Parlee Z-Zero :: ISP, Di2, and *Really* Red - now 6.31 kg
kfreytag
by kfreytag
Old Wheels:
New Wheels, New Weight!
Code: Select all
Frameset
Frame (Custom Geo ISP w/SL Tubing)                  1,063 g
Fork #1 (Uncut)                                       310 g
Tune ISP Topper                                        75 g
Cockpit
ENVE Stem #2 (110mm)                                  122 g
ENVE 42cm Compact Bars (painted black)                220 g
Cane Creek 110 / 40 Combo Headset                      68 g
Extralite Ultrastar II Expander                         7 g
Mcfk Topcap and Bolt                                    5 g
Barfly 2.0                                             20 g
Fizik 3mm Microtex Bartape (uncut)                    102 g (I know, I know)
Drive
ROTOR 3D+ SRM w/ 34/50 Praxis Rings                   688 g
SRM Magnet                                              4 g
ROTOR Pressfit 4630 BB (Ceramic Grade 5)              102 g
ROTOR Spacers                                          14 g
Dura Ace 9070 STI (Left)                              115 g
Dura Ace 9070 STI (Right)                             115 g
Dura Ace 9070 Front Derailleur                        107 g
Dura Ace 9070 Rear Derailleur                         215 g
Dura Ace 9000 Front Brake                             151 g
Dura Ace 9000 Rear Brake                              145 g
Parlee Front Derailleur Clamp w/ nut                   11 g
Cables & Junctions
Shimano Brake Cable Outer #1 (uncut)                   97 g
Shimano Brake Cable Inner #1 (uncut)                   43 g
Shimano Brake Cable Outer #2 (uncut)                   43 g
Shimano Brake Cable Inner #2 (uncut)                   21 g
1000 cm e-tube Cable                                   10 g
2 x 650 cm e-tube Cable                                14 g
2 x 400 cm e-tube Cables                                8 g
5 Port External Junction Box                           12 g
Internal Junction Box                                   5 g
Seatpost Battery                                       61 g
Wheelset #1 (In Transition)
ENVE 3.4 Front w/ CK R45 & Vittoria Evo SC            838 g
ENVE 3.4 Rear w/ CK R45 & Vittoria Evo SC           1,019 g
Dura Ace 9000 12-28 Cassette w/ Lockring              204 g
Carbon-Ti X-Lock Special Road Ti Skewers (pair)        38 g
Wheelset #2                                         1,951 g
ENVE Classic 25 Tubular front w/ DT Swiss 190         589 g
ENVE Classic 25 Tubular rear w/ DT Swiss 190          766 g
Vittoria Evo CX 23mm Tubular #1                       177 g
Vittoria Evo CX 23mm Tubular #2                       177 g
Miscellaneous
Fizik Arione 00                                       146 g
Arundel Mandible #1                                    27 g
Arundel Mandible #2                                    27 g
LOOK KeO Blade Ti 16Nm Pedals                         186 g
TOTAL                                               6,310 g
Life's too short to ride clinchers.
Current:
Parlee Z-Zero ISP
Santa Cruz Stigmata CC
Past:
Ridley X-Fire Disc
carlislegeorge
by carlislegeorge
Awesome! What is the intended/promised weight of the frame?
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
kfreytag
by kfreytag
No promised weight. The (non-disc) show bike that was making the rounds was claimed @ 750 grams. It was, however, a matte black frame. Both the Kandy Red (lots of layers of silver/red, silver/red) and the ISP will add weight, though I'll save weight by not using a seatpost. I'm hoping the frame is ~900 grams.
The fork is proprietary to Parlee, so I have no idea there. They've been working with ENVE for quite a while (and Reynolds before that), so I imagine that the Z-Zero fork is based off the ENVE 1.0. Hopefully it'll be sub-300 grams.
Once I decided on the paint, I didn't plan out the frame to be uber-light, but I'll be very curious to see where it comes in. Trust that I'll be weighing *everything* I can (the PF30 bearings are pressed-in at Parlee).
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
Ozrider
by Ozrider
Looking forward to more pics and a build report. I'm sure it will be worth the wait.
Some custom builders have far longer wait times. I love the colour you have chosen, it looks stunning.
Ozrider - Western Australia
kfreytag
by kfreytag
The frame came in yesterday, and I admit that I was surprised at the weight. Whereas there were no promises made, the matte black frame that was making the press rounds was supposedly 750g. I've added an ISP and paint (and, I'll admit, heavy paint).
