It is currently Sat Nov 25, 2017 12:55 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Mon May 27, 2013 3:56 am
Depending on how you look at it I was either very lucky or very unlucky. I had just finished decending 6500 ft and was braking to a stop at my vehicle when I heard a cracking sound and my front wheel skidded to a stop. I had almost stopped when it happened so I didn't go down. My front wheel was badly out of true and rubbing on the brake pads. The hub flange had cracked off expelling three spokes! The 20 hole m5 hub was laced to an edge 25 carbon rim. When i got home I carefully loosened all the remaining spokes a little at a time around the rim until I had removed all the spokes. Can I reuse the spokes and rim? It's hard to tell but the spokes seem fine and the rim lays on a flat table with maybe a 1mm gap on one side of the rim.( the table may not be that flat)
I am new to building wheels and would probably have my local shop lace them up with a new hub if that is possible. Since I want to reuse the spokes the new hub must have a similar dimension to the broken M5 hub. I have measured the m5 hub and come up with these measurements. Hub flange diameter 30mm and outside of flange to outside of flange 75 mm or hub center to outside of flange 37.5 mm
Extralight ultrafront sx hub has the following dimensions : flange diameter 29mm center to flange 38mm. Do you think this hub would be a drop in replacement for the m5? Fairwheel bikes is out of stock on the hub does anyone know another US retailer of these hubs?
Am I silly to want to reuse the rim and spokes? the rim and spokes have less than 100 km and are almost brand new.
Disappointed to have broken my wheel but so happy it didn't happen while i was doing 40 mph getting ready to enter a tight curve.
PostPosted: Mon May 27, 2013 7:18 am
I'd re-use the rim and spokes quite happily.....how close is an AC hub? (Micro).......they are about 52g but nothing is as light as your M5 unless you go for a DASH hub. Dash Mira (flanged....you'd have to contact Weston Snyder and see if he'd do you one) are about 30g.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Mon May 27, 2013 8:36 am
Why not get a new M5 hub? As far as I know these hubs don't have a reputation for falling apart very often.
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Mon May 27, 2013 6:12 pm
I guess I'm not a true weight weenie, I will add 20 grams to my bike not to have a catastrophic front hub failure. Also the bearings and service from m5 don't seem up to snuff. Can one even order m5 front hubs right now? I did a quick online search and couldn't find one.
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Broken Campagnolo Brake Shoe Retainer Springs on Record Brakes..
3Pio
Mon Mar 06, 2017 4:39 pm
Butcher View the latest post
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2433
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
There are no new unread posts for this topic. Spacers and front end stifness...
3Pio
Thu Aug 31, 2017 1:44 pm
hannawald View the latest post
There are no new unread posts for this topic. How far are your bars behind your front wheel axle?
rothwem
44
2067
Thu Nov 16, 2017 4:19 pm
evan326 View the latest post
Users browsing this forum: Bing [Bot], blaugrana, Google Adsense [Bot], jeffy, Ulver and 29 guests
