It is currently Wed Jan 17, 2018 12:06 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Thu Jun 13, 2013 1:31 pm
I have a Parlee z0 fitted with the proper size Thomson masterpiece seat post and I notice that the post slips a
Couple millimeters per a 2 hour ride with 6nm of force on the clamp and a generous coat of carbon paste. Any suggestions? Thanks
PostPosted: Thu Jun 13, 2013 1:37 pm
May be a silly question but are you 100% sure it's the right size post? Should be 31.6mm
Is the post/inside of the seat tube worn at all?
How much do you weigh?
A quick/easy temporary fix would be to wrap the inserted end of the post in a thin layer of electrical tape.
Campagnolo; because it's a bicycle, not a fishing rod.
PostPosted: Thu Jun 13, 2013 1:51 pm
Just measured it with digital calipers. The post measure 31.6 millimeters so probably within tolerance. The post isn't worn and the frame is new.
I forgot to add I weight 155 pounds
PostPosted: Thu Jun 13, 2013 1:54 pm
I see no reason why it should be slipping in that case, unless there is an issue with the clamp? Try some threadlock/a new bolt maybe?
PostPosted: Thu Jun 13, 2013 2:08 pm
Could be your torque wrench is out?
Blog: http://thesetbackpost.com/
PostPosted: Thu Jun 13, 2013 2:19 pm
There has to be something else going on here. There is nothing about a Thomson seatpost that should allow unusual slip.
PostPosted: Thu Jun 13, 2013 2:33 pm
Should I try more clamping force? Say 6.5nm?
PostPosted: Thu Jun 13, 2013 2:48 pm
I'd personally check the clamp first.
PostPosted: Thu Jun 13, 2013 2:53 pm
What do I look for in defective clamp?
PostPosted: Thu Jun 13, 2013 2:57 pm
Shearing of the bolt/nut, or the clamp may be slightly too large for the frame and therefore unable to provide suitable clamping force.
 Post subject:
PostPosted: Thu Jun 13, 2013 3:25 pm
Grease between the clamp and frame. Grease bolt threads fully, and under the bolt head. As before, Tacx paste on post to frame.
Sent from my EVO using Tapatalk 4 Beta
PostPosted: Fri Jun 14, 2013 8:24 am
I have always found that the Masterpiece posts are marginally smaller than the normal posts from Thomson. I wonder if the extra machining takes a small amount from the overall diameter. I know it is not the principle of WW, but if the torque is correct and the clamp ok, I would try another Masterpiece to see if it is a case of upper-lower tolerances, and then think about a non-Masterpiece. The weight savings are modest compared to having a robust seat fitting.
PostPosted: Fri Jun 14, 2013 11:20 am
If the Masterpiece is not robust, nothing is robust :wink:
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Jun 14, 2013 11:25 am
i had a similar problem with my ax europa post
6Nm, maximum rated torque - wrench checked against calibrated one at work
clamping bolt/nut threads clean and lubed
inside of seat tube degreased
the post is a tight fit
tacx paste didn't solve it - pink paste
finish line paste didn't solve it - white paste with gritty feel
but a mix of the two pastes did, at 6Nm the post no longer slips, been ok with this method for 3 years now
have to reapply paste mix any time i remove/refit the post, i.e. after boxing the bike for travel, otherwise it will slip without fail
There are no new unread posts for this topic. Travel with Tacx Neo Smart
eurgo
Tue Aug 29, 2017 9:35 pm
MayhemSWE View the latest post
There are no new unread posts for this topic. New Tacx Flux or a Second Hand Kickr
Snugship0
23
2435
Fri Sep 01, 2017 5:24 am
Gearjunkie View the latest post
There are no new unread posts for this topic. Short reach bars... thomson carbon Vs deda superleggero
uraqt
11
901
Thu Aug 24, 2017 2:50 pm
duvivr6 View the latest post
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
There are no new unread posts for this topic. worn seat post
sungod
Sun Oct 29, 2017 5:57 pm
srshaw View the latest post
Users browsing this forum: benzebub, Bing [Bot], Ettore, L3X, stevec1975 and 41 guests
cron
