It is currently Thu Jan 18, 2018 4:27 pm
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu Jun 13, 2013 4:01 am
On most charts there is a hidden menu. Move the mouse to the upper left corner of the chart and click on the tiny gray triangle that appears.
select custom, then 'all chart settings'. click on one power series you want. If you want more hold down 'alt' and click on those.
(its alt for me on Linux. may be different on some other OS).
There is another hidden menu in the upper center.
This is why I dislike hidden menus.
PostPosted: Thu Jun 13, 2013 4:50 am
Thanks eric!
Bike Pure
PostPosted: Thu Jun 13, 2013 4:54 am
Fantastic. Thank you.
Now, if only we could select a certain time (ala V2) easily...
VeloKicks
The Gram
The Men of Steel
PostPosted: Thu Jun 13, 2013 10:38 am
eric wrote:
On most charts there is a hidden menu. Move the mouse to the upper left corner of the chart and click on the tiny gray triangle that appears. ... There is another hidden menu in the upper center.
If there is a menu marker how is it hidden?
It is unobtrusive -- for good reason -- we don't want to confuse new users -- complexity is revealed.
FWIW, we use the same icons as Google (ref Google+ and Chrome menu icons). And there is a section in the FAQ on the menus too.
Mark
PostPosted: Thu Jun 13, 2013 10:42 am
The ltm charts setup is the same as in v2, you select data series from a metric list, if you need more than 1 metric you need to use ctrl+click to select then (like in v2). It is under chart settings and the custom tab.
FWIW, we are changing it for v3.1 to remove the ctrl-click UI element since many users are not used to selecting multiple entries from a list like this :)
PostPosted: Thu Jun 13, 2013 10:56 am
liversedge wrote:
euan wrote:
not had any problems with V3 Beta besides the occasional crash when creating manual activities.
Yowser!
Thats not good, any chance you can describe how to recreate the issue? we need to fix that!
I updated to the release version last night, I'll let you know how I get on with it. Using OS X 10.8
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Thu Jun 13, 2013 1:03 pm
Just in from Mark
liversedge wrote:
http://vimeo.com/68292184
Ctrl+Click to choose another metric and right click to adjust the settings.
We're going to change this in v3.1, in fact here are the mockups for the new dialog:
https://raw.github.com/GoldenCheetah/Go ... ttings.png" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Cheers,
Mark
will help
VeloKicks
The Gram
The Men of Steel
PostPosted: Mon Jun 17, 2013 7:48 am
Minor bug found: When on the Analysis -> Ride tab, in "Stacked" mode, switching between "X Axis: Time" and "X Axis: Distance" will not update immediately, e.g. if the chart has time on the x axis and I switch to distance, it will continue to display with time on the x axis until I trigger a chart update elsewhere. Selecting a different activity seems to work as a chart update trigger.
If not in "Stacked" mode, everything seems to work fine.
PostPosted: Mon Jun 17, 2013 8:06 am
Thanks Krakor -- will look at it.
PostPosted: Mon Jun 17, 2013 8:28 am
Love being able to create charts that I've wanted for a while, my only problem is I can"t find where to choose the colour for the metrics contained within. It doesn't appear in the chart menu nor in the main appearance one. Having issues with some colours clashing and being hard to read.
PostPosted: Mon Jun 17, 2013 9:05 am
It's in the vimeo link I quoted from Mark.
VeloKicks
The Gram
The Men of Steel
PostPosted: Mon Jun 17, 2013 7:38 pm
Many thanks TP - got it now.
PostPosted: Sun Jul 21, 2013 12:08 am
Ok, so v3 is terrific. No doubt.
Anyone else though having some issues? Mainly that it crashes. Quite a bit. Also it now seems the 'find intervals' function (which I love) is now not working...
VeloKicks
The Gram
The Men of Steel
PostPosted: Mon Jul 22, 2013 3:36 pm
If it crashes: send a mail with details to the GC list (there's even some "crash report" now?). The developers are very interested in those and fix bugs almost immediately...
"not working" isn't a very useful problem description. If you can provide some details, please do so on the GC list
(BTW: it is "working" for me... but maybe I just don't use it in the way you do?)
PostPosted: Mon Jul 22, 2013 6:52 pm
Mine occasionally flashes a crash msg on startup, but then opens just fine. The GC forum is certainly the place to pursue any issues you may be having.
"Deserve's got nothing to do with it." William Munny
There are no new unread posts for this topic. Canyon prices and models released in the US.
[ Go to page: 1 2 3 4 5 6 ]
hanakuso1
77
7298
Mon Oct 23, 2017 11:12 pm
hanakuso1 View the latest post
There are no new unread posts for this topic. Attachment(s) Observations from today's ride (aerodynamics and drafting)
fa63
18
1853
Sat Aug 19, 2017 3:37 pm
youngs_modulus View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], liam7020, nestornnk, prototoast, rcb78 and 37 guests
cron