I didn't expect, however, that the frame would come in over 1kg:
The fork isn't *too* bad. It includes the weight of the crown race, and it hasn't yet been cut:
I had them paint an ENVE stem (110mm) to match the frame, and it came back at only 1g heavier than when it left:
I also asked for them to paint the logo on my ENVE compact bar gloss black (instead of white) but, for some inexplicable reason, they painted the whole bar gloss black. Not sure whether I'm going to use it, use an "unmolested" ENVE compact bar, or search the planet for one of the Cannondale Evo black ENVE bars (anybody want to sell one?):
Despite the weight, she sure is a looker (and this horrible pic under fluorescent lights does it no favors):
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
kfreytag
by kfreytag
I'll start posting parts for the build in bits and pieces:
Wheels
The "everyday" wheels I'm planning to use are ENVE 3.4 SES tubulars built on Chris King Shimano 11-speed hubs. Not the lightest tubular wheelset by any stretch, and I have lighter wheels in a pair of Mavic CCUs; I've been wanting to try the SES wheels, however, since they came out, and this seems like a good opportunity.
The build and finish quality on the wheels (and the hubs!) is fantastic.
Front Wheel : 550g
Rear Wheel : 722g
Wheelset : 1272g
ENVE claims 1253g, so these are coming in 19g overweight (at least on my old crappy scale):
Front:
Rear:
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
fa63
by fa63
That looks great, though I would be miffed at that weight as well. Did you by any chance ask Parlee why such a discrepancy?
LionelB
by LionelB
What are the differences between the Z0 and the Z1 ?
PSM
by PSM
fa63 wrote:That looks great, though I would be miffed at that weight as well. Did you by any chance ask Parlee why such a discrepancy?
+1.
kfreytag
by kfreytag
@fa63 - I've asked my LBS to ask them about the (rather large) difference
@LionelB - The primary difference is that the Z1 is a pseudo-lugged bike (wrapped tube-to-tube construction) whereas the Z-Zero's tubes are bonded together in a manner that Parlee calls "fused". Frankly, they are trying to make a handmade bike that closely resembles a monocoque frame and reduce the total amount of carbon used at the joints. From the Parlee site:
PARLEE tube joining process: Pioneered on the Z1, our exclusive molding process is the technical benchmark for fusing carbon fiber tubes into a monolithic structure. Our process is neither “lugged” or traditional “tube to tube” construction. The Z-Zero joining process is more precise, more costly, and unmatched in strength, using only carbon fiber to fuse each tube to another in a manner that yields a wholly unified structure with almost zero redundant material.
Could all be bullshit, but we'll see how it rides.
In addition, the tubes are shaped. The downtube, for example, starts round at the headtube and becomes elliptical by the time it hits the seattube.
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
LionelB
by LionelB
kfreytag wrote:@fa63 - I've asked my LBS to ask them about the (rather large) difference
I'd pick the phone and call them up instead!
majklnajt
by majklnajt
kfreytag
by kfreytag
@fas62 & @PSM - I'll give 'em a few grams for the ISP (~50?). The question remains as to whether the remaining ~240g is justifiably paint or whether my bike is measurably larger (doubt it -- I'm a 55). I know I chose a *really* damn heavy paint. They have to do three layers of paint to get the Kandy Red paint effect, then they do an absurd number of clear coats to make it sparkle.
Hard to fathom, however, that the bike has over 1/2 lb. of paint on it.
@LionelB - I have a really good relationship with my LBS, and they've already called. We'll see what Tom has to say.
Despite being truly chuffed at how it looks, I *am* disappointed at the weight, as I feel like I'm starting my weenie build with one hand tied behind my back. Especially on Parlee's "halo" bike.
Hell, it isn't much lighter than my 'nago EPS:
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
btompkins0112
by btompkins0112
I can believe that that three layers of paint and numerous layers of gloss weigh that.....not surprised.
That being said, the frame is the best looking frame I have ever seen......yep, I said that. I would gladly accept the weight penalty for a frame that looked like that! Spectacular! Really stoked to see this built up.
Sent from my iPhone using Tapatalk 2
kfreytag
by kfreytag
btompkins0112 wrote:That being said, the frame is the best looking frame I have ever seen......yep, I said that. I would gladly accept the weight penalty for a frame that looked like that!
Quite a statement, and I appreciate it. I am really happy with how the frame turned out. It was a lot of back-and-forth to get to the geometry, color, and design (as simple as it may be). Nothing will change the weight now that it's built and painted, and it's frankly beautiful in person.
Hopefully I won't screw it up when I build it. :wink:
Current:
Parlee Z-Zero ISP
Past:
Ridley X-Fire Disc
