosted: Tue Aug 06, 2013 8:15 am
No trim needed for 9000...
VeloKicks
The Gram
The Men of Steel
 Post subject:
PostPosted: Tue Aug 06, 2013 8:49 am
PostPosted: Tue Aug 06, 2013 10:15 am
I was talking about Ultegra 11 speed.
PostPosted: Tue Aug 06, 2013 10:19 am
I never noticed any need for that on the 6800 bikes I rode either.
VeloKicks
The Gram
The Men of Steel
PostPosted: Tue Aug 06, 2013 10:43 am
The FD low adjustment (chain is 0.5mm away from the inner cage of the FD), This is also the low trim position.
you will land on another index ( low position) when you shift from the bigger chainring to the smaller chainring, at this position, the rear 3 big cogs will rub the chain, you need to click again go to the low trim position to avoid the rub.
there are total of 4 indexes low trim-low -top trim-top.
the reason you never noticed the rub is probably the skid plate, the skid plate will make the rub silent, but the rub is there.
PostPosted: Tue Aug 06, 2013 10:47 am
Anyone who has setup the Shimano 11 speed FD would know what I am talking about, need to put lot of tension on the derailleur cable.
PostPosted: Tue Aug 06, 2013 11:53 am
Interesting discussion and thanks for splitting the thread TP. I am brand agnostic mostly when it comes to road bike equipments. I run Shimano 105 10 Speed on a Ridley Fenix bike and pretty much like the aesthetic of both DA9000 and Chorus. Slightly prefer Thumb shifters. I asked about DA9000 performance specifically because many people said it shifts a lot better than Red (though haven't read much vs Campy 11). Having said that I have no problem with my 105 which shifts almost always perfectly.
Guess I will go with Campy after all.
PostPosted: Tue Aug 06, 2013 12:14 pm
Online
With shifters Chorus is identical to Record, and almost so in every other part too. Chorus is by far the best value in Campy 11 spd.
There's sometimes a buggy.
One.
PostPosted: Thu Aug 08, 2013 9:22 am
To be really annoying and cnut the thread up a bit...
It seems to me that a 9000 chainset would work ok with 11 speed Campag set up right?
PostPosted: Thu Aug 08, 2013 9:30 am
Totally fine (have done it).
VeloKicks
The Gram
The Men of Steel
PostPosted: Thu Aug 08, 2013 9:45 am
And risked scorn from the world of bike fashion? Brave man.
PostPosted: Thu Aug 08, 2013 10:31 am
VeloKicks
The Gram
The Men of Steel
There are no new unread posts for this topic. Attachment(s) Campagnolo Record 11sp Drivetrain with Shimano casette
mlok
13
1156
Tue Jun 27, 2017 4:32 pm
AJS914 View the latest post
There are no new unread posts for this topic. 2 new 11s 11-36 cassettes: VXM (for 10-11sp hub) and SunRace (for ?? hub)
ooo
Sun Nov 12, 2017 4:50 pm
ooo View the latest post
There are no new unread posts for this topic. 11sp 11-30, 11-32, 12-32 cassette speed jumps comparison
ooo
23
2338
Sat Dec 31, 2016 10:57 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Miche Primato Light 11sp 12-29T for SRAM?
stockae92
Tue Jan 10, 2017 8:56 am
Marin View the latest post
There are no new unread posts for this topic. Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
12
1244
Mon Jan 30, 2017 8:45 am
Users browsing this forum: No registered users and 44 guests
