It is currently Wed Nov 22, 2017 11:36 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Thu May 09, 2013 7:31 am
I've done a search and couldn't find a thread on reports from owners.
Can anyone comment on these from experience? Any known problems?
I don't plan an SRM in the near future.
I has a set of the standard Clavicula's and they were nothing but trouble.
1. The 2 pinch bolt type and it never stopped squeaking. I tried everything and after 2 years gave up on them
2. There was always a little play in it regardless how tight i did up the preload bolt. It was because the aluminium part on the axle was warn where the bearings sit on it.
3. Also, the aluminium bung that the pedals screw into busted on me so i had to fix/modify it. This is what i did.
I brought them used from evilbay so who know's exactly what happened to them prior, i assumed they were crashed.
THM was excellent with helping me through all the problems so i'm not at all concerned they make dodgy products.
2012 Scott Foil Premium
PostPosted: Thu May 09, 2013 8:40 am
Have them on 2 bikes pf30 on Crumpton and english on Cervelo. I haven't had any trouble except when mechanic didnt torque down clamping bolt and crank came off stripping the preload cap. They mad it right in end by rethreading it with tap. It has been fine ever since, no creaks with pf 30 if you are concerned about that.
PostPosted: Thu May 09, 2013 11:43 am
No dramas at all with mine got a good 10000kms on them.
A set of praxis rings and you got winner. The Front shifting on mine with SR mech 2012 is awe inspiring!
Skunkworks Bikes
PostPosted: Thu May 09, 2013 4:08 pm
I have a set of my personal Storck Aernario Platinum.....the cranks are great.
These frames are BB86 and require the special cups with integrated bearings which I personally don't like as I can't replace the bearings like in the other THM BBs.
Preload and spacers has to be correct...too tight and you damage the bearings. Too loose and you have sounds under torque.
www.royalbicycles.com
PostPosted: Thu May 09, 2013 5:07 pm
I have two pair with many miles on them. They have worked flawlessly. No problems whatsoever!
PostPosted: Thu May 09, 2013 5:36 pm
Jmartpr Any issue with the new M3 clavicula in terms of clearance on the bb86 thm sleeve? I've got a compact THM clavicula (non M3) that I'm trying to install on a bb86 BMC bike. Having issues as the spider on the crank is contacting the outer thm bearing sleeve If i tighten, it squeezes right onto it and basically gets hung up and you can't even turn the arms. I was debating either getting a thm M3 or lightning or worse yet to grind a bit of the carbon off of the spider to create some clearance.
PostPosted: Fri May 10, 2013 12:06 am
At least on the M3 they include a 2.5 spacer you put on the non-drive side. If you don't use it you get the same problem you describe.
THM also include a 1.5 mm spacer for some applications you could add to either side...depending on the frame/application.
Maybe you can try using spacers on the drive side....just make sure the non-drive arms fully seats on the axle.
PostPosted: Fri May 10, 2013 12:22 am
Contact THM and explain the problem. I bet they'll just send you a spacer for free. They have for me every time.
PostPosted: Fri May 10, 2013 12:24 am
PostPosted: Fri May 10, 2013 4:38 am
On two separate occasions THM has sent me spare parts for my clavicula cranks free of charge!
PostPosted: Fri May 10, 2013 6:06 am
Looks like I should drop them a line.....I'll give it a shot. Thanks
PostPosted: Fri May 10, 2013 9:04 pm
I had a set. I had the BB86 Shimano pressfit THM bearings. I couldn't get the chainline correct. The crank was spaced out too far from the frame and caused a weird chain line. I had rubbing in the lower gears in both the large and small rings. The chain wasn't rubbing on the front dr but the cassette itself. It was noisy and I couldn't stand it. Ended up selling them and getting the a set of DA 9000. The problem went away and I can cross chain (not that I do) with little noise. Maybe just a bad crank.
PostPosted: Sat May 11, 2013 10:07 am
what frameset do you have?
I would need the THM BB86 press fit for my Scott Foil.
PostPosted: Thu May 16, 2013 10:12 pm
Sorry for the late reply. 2012 Time NXR. I have a friend with a 2011 TCR(?) Di2 specific had the same issues with the same type of cranks.
There are no new unread posts for this topic. Attachment(s) THM Clavicula SE installation
adamdoc12
Tue May 23, 2017 2:00 am
audiophilitis View the latest post
There are no new unread posts for this topic. Ceramicspeed BB with Clavicula
leej88
26
1977
Fri Apr 14, 2017 8:57 am
benp View the latest post
There are no new unread posts for this topic. THM Clavicula SE BB86 questions
KaneChang
Sat Nov 11, 2017 7:04 pm
KaneChang View the latest post
There are no new unread posts for this topic. Attachment(s) Crank arm fell off. [thm clavicula]
KCookie
41
3842
Thu Dec 01, 2016 5:08 pm
qorwlch View the latest post
There are no new unread posts for this topic. THM Clavicula SE on 2017 Supersix Evo
syvid
10
1278
Tue Aug 01, 2017 3:48 pm
jinnie799 View the latest post
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], stevec1975, tomee and 29 guests
