It is currently Fri Dec 15, 2017 3:24 pm
PostPosted: Sat Aug 03, 2013 11:45 am
For £65 I thought a Serotta built steel frameset with a stuck seatpost was worth trying to save. It's Spirit steel with an alu post. I turned upside down, plugged holes and filled the seat tube with penetrating oil and soaked for a day and a half. It's still stuck solid though did get about 5mm rotation before snapping the top of the post off. The next step would be to corrode it out using caustic soda - I've picked up goggles and overalls.
Any scientists out there - Is the heat from the caustic soda reaction likely to cause the penetrating oil residue inside the frame to combust??
Thanks
PostPosted: Sun Aug 04, 2013 12:39 am
There is another sort of 'caustic soda' to try first and thats Coke. Let that eat away at it for a few days. Worked for me.
PostPosted: Sun Aug 04, 2013 12:41 am
I havent tried it my self, but i have heard that cola could do the job with a seatpost stuck in the frame. Turn the frame upside down, and fill the cola inside the frame and give it around 24 hours, and try again.
Hope it helps and good luck, and :thumbup: for trying to save a nice frame :-)
I ride for fun
PostPosted: Sun Aug 04, 2013 1:10 am
A lot of "mechanical" solutions before going Caustic, but really time and patience are your friends, re-applications of a thin penetrating oil (mineral oil for bad cases) over time (more than a couple days, maybe a week or even more) This works, something I do for all kinds of "stuck" situations.
PostPosted: Sun Aug 04, 2013 1:43 am
http://tidewaterrandonneur.blogspot.pt/ ... tpost.html
or in last case:
http://www.fixedgearportugal.com/a-minh ... #msg164144
PostPosted: Sun Aug 04, 2013 7:56 am
Thanks for the suggestions - I think I've got plans A, B and C now!
The frame's continued to soak in penetrating oil for another night so later today I'll give it hell with a pipe wrench. (before toping back up with oil I expect).
Turned into a bigger job that I anticipated but not looking to back down now. Cranks seized to bottom bracket, bottom bracket seized in frame. Penetrating oil + old mtb handlebars attached to huge spanner for leverage + a few hours did the job on those.
The frame is a Glider Tupelo, built by Serotta for the bike shop Cycle Fit in London a few years back. I'll get some pics of mine at some point but here's a nice one from the internet.
PostPosted: Sun Aug 04, 2013 8:11 am
I'm sure it will be worth it , patience allowing!
would chucking it in a walk in freezer do anything? I'm thinking expansion and contraction here....
There are no new unread posts for this topic. Tune Schwarzes Stuck, any experience?
Penthousepete
Wed Oct 11, 2017 2:32 pm
Penthousepete View the latest post
There are no new unread posts for this topic. Looking for 30.9 seatpost
dbnm
Sun Sep 24, 2017 2:52 am
silvalis View the latest post
There are no new unread posts for this topic. 20mm Seatpost vs 5mm
p3dalfaster
Thu Jun 08, 2017 10:01 am
2lo8 View the latest post
There are no new unread posts for this topic. Ti seatpost in a Ti frame?
taztaylortaz
Sun Nov 26, 2017 8:16 am
TonyM View the latest post
There are no new unread posts for this topic. seatpost clamps?
simoncx
Wed Jan 25, 2017 5:06 pm
simoncx View the latest post
Users browsing this forum: alistaird, Butcher, Swano, tomycs, topflightpro and 37 guests
