It is currently Wed Jan 17, 2018 6:38 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Wed Jun 26, 2013 7:34 pm
Hi all, I'm building up a Look 695 currently, have dura ace 9000 on it with Look Zed 2 crank, but need to buy some chainrings. I understand that the 11 speed dura ace setup means there can be shifting issues unless I get 11 speed chainring - I was thinking of buying the following: http://www.amazon.co.uk/Stronglight-Chainring-Ceramic-Shimano-Compatible/dp/B007W0GEEW/ref=sr_1_4?s=sports&ie=UTF8&qid=1372270989&sr=1-4&keywords=stronglight+chainrings but have no experience of this, and grateful for feedback, and any specific recommendations? many thanks for any help, Tom
PostPosted: Wed Jun 26, 2013 7:37 pm
It will not work properly without 11 speed chainrings. Stronglight chainrings in my experience though are good and should get the job done. You could try TA-Specialities though.
PostPosted: Wed Jun 26, 2013 8:37 pm
Thanks for the recommendation - I see that TA do one specifically for Look crankset so will go for this http://www.moilutin-cycles.com/857-plateaux-zenith-pedalier-zed-et-zed-2
I'm going for a 12-28 cassette, do you know what the recommended chainring combination would be?
Thanks again, Tom
PostPosted: Thu Jun 27, 2013 3:32 am
If you are going with a 12-28, I would go with standard size chainrings. But if you plan to do serious climbing, are not in shape, or need to spin as fast as wiggins. I would then go with compact being 50,34 or semi compact 52,36. Personally I would take the semi compact option
PostPosted: Thu Jun 27, 2013 6:48 am
Thanks Lucas, I'll go for semi compact, top line speed is rarely holding me back :wink:
PostPosted: Fri Mar 07, 2014 9:16 am
Been wondering the other way around -- do Look chainrings fit on regular 110BCD cranks? I'm a bit after a "does not match" look.
It seems that the BCD pattern would match -- right?, but I'm wondering about the bolts, since Look requires proprietary ones.
PostPosted: Sun Mar 09, 2014 1:01 pm
Can also get the praxis rings made for Look. They work with Campy 11 at least. I can sell you 52/36 if interested (almost new). Shown here with SRAM 10, but it's been set up with 11. Don't mind my thumb in the upper left! Image
There are no new unread posts for this topic. campagnolo centaur 11 speed chainring compatibility
JoO
Sun Oct 22, 2017 3:19 pm
JoO View the latest post
There are no new unread posts for this topic. SRAM Red chainring compatibility with Shimano 9150 Di2
bpe
Sat Jul 08, 2017 4:53 am
pdlpsher1 View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
737
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. power meter Q again, compatibility
Boshk
Mon Jul 24, 2017 5:31 pm
There are no new unread posts for this topic. 9170 shifters compatibility
hannawald
Mon Oct 23, 2017 11:22 am
hannawald View the latest post
Users browsing this forum: Google [Bot] and 25 guests
cron
