Shimano 10s vs 11s freehub compatibility.
expan
by expan
Hi
all my wheels weaponry are shimano 10s freehub(zipp404carbonclincher lightweight obermayer shimano DA WH7850cl24 etc..)
I looking to put new DA in my new project bike
can i put the 11s cassetes of new DA 9000 in my wheels that in allready use with 10s cassetes?????
Please :search:
viewtopic.php?f=3&t=108553
mrd
by mrd
no
FIJIGabe
by FIJIGabe
mrd wrote:no
Welcome to the world of forced obsolecense.
bricky21
by bricky21
You should be able to remove a cog from a few of the 11 sp cassettes(13/14/15/16) to use it on a 10sp freehub.
thisisatest
by thisisatest
For the Lightweight, if it's a DT freehub, just get the DT 11sp freehub. Dish difference is less than the allowed tolerance, so it may actually improve dish if it's erred to the other side.
Zipps, if they're 88/188 hubs, will either be convertible to 11 or Zipp will rebuild it with an 11sp hub for a small fee.
If you're going to drop a cog off an 11speed cassette, best way to do that is to get one that starts with an 11t, and leave that one off. Then you won't have a funky jump in the middle. Only issue, and I just checked, is that there are no serrations on the 12t cogs anymore unless it's a 12t first position. You could Loctite it or possibly use the 12t cogs from your numerous 10sp cassettes.
bricky21
by bricky21
A 12 and 13 tooth cog from a 12-25, or 12-28 cassette would be ideal allowing you to turn an 11-23/25 into a 12-23/25 ten speed. Anybody know if it's possible to source just those two cogs from Shimano?
Dalai
by Dalai
bricky21 wrote:You should be able to remove a cog from a few of the 11 sp cassettes(13/14/15/16) to use it on a 10sp freehub.
This is what I've seen suggested.
Take a shimano 11-speed cassette (11-12-13-14-15-16-17-19-21-23-25), drop out 1 cog and 1 spacer (the 16) to make a 10-speed cassette (11-12-13-14-15-17-19-21-23-25) with perfect 11-speed spacing. Mount this cassette on any 8/9/10 speed shimano compatible rear wheel with one standard (1mm thick) shimano cassette spacer behind it. Set up your 11-speed derailleur and shifters to just use 10 "clicks". Now you're set.
biotin
by biotin
Can mavic ksyri sl premium would able to use 11s cassete?
