It is currently Sun Sep 24, 2017 4:41 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon May 06, 2013 3:43 pm
I recently purchased a NOS Zipp 82 hub in polished silver, but want to make it black to match the rest of the bike and components.
What are the pros and cons of having the hub anodized black, versus having it painted or powder-coated black? It this an easy DIY project, or are there any painters you could recommend that would do this in-expensively?
Thanks in advance.
PostPosted: Wed May 08, 2013 6:15 pm
Anodization is not a DIY. You'd have to strip the hub down to the shell, and mask it off, to get it powder coated. Paint will probably peel unless you really know what you are doing.
If you have friends getting stuff powder coated the color you want you could put your hub shell in with their run. It'd be very expensive on a per-part basis to do a powder coat run for a single part.
PostPosted: Wed May 08, 2013 6:42 pm
Anodizing certainly can be a DIY process without a doubt. There is a huge amount of information on the web.
http://lmgtfy.com/?q=diy+anodizing
PostPosted: Thu May 09, 2013 12:01 am
Sure, and you can get a home powder coating kit from Eastwood. Or paint and equipment from your local auto paint store.
But the OP asked for 'easy DIY'. If you have not done any of those before, they are not easy, especially if you care about the finish quality.
Not to mention needing to buy equipment. I assume the OP has not done any of those processes before based on the question.
PostPosted: Thu May 09, 2013 4:26 am
Thanks for your input! Your opinions are much appreciated.
You're absolutely correct regarding the word "easy" in front of the DIY. I was concerned of trying to spray paint the hub myself, only to find a lousy finish that might then flake off once the spokes are brought up to tension. I have read about DIY anodizing, but wasn't interested in having to purchase expensive equipment only to be used once. I was hoping someone might have a DIY way that was not too expensive nor time consuming, yet still lead to a good looking result.
PostPosted: Fri May 10, 2013 1:01 am
I think powdercoating is going to be the only realistic option here. I doubt it would be too much money. It would be imperative for the paint to not be too thick though so that you can still slip the spokes through the spoke holes.
http://www.WheelBuilder.Org
PostPosted: Fri May 10, 2013 7:47 am
German easyelox.de specialises on one-off pieces, does 10x10x10cm parts for like €10. They do lots of bike stuff.
Powdercoating should work too, but you will probably have to re-drill the holes to get the paint out.
It really comes down to finding a shop which does such "small series".
There are no new unread posts for this topic. Changing to compact?
Peedee
11
1022
Fri Mar 31, 2017 11:26 am
DJT21 View the latest post
There are no new unread posts for this topic. Changing Groupset and Wheelset
Shonn
16
1519
Tue Oct 11, 2016 6:59 pm
junchen View the latest post
There are no new unread posts for this topic. SOLD - Giro Synthe Helmet Matte (Titanium/Silver) Medium
asiantrick
Thu Aug 10, 2017 6:44 pm
asiantrick View the latest post
There are no new unread posts for this topic. Chain Length when changing cassette
frede
12
1237
Tue May 16, 2017 6:19 am
TonyM View the latest post
There are no new unread posts for this topic. Changing setup, Aeronova/SL70
PLuKE
Tue Mar 21, 2017 9:30 pm
PLuKE View the latest post
Users browsing this forum: No registered users and 1 guest
