It is currently Tue Dec 12, 2017 5:53 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Apr 26, 2013 6:01 am
Hello guys,
i have a problem here and i need help to solve it.
My frame is a Scott Spark 900 RC 2013. And i am using a Shimano XTR Double M980 Crankset 38-26T.
I am looking for a XTR Front Der. to use with my system (that is all xtr)BUt...
-The XTR M980 Front Deraileur is only for Triple Cranksets; so... no good for me (mine is double)
-The XTR M985-E is for use with 40-44T cranks; (no good for me, mine is 38T)
-The XTR M-985-E2 is compatible with my 38T crankset. But it is not compatible with the Spark frame. no good for me, my frame is a spark
Any suggestions ?
Is it impossible to use a 38-26T system and a complete XTR kit with a Spark frame ?
Thanks,
Eimart
PostPosted: Fri Apr 26, 2013 12:12 pm
XTR M 985 - see here for various option for clamp on types.
http://www.chainreactioncycles.com/Mode ... Front+Mech
PostPosted: Fri Apr 26, 2013 5:07 pm
The 2013 Spark 900 RC takes a direct mount front derailleur... all you have to do is google "direct mount xtr front derailleur" and it will give you the XTR M986, its dual pull for 2x10 systems.
PostPosted: Fri Apr 26, 2013 5:36 pm
Thanks for the reply my friend,
Do you know if this Shimano XTR FD-M986-D (Direct Mount)
Is compatible with the Spark 900 RC 2013 Frame ?
Because there are 2 types of direct mount right ?
This FD-M986-D you use 1 bolt to fix it in the frame .
And the FD-M985-E2 you use 2 bolts to fix it in the frame.
I dont know what type of mounting the spark 2013 uses , 1 or 2 bolts direct mount.
Thanks,
PostPosted: Fri Apr 26, 2013 6:11 pm
I'm, a little confused... you say in your first post that you have this frame buy you dont know what type of mounting it uses, have you not looked at it?
You need to check your bike, I know it takes a direct mount front derailleur but dont know if its 1 or 2 holes... it its 1 hole you need the M986. if its 2 holes you need the M985-e2
PostPosted: Fri Apr 26, 2013 6:56 pm
Let me explain, i bought the frame and a "Shimano FD-M785 Front Derailleur E-Type, Dual Pull, Top Swing". And i took both to a Bike shop to mount it. Now it is already mounted in the frame, i tried to check if it is using Direct Mount or BB Plate mount, but the crankset dont let me see what type of mount it it using.
And i want to buy a XTR Front. Der. to use on the bike.
I have some pictures here, maybe you can recognize what mount it is using.
Thanks !
PostPosted: Fri Apr 26, 2013 7:50 pm
Looks like 2 holes, so i need the E-Type mounted directly.
So one last question here,
If the M985-E and M985-E2 are the same Front der. But one of them come with BB plate mount and other dont. Why Shimano on their own website specs says that the M985-E is to use only with 40-44T and the M985-E2 is for 38T ?
PostPosted: Fri Apr 26, 2013 9:09 pm
Scott Support told me that i need a "Shimano XTR M985 E2-type 2x10" .
, directly mounted on the frame.
Thanks all,
Problem solved
PostPosted: Sat Mar 07, 2015 10:45 am
Hello,
I have a little problem with front derailleur too. It is SLX in spark 920. The bottom of derailleur scrathed the carbon frame.
Did you have had simillar isues?
Should I replace the front triangle on warranty? or just adjust it properly and ride?
Thanks for your advices.
There are no new unread posts for this topic. Frame set weight question Scott Spark Ultimate 700 vs Spark 700 Plus tuned
in MTB
el condor
7
921
Wed Apr 26, 2017 5:41 pm
el condor View the latest post
There are no new unread posts for this topic. 2017 Scott Scale and Spark RC crank q-factors?
in MTB
hjb1000
Mon Dec 19, 2016 9:53 am
hjb1000 View the latest post
There are no new unread posts for this topic. Attachment(s) Scott RC 900 SL Scale 6.22kg/Spark 7.33kg - Worlds lightest 29"ers
[ Go to page: 114 15 16 17 18 ]
Gullholm
268
58500
Fri Dec 08, 2017 8:19 pm
t0ph0id View the latest post
There are no new unread posts for this topic. 6.87kg Full suspension Scott Spark With Full List
in MTB
SK5
19
1116
Mon Dec 11, 2017 7:42 pm
bikemaniack View the latest post
There are no new unread posts for this topic. Shimano ST-RS505, upshift problem
rainerhq
Mon Feb 20, 2017 10:19 am
rainerhq View the latest post
Users browsing this forum: No registered users and 8 guests
