It is currently Sun Jan 21, 2018 3:59 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: BH G6 2013 (xs)
PostPosted: Thu May 09, 2013 7:10 pm
I have my new frame in my LBS. After 10 years super light frame, finally :)
Came home today. Frame 952g, uncut fork 354g, seatpost 147g.
Uploaded with ImageShack.us
Truth and love must prevail over lies and hatred. (V. Havel, november 1989)
 Post subject: Re: BH G6 2013 (xs)
PostPosted: Sun May 12, 2013 7:01 pm
Finished much early than in 10 years :)
BH G6 (xs), Dura Ace Di2, Mavic Ksyrium SLR. Aha Aha I like it ! :)
PostPosted: Sun May 12, 2013 8:29 pm
Those mavics are pimp!
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Mon May 13, 2013 11:15 am
What size frame is it? You have quite a stack of spacers there.
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Mon May 13, 2013 4:00 pm
Administrator
Mate, please make sure to check the topic title :thumbup: A stack of spacers you say? slamyourstem.com is another website :wink:
I like the look of the BH, you don't see them around that often.
{USERNAME} wrote:
PostPosted: Mon May 13, 2013 11:45 pm
Nice ride! :thumbup: But seriously un-aero wheels on an aero frame? :noidea:
PostPosted: Tue May 14, 2013 10:00 am
Hes got some cosmic SLRs in top pic.
PostPosted: Mon Jun 03, 2013 8:37 am
Race ready :) 7,25 kg.
PostPosted: Mon Jul 29, 2013 5:20 pm
Cranks, brakes, fork cut.
PostPosted: Tue Nov 12, 2013 9:42 am
I have a similar build as yours. I do have a couple of questions though.
How did you route the Di2 wiring through the BB shell? Is the cable able to come into contact with the crank spindle? I routed mine via the mechanical cable guides.
Also, the rubber grommets that came with the frame are meant for e-tube wiring. What type of grommets are you using instead?
Thanks.
PostPosted: Sun Jan 05, 2014 8:00 pm
My english is not perfect, but I will try....:)
Di2 wiring is completely inside the frameset - but the hole under BB area is little bit bigger (about 1cm bigger) - just to get it inside. No contact with crank spindle - because of plastic roller. The biggest problem was cable from RD. The holes inside the chainstays are little bit smaller than end of the cable. I cut it (probably 2mm were enough) :)
Grommets are original from BH.
Btw. I am going to rebuild it with DA 9070 and this DA electronic kit is for sale :)
PostPosted: Sun Jan 05, 2014 9:03 pm
Nice bike. And a handy bag under the saddle to carry your box of fags (UK slang for cigarettes).
PostPosted: Sat Jan 18, 2014 10:35 am
No worries..ur english is perfectly fine and thank you for the explanation. Yes, all the wiring is inside the frame. What i did first was to run the cables inside the BB shell itself. As I was worried that the cables will come into contact with the crank spindle, I decided to run the cables like you did, through that gap underneath the BB shell itself. The routing however is actually meant for mechanical groupsets. Still not happy, managed to find a BB386 to shimano converter from Hope that has a cone in between the bearing cups. The BB cups that came with my frame didnt have the cone.
I think the original grommets are meant for the newer Di2 that uses Etube. It wasnt easy to fit them and I had to resort to melting them slightly so that they would fit perfectly.
The latest 9070 DA would be perfect...but it will burn a super duper big hole in my pocket :p
PostPosted: Wed Apr 09, 2014 12:22 am
Valbrona wrote:
Nice bike. And a handy bag under the saddle to carry your box of fags (UK slang for e cigarettes).
'Slang for cigarette'- what is this. i am not familiar with this word. I hope it has metaphorical meaning. Hope you will elaborate this.
PostPosted: Wed Apr 09, 2014 9:30 am
means a colloquialism :thumbup:
There are no new unread posts for this topic. Fork for 2013 supersix evo 1.125->1.25 tapered
vejnemojnen
Fri Jul 07, 2017 1:13 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. cd super six evo himod 2013 size 52
reedplayer
16
3748
Sun Jul 23, 2017 10:13 pm
dolophonic View the latest post
There are no new unread posts for this topic. 2013 Cannondale Supersix Evo Race Edition - widest tire
G6612
Sat Mar 18, 2017 12:12 pm
dmtevo View the latest post
There are no new unread posts for this topic. 2015 Ridley Helium SL new build & 2013 winter Helium SL
Monkeychunki
15
3116
Sun Feb 05, 2017 9:32 pm
Monkeychunki View the latest post
There are no new unread posts for this topic. 2013 Northwave extreme tech SBS vs current extreme tech shoes
Delorre
Wed Apr 19, 2017 7:37 am
mrlobber View the latest post
Users browsing this forum: No registered users and 10 guests
cron
