It is currently Sat Dec 16, 2017 8:22 am
PostPosted: Tue May 21, 2013 9:28 am
I'm reading the rotor install guide that indicates there should be no more than 1.5mm of clearance from the teeth to the FD cage.
Does anyone know if they mean this for the tallest point of the chainring or the lowest point?
thanks in advance!
PostPosted: Tue May 21, 2013 10:04 am
Derailleur must be positioned the way that will allow a free movement of the cage over the bigger ring.
If you set it up to the smaller diameter you will not be able to move it on or off the big ring.
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri May 24, 2013 10:52 pm
The highest point of the ring, should be where you take the measurement.
Be patient, pay attention to what you're doing, and these shouldn't be too much of a headache to install.
PostPosted: Mon May 27, 2013 3:59 am
I find that 1mm at the highest point is about the sweetspot, but be prepared to fine tune the height a number of times.
Bike Pure
PostPosted: Sat Jun 01, 2013 5:31 pm
thanks guys.. this was all very helpful. finally on the road at last.
Going from the small to big ring is still a little wonky and takes several tries. I think I have the gap at a tiny bit less than 1mm, going to try moving it a bit and see if I can get this working properly.
PostPosted: Sat Jun 01, 2013 6:27 pm
another tip that may work for you is to adjust the tail of the front d cage inwards (towards the wheel) 1-2 mm more then you would normally. I find this position helps with upshifts.
PostPosted: Sat Jun 01, 2013 7:48 pm
Bear in mind, these rings do not follow to the category of the best gear changing rings :wink:
Having said that, after a number of tiny adjustments finally I can be happy with these fellas.
PS.
I am sure that the flimsy Red with Ti cage plays its role there as well.
Cervelo S5
PostPosted: Sun Jun 02, 2013 12:40 pm
I have no problem with mine, once they are set up right.
Bike Pure
There are no new unread posts for this topic. Convert Rotor QXL to single front ring
hanzypanzy
Wed Feb 08, 2017 10:50 am
hanzypanzy View the latest post
There are no new unread posts for this topic. Compatibility between etap front derailleur and the 53-39 Q-ring
Eclat
Wed Mar 08, 2017 6:11 pm
1415chris View the latest post
There are no new unread posts for this topic. Dura Ace 9100 front derailleur installation problems - can't shift into big ring
eric01
Sun Sep 24, 2017 5:36 pm
mlok View the latest post
There are no new unread posts for this topic. SRAM Centerlock Rotor Lock Ring?
Samklee15
7
1647
Mon Dec 19, 2016 7:36 am
Samklee15 View the latest post
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2618
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
Users browsing this forum: Google [Bot], Google Adsense [Bot], MagicShite and 32 guests
