It is currently Sat Jan 20, 2018 8:41 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Sun Apr 07, 2013 3:02 am
I have a steel pegoretti duende. It has a super record 11 speed group on it. I want to get a 52/36 combo and am thinking of putting a DA 9000 crank on it. I'm I crazy it just seems that da chainrings seem to shift slightly better but I love the style of campy shifters and ergonomics. So will it work any reason it wouldn't
PostPosted: Sun Apr 07, 2013 3:13 am
It will work. I have seen many people with fulcrum cranks on DA bikes. It will look weird is all. You could always get compact campg cranks and some praxis rings.
PostPosted: Sun Apr 07, 2013 4:18 am
Shop Wrench
Campagnolo has 52/36 rings now.
PostPosted: Sun Apr 07, 2013 7:55 am
Other option is I got a buddy with a 50/34 SR crank who will trade for my 53/39 SR crank. Question is does anyone make 52/36 chainrings for the 2010 SR compact
 Post subject:
PostPosted: Sun Apr 07, 2013 8:28 am
PostPosted: Sun Apr 07, 2013 12:32 pm
Looking at Campag's spares list it appears that the current rings are incompatible with older cranks. I'm pretty sure this is more to do with the chainring bolts rather than anything else, so changing the bolts as well should solve that issue. I'll see if there is any other reason once back at work on Monday.
PostPosted: Sun Apr 07, 2013 1:16 pm
Stronglight CT2 rings
Specialites TA Nerius
Both work well and come in 52 and 36 for the special 110/112 campagnolo configuration
here a link for them
http://www.starbike.com/p/Specialites-T ... CT-3671-en
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
PostPosted: Sun Apr 07, 2013 1:23 pm
Another option would be Miche Super 11 rings. Available in 53/52/50 and 34/36/38/39/42 to fit Campagnolo CT chainsets. Seem to work perfectly well.
http://www.miche.it/en/catalogo/catalog ... i-super-11
PostPosted: Sun Apr 07, 2013 1:34 pm
I'm sure Ulti is correct. Campy has really messed with chainring bolt designs in the past few years, as you can see looking at the 2010 and 2013 catalogs. There are three styles:
1 "conventional" nut (from the back) and bolt, still used on levels below Chorus.
2 reverse system used in 2010 Athena and up with the nut in front and screw at back.
3 "nutless" system today on Chorus and up using threaded inner chainrings.
There are either 2 or 3 different hole sizes in the crankarms to go with the above.
I thought that maybe current Athena CT 52/36 rings might fit 2010 Record, but without having the bits in hand it's hard to say.
There's sometimes a buggy.
One.
PostPosted: Sun Apr 07, 2013 1:50 pm
I have a sneaking suspicion that the change in 2011 was to allow a smaller hole in the crankarm tabs. Athena Carbon CT rings may be a better fit...
PostPosted: Sun Apr 07, 2013 2:17 pm
Shop Wrench
I just put 52/36 campagnolo rings on a super record crank with the white graphics. 2010 I think. Just used some new nutlets chainring bolts.
PostPosted: Sun Apr 07, 2013 3:56 pm
So are these the 2012-2013 campy chainrings you put on your 2010 SR cranks?
PostPosted: Sun Apr 07, 2013 4:09 pm
Campagnolo only started offering 52/36 this year so you'll need to change your rings and bolts.
PostPosted: Mon Apr 08, 2013 4:46 pm
If you're wanting to switch to the DA9000 crank merely for the 52-36 combo, then there are other options as people before me have pointed out. These two threads contain a lot of information about switching chainrings on Campy cranksets:
viewtopic.php?f=3&t=110154
viewtopic.php?f=3&t=96114
If you want 52-36, here is what I would do:
1) Trade your buddy for his SR11 compact cranks
2) Buy TA Specialites Nerius 11 chainrings in 52-36 (http://www.specialites-ta.com/gb/plateau-nerius11.html)
3) Buy the TA Specialites UTC3 chainring bolts (http://www.specialites-ta.com/gb/visserie-utc3.html)
The 36T chainring is $50 and the 52T chainring is $85 from Wiggle. The chainring bolts should run about $35.
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
There are no new unread posts for this topic. New Stages Pwoermeter for Campagnolo Super Record...crank arm question.
kode54
Fri Mar 17, 2017 4:26 pm
AZK View the latest post
There are no new unread posts for this topic. Campagnolo Record/Super Record 11 Rev + Medium Cage
dudemanppl
Fri Aug 04, 2017 4:41 pm
joeyb1000 View the latest post
There are no new unread posts for this topic. Campagnolo Super Record chainrings replacement
xmashx
20
2294
Fri Jan 05, 2018 10:27 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Campagnolo EPS Super Record rear derailleur
rosuch
Mon Oct 30, 2017 10:21 pm
avispa View the latest post
There are no new unread posts for this topic. Sram red 22 VS Campagnolo Super Record VS Shimano 9100
Look595
Fri Mar 17, 2017 6:09 pm
Users browsing this forum: alcatraz, Bing [Bot], bobones, Google Adsense [Bot], iamalex, sovereign, wedgie and 45 guests
cron
