Scott CR1 SL
ross
by ross
Hey weenies!
This project was completely unplanned so took a bit longer to complete, the frame came from a silly cheap deal from Westbrook Cycles. As much as I support my LBS, Westbrook were practically giving these away and too good to refuse. I was too late seeing the deal to bag a 52cm so this is a 49cm with 120mm stem, very pleased with the results though. The frame was delivered with the BB fitted and was 974g inc rear hanger so around 885/890g bare. The fork was 342g uncut and 306g cut
The cabling took way longer than expected, and two goes to get right. Have gone for gearcables crossed under downtube and front brake continental to get a clean cable run with minimum length, and no cable rub which was a bonus. Didn't take long to get used to the brake swap but will need to switch my CAAD over to be the same
Weight not too bad
What does it look like with tan sidewalls I hear you ask?
My kitchen digital scales aren't the most accurate but within a couple of g, estimates are noted
Will get some pics against a neutral background sometime soon
Cheers :D
gravity
by gravity
tell us more about your seatpost.
(come to think of it, what is there to talk about seatpost other than purely aesthetic? :lol: )
damitamit
by damitamit
That is a lovely build!
(Loving my westbrook cr1 too)
paradawt
by paradawt
Very nice new frame CR1.
Congrats.
Cannondale Supersix '10
ross
by ross
Cheers guys, I've been admiring all the other CR1 SL builds too 8)
gravity wrote:tell us more about your seatpost.
Yeah pretty nice post, asides from the logos and white graphics. I may yet sand those off and reapply clearcoat
Weight is good for such a long post.
Interior seems to be CF and not an alloy wrap which some have suggested. Will probably cut the post down at some point as I only need 250mm or thereabouts and it's 400mm at the moment
The only downside is that oval rails are not compatible so my Selle SLR Kit Carbinio won't fit
drainyoo
by drainyoo
Beautiful bike, great build.
Barters
by Barters
I have the 2012 CR SL as sold by Scott (DA 7900 group, Kysrium SL wheel set).
I really like the bike but am considering moving on to a S Works Tarmac or Canyon Ultimate CF SLX. Reckon I am going to notice an "upgrade" or I am already on such a great bike that I will be left unable to notice a lot of difference?
tinytree
by tinytree
i was looking at the seatpost, too! i just ordered an omni this morning.
beautiful bike!
ross
by ross
Thanks tinytree :)
Barters wrote:Reckon I am going to notice an "upgrade" or I am already on such a great bike that I will be left unable to notice a lot of difference?
I haven't ridden a Tarmac but I have ridden a Canyon Ultimate CF SLX (2013 model) and I would say more of a step sideways than upgrade. Granted the Canyon is a bit lighter in current 2015 form (790g) so it's worth considering for weight reasons but the ride and handling is very similar to the CR1 SL (i.e great!)
As for my CR1 SL, I haven't changed a thing (apart from replacing brake pads and tyres when they wear out). Oh I did swap pedals to Keo Blade 2 Ti which saved a handful of grams :mrgreen:
Still love it, but have just bought a Scott Foil HMX with Di2. Currently 7.05Kg with Ksyrium Elites
Hated the gloss Fizik tape, swapped to matte
The Foil is a bit stiffer and seems harsh compared to the CR1 SL, still experimenting with tyre pressures but swapping to latex tubes helped. Love the Di2 though!
Cheers
ross
by ross
Oh while I'm here, has anyone experienced rear brake caliper (Ultegra) slipping on a Foil? I've tightened it as far as I dare and I have the serrated washer in place but it keeps rotating under heavy braking and then not returning, so one pad then rubs until I re-centre it
Many thanks
Barters
by Barters
Cheers Ross!
The Ultimate CF SLX is one of the top rated bikes today so if you are saying that the CR1 SL is similar....
Reckon buying a new bike might not deliver a step change for me.
Krull
by Krull
good-looking bike, perfect settings, why changing anything? :?
sorry vor mai bed englisch!
ross
by ross
Thanks Krull :)
LouisN
by LouisN
Very nice :beerchug: !!
Louis :)
