It is currently Mon Jan 22, 2018 7:40 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
 Post subject:
PostPosted: Sun Apr 23, 2006 10:01 am
Popawheelie; I'm planning the work on my front der. right now and am reading through your old posts. I was wondering if you heat the Ti to make it easier to bend or does the temperature have to be to high for Ti to make that work? I have bent steel before and heating it is the trick to make it easy. Your Ti springs look very nice so I was just wondering.
Also, did you (consider) replacing the steel pivots that are in the main aluminium body itself (the part with the limiting screws) I was thinking about replacing the steel nut in there and maybe drilling the massive steel rod. Any thoughts on this would be appreciated!
 Post subject:
 Post subject:
PostPosted: Sun Apr 23, 2006 4:47 pm
hello, my method of homemade is easier. no need plier, no need clamp. You just need new 2 bolt and a wooden plank. On the left side is the work done by 30 seconds. 8)
 Post subject:
PostPosted: Sun Apr 23, 2006 5:31 pm
JDZ3QJ, can't see your picture :noidea:
 Post subject:
PostPosted: Sun Apr 23, 2006 5:33 pm
Don't heat it. To get it hot enough to be easier to bend, you'll permanently weaken it. Bending it at room temperature will make it a little stiffer, so maybe you can get away with using less and still have the springing force you require.
 Post subject:
PostPosted: Sun Apr 23, 2006 8:54 pm
here you go :D
Ciao ebsilon
 Post subject:
PostPosted: Mon Apr 24, 2006 12:03 am
I don’t heat up the ti when I make it. I have heard that heating it would stress relieve it. Ti wants to return to it’s original state. So the spring could get tighter over time. But I don’t think it’s an issue.
The springs I make now are less (4) winds. Since they have less winds they aren’t as uniform in tension throughout their travel. There is more tension on the spring when the chain is on the big ring. It work out great because that is where the spring has to shove off the chain.
The original steel spring needs 4.9 kg of force to make it work. Mine takes 3.5kg. I think 4.9 is to much. I check all my springs for this tension before they go out on the 41 gram derailleurs I tune for fairwheel bikes.
I push the steel insert out and replace it with an aluminum one I make. I change the hole so there is a 7* taper. The insert I make has the same. You could glue in an aluminum nut there. I do the same for the pinch bolt that holds the cable.
I drill out both of the steel posts in the body. I stop just shy of going through but I don’t see why you couldn’t go all the way through. I think a lot of holes in stuff looks a little tacky, but that’s just me. Be careful not to bugger the threads on the one.
There is no Ti or steel on my derailleurs now. Just aluminum and carbon.
You can see from the pic that there are only 4 winds.
 Post subject:
PostPosted: Mon Apr 24, 2006 2:23 pm
Thanks a lot for sharing your wisdom popawheelie :thumbup:
I will try with 4 winds of normal 2.0mm titanium rod, it doesn't have that colouring but it looks like that would work as well. I have no idea how you determine the tension of a spring like this but I will just go by trial and error on this one and see how it works out :D
JDZ3QJ, I can see your picture now (thanks ebsilon!) looks like a good way to make these as well.
 Post subject:
PostPosted: Mon Apr 24, 2006 2:49 pm
Since I'm making them for other people I have to have standards that i can go back to. I made a mount for the derailleur and attached weights to a string. I just measure the weights.
Once I set it up it's not that hard.
2.0 rod should be fine.
 Post subject:
PostPosted: Tue Apr 25, 2006 10:32 pm
Here there is only talk about Ti springs for Campa FD. Has anyone made a ti spring for a XTR FD or RD?
/PalleRaa
 Post subject:
PostPosted: Tue Apr 25, 2006 10:36 pm
I faintly remember something about the XTR/DA RD springs already being ti....
 Post subject:
PostPosted: Tue Apr 25, 2006 10:40 pm
Resident Pro
/PalleRaa
hi, check you pm....
 Post subject:
PostPosted: Tue Apr 25, 2006 11:43 pm
As it works out the Campy front derailleur is the best for tuning. You want to start with the best you can get since you are doing so much work.
But the rear is another story. I've spoken to Madcow about the rear derailleurs and he suggests the Shimano.
We haven't really gotten into rear deraillleurs so maybe the Campy has potential. Madcow has done some tuning to the Shimano rear.
I've gotten one request for a tuned Campy rear but haven't done one yet.
That was from someone who doesn't like Shimano.
For some people a Campy front and a Shimano rear is unthinkable.
But that might be the lightest way to go.
 Post subject:
PostPosted: Thu Apr 27, 2006 1:13 pm
@popawheelie; There is a thread over in the DIY section of the fairwheelbikes forum where Jason says that they did investigate tuning a rear derailleur to sell in the shop, but with all the work involved it would be more economical (and lighter as well) to just buy the new Lightweight derailleur instead. But ofcourse for people tuning their own stuff this isn't a concern :D
There are no new unread posts for this topic. Broken Campagnolo Brake Shoe Retainer Springs on Record Brakes..
3Pio
Mon Mar 06, 2017 4:39 pm
Butcher View the latest post
Users browsing this forum: Allen254, Bing [Bot], MagicShite, TheDoctor and 33 guests
cron
