It is currently Thu Nov 23, 2017 3:23 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Tune Mag 170 disassembly
PostPosted: Thu May 16, 2013 1:04 pm
Can anyone make any sense of the Tune MAG 170 instructions regarding adjusting play with shims?
From what I can tell, you need to measure the protruding axle length on the drive side from the outer bearing recessed in the freehub. Then the instructions say make sure the end cap plus shims is no more or less than 0.2 (aardvarks? I assume mm).
1.I'm not sure quite what that means
2.The axle is so tight in the bearings I'm not sure how to ensure all the 'play' is at the drive end
3.What sort of device do you need to measure? Most regular calipers I've seen wouldn't measure inside the recess of the end cap or the freehub.
Thanks
PostPosted: Thu May 16, 2013 4:31 pm
An easier way to do it, is to just clamp the wheel tightly into a truing stand with a skewer and check the amount of play. If there is any binding in the freehub body or axle, remove a spacer and re-check.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Thu May 16, 2013 4:38 pm
Aha, thanks. That sounds like my kind of solution :thumbup:
PostPosted: Thu May 16, 2013 6:06 pm
I've noticed that the end cup can go loose as a result of changing the wheels.
First when I found a small play in the hub, I removed the cup end, spacers, re-assembled, no play.
Second time I just made sure that the end cup is seated properly by few gently taps.
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
There are no new unread posts for this topic. Campagnolo TOOLS UT-FC220 - Over-Torque crankset assembly and disassembly tool
moccacaffee
Fri Mar 10, 2017 4:44 am
ferrarista View the latest post
There are no new unread posts for this topic. Speedplay Tune ???
1spd
16
1903
Thu Apr 06, 2017 1:19 pm
kode54 View the latest post
There are no new unread posts for this topic. Tune freehub
steelme
7
755
Wed Apr 12, 2017 9:51 pm
steelme View the latest post
There are no new unread posts for this topic. Re-covering tune speedneedle
Martin.F
Thu Mar 02, 2017 2:03 am
Fixie82 View the latest post
There are no new unread posts for this topic. Tune Schwarzes Stuck, any experience?
Penthousepete
Wed Oct 11, 2017 2:32 pm
Penthousepete View the latest post
Users browsing this forum: antonioiglesius, Baidu [Spider], BigPoser, elzilcho, fordred, hamd, Wildh, YinYang and 38 guests
