It is currently Tue Jan 16, 2018 8:44 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri May 10, 2013 6:54 pm
What are the options for a single ring set up with specialized cranks?
I wished I could have been able to use carbon ti x mono-ring, but realized that it would not fit in. Chainstays are few millimeters too wide. So I have go with spider that will move the ring outwards.
Specialized spiders, a bit heavy and expensive?
http://www.mbr.co.uk/wp-content/uploads/2012/07/12e180080.jpg
is that road 110 bcd?
Lightning reversible spider, where to buy?
Bor spiders?
EP Mattias custom made? XX1 spider would most likely have a similar chain line problem like x mono-ring.
Other options?
PostPosted: Sat May 11, 2013 12:07 am
I run the S Works triple on my bike, which is a 1x10, and the chainring is mounted in the middle position.
What kind of bike are you putting it on?
PostPosted: Sat May 11, 2013 9:09 am
Single speed, titanium frame with 68mm bb, I might need 52mm chain line.
PostPosted: Mon May 13, 2013 6:14 pm
The Specialized crankset allows you to adjust it with a few plastic spacers, but if its not a bb/pf30 frame and you're using Vumaquad cups or the like then I'm not so sure. The Lightning spiders can be ordered directly from Lightning, your best bet is to call them up.
PostPosted: Mon May 13, 2013 8:09 pm
There will not be many millimeters left to play with with. 68 bb shell+10mm cups on each side. I also would prefer the axle be centered.
I will have to install the cups later this week and recheck the chain line.
Tonytourist would you mind checking what is the chain line with that triple spider, and also how much further it would go when placing the ring to the outer ring position ?
There are no new unread posts for this topic. Single carbon ring advice
Jenmoss
Sat Dec 30, 2017 12:24 am
Jenmoss View the latest post
There are no new unread posts for this topic. Convert Rotor QXL to single front ring
hanzypanzy
Wed Feb 08, 2017 10:50 am
hanzypanzy View the latest post
There are no new unread posts for this topic. Cannondale SuperX power meter, spider, and chainring options
jkjaer
12
1430
Fri Oct 06, 2017 4:47 pm
nobuseri View the latest post
There are no new unread posts for this topic. FSA carbon spider
in MTB
Yorl
7
943
Thu Jun 08, 2017 1:09 am
poynt View the latest post
There are no new unread posts for this topic. Attachment(s) Spider for SISL Hollowgram (pic)
Luca79
Tue Mar 28, 2017 9:33 pm
Hexsense View the latest post
Users browsing this forum: No registered users and 5 guests
cron
