It is currently Mon Dec 18, 2017 4:33 am
Post new topic  Reply to topic  [ 414 posts ]  Go to page 1 2 3 4 528 Next
PostPosted: Fri Mar 01, 2013 12:39 am
I'll be picking one of these up and need to choose the mount. I'm thinking between the Garmin mount and K-Edge. The K-Edge is a little more expensive but you can adjust it closer to the stem for the 500 or further out for the 800. What is everybody using for their out-front mount and does the 500 seem to stick out too much on the Garmin mount? Thanks!
PostPosted: Fri Mar 01, 2013 12:45 am
Lot of info here -
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=99896
PostPosted: Tue Apr 16, 2013 4:54 am
Sadly, I bought all these garmin mounts in my quest to find the lightest/best option. Cliff Notes version - of these, get the RaceWare.
Here are pics.
K-edge. Cool but fat. Like that the out-in-front arm aligns with the bottom of the stem, keeping the garmin in line with stem instead of above the stem.
Garmin's own offering. Ok but fat and plastic gets you worst of both worlds.
SRAM's offering. Light. 2nd place in looks to k-edge. Out-in-front arm aligns with top of the stem meaning the garmin is perched above stem. Torx screw is hard to swap to ti or aluminum because it's a funky size.
RaceWare version for Garmin 800/810. Lightest. Was 14.x with standard bolt, it was easy to swap for a ti bolt, bringing it to 13.8. Out-in-front arm aligns with bottom of stem, keeping Garmin in line with stem. RaceWare branding looks a bit chintzy but it's raised black-on-black lettering and at this point we're really nitpicking.
RaceWare has worked well so far on rides, no complaints.
2013 Colnago C59 TSRD
2013 Colnago Prestige
2014 Parlee Z-Zero
PostPosted: Tue Apr 16, 2013 5:48 am
Nice compilation! Thanks for putting this together.
(currently using the RWD mount, no complaints, absolutely love it)
PostPosted: Tue Apr 16, 2013 7:50 am
Got a 3D printed mount here:
http://www.shapeways.com/model/964383/w ... -turn.html
Dead 14g with screws (that was V1 though, don't know about V2).
PostPosted: Tue Apr 16, 2013 8:35 am
Any thoughts on Barfly 1.1 ?
PostPosted: Tue Apr 16, 2013 1:40 pm
Bar fly 1.1 seems to be the same story as sram. Weight looks same (or maybe a touch more) according to bikeradar, it perches the garmin above the stem too.
http://m.bikeradar.com/gear/category/ac ... 7006/#next
Only reason to buy this over sram is the gaudy white sram logo if you are a campy/shimano guy. But you can paint over that easily if you prefer the looks of the sram mount.
For me, the raceware is still the winner. Looks normal, light at below 14g, no gaudy logos, mounts garmin in line with stem, and it works...
2014 Parlee Z-Zero
PostPosted: Tue Apr 16, 2013 1:44 pm
Does 16.4g really make any difference to the bike? :unbelievable:
A bit of mud on the seatstays or tyres will make a larger difference...
Campagnolo; because it's a bicycle, not a fishing rod.
M∆SON Definition x Camapgnolo endurance build - ~8.4kg
PostPosted: Tue Apr 16, 2013 1:47 pm
Do you know what website this is? :)
2014 Parlee Z-Zero
PostPosted: Tue Apr 16, 2013 1:51 pm
I know this, but worrying over 16 grammes is a little excessive.
PostPosted: Tue Apr 16, 2013 2:05 pm
The deda zero100 stems and the servizio corse are less than 10g difference at 100mm length but there's a $40-50 price difference. So obviously people are willing to pay for slight reductions.
The difference here is two-fold. First, you actually save money going raceware or sram over k-edge (whilst also saving weight). Second, unlike a stem where stiffness is paramount, these little things are only dead weight if they are built heavier than they need to be to hold a garmin in place when you hit bumps on the road. In short, you aren't losing any function with the lighter mounts. If they work, they work.
End rant :)
2014 Parlee Z-Zero
PostPosted: Tue Apr 16, 2013 2:11 pm
My wife would agree with you wholeheartedly.
2014 Parlee Z-Zero
PostPosted: Tue Apr 16, 2013 2:41 pm
great wrap up on out front mounts.
i've used the barfly 1.0 and 1.1, garmin out front. at the time, i didn't see any option for the lower raceware version...but it looks quite nice and lower than barfly.
the SRAM mount never appealed to me since it is top mounted (like barfly)..not flush mounted like the never mounts.
the Garmin mount takes my 800 nicely (no surprise here), although it is not entirely straight with the stem (Enve stem and bar). i'm willing to try out the raceware once.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Tue Apr 16, 2013 2:52 pm
:lol: :lol:
I have two RaceWare mounts and they work great. Light, ok price and Martin is a sound chap to deal with.
Planet-X Nanolight HM - 5.63kg
PostPosted: Tue Apr 16, 2013 3:13 pm
Shop Wrench
I've had a similar path, which started with the original barfly. I'm currently using the k-edge, because I like the positioning and security of it the most. I never felt comfortable with the barfly. The garmin sits crooked on the garmin mount. I dont like how the k edge interferes with my cable exiting under the tape. I'd like to try the raceware, as it seems the best compromise but find it too expensive at the moment.
There are no new unread posts for this topic. Garmin out front position
hlvd
20
1350
Wed Sep 13, 2017 10:51 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Inside bike storage mounts
gerryc89
Fri Jul 28, 2017 10:09 am
Lelandjt View the latest post
There are no new unread posts for this topic. Single Speed Frame & Fork with Mudgaurd Mounts
SgtRock
Wed Jun 14, 2017 3:37 pm
Ulver View the latest post
There are no new unread posts for this topic. Garmin Vector 2 Upgrade
Kurets
Mon Jan 23, 2017 5:30 pm
Kurets View the latest post
Users browsing this forum: velomane and 7 guests
