It is currently Thu Jan 18, 2018 9:17 am
Post new topic  Reply to topic  [ 46 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Ultegra Di2 discs.
PostPosted: Mon Mar 24, 2014 11:16 am
Rear shifting is awesome...no cable stretch yet! :wink:
PostPosted: Thu Mar 27, 2014 6:29 am
I have just built up a new Cannondale SuperX using the R785 levers but mated to the latest XTR M987 XC calipers as they are lighter. I run single ring on the CX bike using the Cannondale Si chainset and a stages PM arm so I have setup the shifting so that both buttons on the RH lever go down the cassette and both buttons on the LH lever go up the cassette. I find this to be very useful with freezing hands you are sure to hit one of the buttons to make the shift!!
With this build I have also routed the cables internally and used the internal mounted battery in the seat tube.
I can't wait to race this bike come September - the Di2 and hydraulic braking combination is just superb
Stephen James
Renvale RT/Reveloutdoors.co.uk/Cannondale
PostPosted: Thu Mar 27, 2014 8:18 am
What frame was it?
Black/grey/red?
PostPosted: Thu Mar 27, 2014 10:03 am
And where were you able to buy a superx frame?
Did you buy a complete bike?
PostPosted: Thu Mar 27, 2014 12:18 pm
It is the normal Cannondale Green/Blacl/White colours, and yes I did have to buy a complete bike but the SRAM disc model can be found for reasonable money. I found one in the USA for $3500 and imported to the UK then sold most of the spare parts!
PostPosted: Thu Mar 27, 2014 12:19 pm
The model from 2013?
Is it "di2-ready"?
PostPosted: Thu Mar 27, 2014 12:42 pm
No it is not Di2 ready but it is quite easy to make a neat job.
I have drilled a hole for the grommet in the down tube then routed the wire inside to the BB. The internal battery sits inside the seatpost and the wire from that also drops down to the BB area. The only part i did not route internally was for the rear mech. For this I drilled a hole in the bottom of the BB shell and took the wire directly out through another grommet and used the shimano cable cover to run the cable on the under-side of the chainstay.
Then for your wires around the BB, I find it is best to use superglue to bond them around the outside of the inner BB shell to keep them away from the BB spindle. I mounted the internal junction box right at the bottom of the down tube near the BB shell.
For me it was quite an easy install although of course make great care with drilling the holes. I own a company that manufactures the wiring harnesses for F1 teams such as Mercedes, RBR, Lotus etc so wiring is second nature!!
PostPosted: Thu Mar 27, 2014 12:45 pm
Ok
Thanks for sharing.
I don't know if i'm willing to drill a carbon frame though.
If possible, please post i picture. It sounds like an awesome bike!
PostPosted: Thu Mar 27, 2014 1:13 pm
Really dont be afraid to drill the frame - a well placed hole never caused any issues! Just make sure you use new drill bits and step up to the 6mm in increments. Also use masking tape on the frame where you are going to drill.
Some pictures
https://www.flickr.com/photos/85831261@N04/13445450024/in/photostream/
PostPosted: Thu Mar 27, 2014 1:43 pm
Lookong good!
Have you finished building the bike?
If so, what does it weigh?
PostPosted: Thu Mar 27, 2014 9:27 pm
7.14 kg with the SRAM Elsa PM chainset, setup single ring. Pretty happy with that, and that is with the 38mm carbon tubs + FMB's as in the pic
PostPosted: Fri Apr 25, 2014 7:18 pm
I'm building one at the moment, having fun with the Di2 and the R785's at the moment.
PostPosted: Fri Apr 25, 2014 7:22 pm
The holes for the grommets are only small 7mm diameter. Just be careful drilling and use the shimano grommets.
PostPosted: Fri Apr 25, 2014 7:24 pm
That's a good tip with the superglue, I was going to use tape.
PostPosted: Fri Apr 25, 2014 7:26 pm
Stephen James
That's a good idea with the shifters and shows the versatility of the Di2.
There are no new unread posts for this topic. Living with Discs - Feedback and Opinions
[ Go to page: 1 2 3 4 5 ]
RyanH
63
5411
Sun Dec 24, 2017 8:42 pm
XCProMD View the latest post
There are no new unread posts for this topic. Calipers rule and discs shouldn't win
dynaserve
7
1098
Tue Jun 27, 2017 2:58 pm
mattr View the latest post
There are no new unread posts for this topic. Attachment(s) It’s Miller Time! Gotobike B36 with EPS and TRP Hy/Rd discs
Miller
38
4536
Tue Sep 26, 2017 3:29 pm
lwk View the latest post
There are no new unread posts for this topic. Attachment(s) Is 2018 the year proper race bikes with discs gain momentum?
[ Go to page: 14 5 6 7 8 ]
alastairb
107
7437
Fri Jan 05, 2018 9:34 am
zefs View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
Users browsing this forum: No registered users and 1 guest
