It is currently Tue Oct 17, 2017 1:15 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Tue Jul 09, 2013 7:45 pm
Going on four years on the forum and there is a lot of advice that come from members, so here is goes...
I'm having a hard time thinking about parting with this frame just for the sake of something lighter (though this is weightweenies and I am one). It fits perfectly, is super stiff & responsive, looks great, and a Swiss edition that is no longer made. I'm just getting a little bored with the build but can't decide what to do.
So here's what I'd like to hear your thoughts on these options. I'm no longer racing, maybe 1 or 2 a season, so I don't worry too much about going down and killing nice parts. It's more about doing group rides, centuries, and solos.
XXX-lites gone, replaced with 900g Reynolds MV32T's
Thoughts on these options.
1. Replace frame with Foil, addict sl, Moots RSL, Cervelo R5...old parts.
OR
2. (keep frame) Replace groupo with Red22 or Record 11, EE brakes, New Ultimate bar,stem and Aican cables/housing.
OR
3. (keep frame/groupo) New wheelset, Enve 45, 3.4 clinchers or new Reynolds Assault clincher with tune 70/170.
Thanks in advance
PostPosted: Tue Jul 09, 2013 7:50 pm
So you want to replace the frame, wheels, and groupset? Why not just buy a whole new bike at that point? It's usually cheaper to go that route than build from the ground up, which is essentially what you'd be doing.
PostPosted: Tue Jul 09, 2013 7:52 pm
I would personally hold on to that frame since it fits perfectly and is absolutely boss........so.......
I would go with Red 22 and Enve Wheels....go ahead and match the Enve wheels with Enve stem. Problem = Solved!
:noidea: :beerchug: :beerchug:
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Tue Jul 09, 2013 8:14 pm
I would get a different frame. Since your focus has shifted away from racing, maybe something more compliant instead of super stiff? I don't mean a noodle or anything, but something with nice ride characteristics (for your taste) C59, Dogma, 695 etc. Test riding time.
PostPosted: Tue Jul 09, 2013 9:10 pm
If you want a new frame why not custom? Something like Crumpton or Parlee? Or I would even consider looking for a used Look 585/595 in good shape?
PostPosted: Tue Jul 09, 2013 9:56 pm
I like the frame as well and if you're happy with it then keep it. Personally, I would do a swiss theme because of the rare paint and go with some DT Swiss wheels (carbon clinchers), Sram Red 22 with TRP 960 brakes. I think they go perfect with that frame.
My Bikes:
BMC SLR01 TeamMachine
Cannondale CAAD8
PostPosted: Tue Jul 09, 2013 11:45 pm
As much as I'm one to prefer custom & highly suggest it, I can't quite justify $5000-$6500 for a Crumpton or Parlee. That's why I'm leaning a little towards a stock carbon frame, maybe the Moots if I can find a deal. If I do replace the frame, it will have to be lighter; no sense in replacing the BMC with something of similar weight.
PostPosted: Wed Jul 10, 2013 5:19 am
Id say go for a custom frame or custom wheels. A nice custom frame can enhance your ride quite a bit. A wheelset would be a nice upgrade too but wouldn't be as noticeable as a well built frame.
http://www.zencyclery.com
PostPosted: Wed Jul 10, 2013 10:18 am
Man, I wouldn't part with this frame as it looks proper bad ass! Geometry, colours and pain scheme look spot on! (that said from a pro designer's point of view)
If you're not fussed about weight saving then why bother changing it? Plus, I shouldn't think the bike manufacturing technology has advanced as much in the last few/several years, that a 5 years old frame will slow you down as opposed to any brand new frame... Let alone justifying the money.
New cool wheels and groupset is all this frame needs. Make sure they have slightly more understated look, so the frame doesn't fight colour-wise with the rest of the components.
And last but not lease important, if its comfortable why bother going for smth new? What if you get rid of this, spend all the money and find out the old one is better :D
PostPosted: Fri Jul 12, 2013 8:04 pm
Keep the frame and build it up with Record 11 speed or Sram Red 22. Also buy some hot 50mm high carbon wheels. You will be in love with your bike again.
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
http://i891.photobucket.com/albums/ac11 ... 87f433.jpg
PostPosted: Fri Jul 12, 2013 8:37 pm
Carbon bike design and manufacturing has made a leap forward though. A few years ago there may have been 2 production bikes in the 700s gram range. Now there's at least 7. And there are some "non-production" frames deep into the 600s, with variance into the high 500s for smaller sizes.
That's incredible. We all thought carbon tech was plateauing but it just doesn't look that way.
Unless your company is called Pinarello that is.
PostPosted: Fri Jul 12, 2013 8:48 pm
That bike is in great shape. If you have the itch to change something, maybe identify the weakest component and upgrade that part. The whole set up is clean and seems like good quality parts. I may be a tad jaded as I rode my Trek carbon bike for 13 years and just recently did a new bike so my standard says it should get a lot older and a lot more beaten up before replacing.
PostPosted: Fri Jul 12, 2013 9:23 pm
Go electronic, Campagnolo or Shimano. Makes you feel like you're riding a brand new bike.
K2
Do you suffer more when you train, or cannot train?
PostPosted: Fri Jul 12, 2013 10:56 pm
I recommend keeping the frame set unless there is something you're looking for that this one doesn't have. And then put the new Shimano Ultegra electronic on it....maybe with the 11-32 cassette if you ride mountains often. And for wheels I would stay the safe path, and put some Zipps or perhaps Dura Ace wheels with a profile consistent with most of your riding. The new DA wheels are really superb. Reynolds have some nice ones too. Lots of wheel options.
PostPosted: Wed Jul 17, 2013 9:13 am
[/quote] Carbon bike design and manufacturing has made a leap forward though. A few years ago there may have been 2 production bikes in the 700s gram range. Now there's at least 7. And there are some "non-production" frames deep into the 600s, with variance into the high 500s for smaller sizes.
Unless your company is called Pinarello that is.[/quote]
As much as I completely agree with you when it comes to weight reduction and new technologies allowing us to shave 100-200grams, can we really make the difference? Can you justify the purchase of a new £3-4k frame with saying...."Yeah, it's 200gr lighter and will make me go so much faster" I would say, keep the frame and get better and faster with regular training on the bike ;)
There are no new unread posts for this topic. What factors do you consider when deciding to buy a new frame?
wwnick
21
1081
Sat Jul 01, 2017 5:27 pm
MiddMan View the latest post
There are no new unread posts for this topic. Groupo Weight savings question
addictR1
Sun May 07, 2017 12:42 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Between frame sizes - : Going larger frame vs going smaller frame
jeffy
16
1301
Sun Jul 09, 2017 11:03 pm
sooni View the latest post
There are no new unread posts for this topic. Hi-Mod frame vs non-himod ? Different frame quality ?
[ Go to page: 1 2 3 4 ]
destinationwarmth
49
6379
Sun Apr 16, 2017 7:58 pm
Hexsense View the latest post
There are no new unread posts for this topic. Sram Red BB386 Crankset with BB386 Bottom Bracket in BB386 Frame: Small Chainring touches Frame
jbattermann
Sun Jul 23, 2017 5:06 am
KCookie View the latest post
Users browsing this forum: aplcr0331, AZR3, Baidu [Spider], Bing [Bot], DiegoMendes, Google [Bot], Google Adsense [Bot], Lookryder, yinzerniner and 37 guests
