It is currently Tue Jan 16, 2018 8:55 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Apr 05, 2013 8:14 am
Took my TT bike out yesterday and noticed that I couldn't see anything on my Garmin as it was attached to the stem. Any good ideas/products that are suited for the Edge for a TT bike?
If you dream of being famous - think of what birds do to statues.
Instagram: https://www.instagram.com/kermithimself/
Youtube: https://www.youtube.com/channel/UCdCPaXwpeXT_LpuEF0REjqw
Facebook: https://www.facebook.com/gotlegscycling/
PostPosted: Fri Apr 05, 2013 8:43 am
http://www.tatelabs.com/barflytt/
http://www.racewaredirect.co.uk/
ImageSearch
PostPosted: Fri Apr 05, 2013 9:42 am
I made one of block of balsa wood wrapped with carbon cloth. Attached to to bars using zip ties. Even simpler to use piece of pvc tube ziptied between the bars.
Currently I am working with another solution to move computer (currently using Edge 500) even further to be able to use torpedo mount bottle between the hands.
Juha H >> Swim > Bike > Run
PostPosted: Fri Apr 05, 2013 11:12 am
Administrator
I had the same issue when I had my Garmin mounted on my stem. Bought one of these and cut it down. My hands block the air and I can easily see it by glancing down.
http://www.all3sports.com/profile-desig ... nt-xl.html
Pardon the crappy picture.
RESIDENT GRUMPY OLD MAN.
PostPosted: Fri Apr 05, 2013 4:19 pm
Also what works surprisingly well is 2 piece of electrical tape wrapped around the extensions and then the garmin is placed between them. Idea is very similar to juanmoretime's solution but this way the garmin is laying right in between your extensions and you can move it even further forward without worry it will hit your arms.
It is a poor mans solution but worked surprisingly well. I found I could use the same tape for weeks and it would still hold. Since the tape is cradling the garmin from both top and bottom I never feared it falling out. Don't have a picture to show right this second.
My Lynskey R420 with Chorus 11
If you are interested in a Weight Weenies kit I no longer know what you should do.
PostPosted: Fri Apr 05, 2013 4:53 pm
Barfly TT mount is the best
PostPosted: Fri Apr 05, 2013 5:39 pm
Top of steerer tube and two zip ties. Not so pretty, but works great.
PostPosted: Fri Apr 05, 2013 6:56 pm
http://indyville.fi/villen_muut_tiedost ... armin1.jpg
PostPosted: Sat Apr 06, 2013 10:15 pm
Exactly what I do, too.
[weenie]
Couple of wraps of electrical tape has to be lighter than a mount as well. ;)
[/weenie]
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
PostPosted: Sat Apr 06, 2013 11:28 pm
This topic was recently covered in the UK TT forum, some more suggestions there:
http://www.timetriallingforum.co.uk/ind ... =77076&hl= mounting garmin&st=0
PostPosted: Sun Apr 07, 2013 8:12 am
I used the same idea (independantly) as post 18 from the above link. Worked fine in my first race yesterday. Able to see it easily and no movement whatsoever. Was cut really tight in the first place which helped.
PostPosted: Mon Apr 08, 2013 3:43 pm
I use a K-Edge, fully extended, tilted down just a little bit, so I can look down and view it. I will try to post a photo later.
At last year's Interbike, K-Edge announced a new version for TT bikes. I sent them an e-mail, and was told that the product would be made available in March, due to manufacturing constraints with their current lineup. Considering we're in April, and I haven't seen anything, and the regular mount still has a 10-day backlog on their website, I wouldn't hold my breath on that. However, the current model works well if it fits your bullhorn.
PostPosted: Tue Apr 09, 2013 10:37 pm
I've just got a Raceware TT mount. Really nicely made and puts the garmin where you need it.
PostPosted: Wed Apr 10, 2013 3:59 am
I use the Barfly aerobar mount on my TT bike. It's plastic, but still holds the Garmin securely.
There are no new unread posts for this topic. Garmin Powermeter question
PrettyA
7
648
Tue Aug 29, 2017 10:53 am
3Pio View the latest post
There are no new unread posts for this topic. Attachment(s) Garmin Vector failure
jpanspac
12
1767
Sun Aug 13, 2017 3:29 am
NGtim View the latest post
There are no new unread posts for this topic. Garmin Vector 2 Upgrade
Kurets
Mon Jan 23, 2017 5:30 pm
Kurets View the latest post
There are no new unread posts for this topic. Garmin 510 and sram etap
Jowwy
Sat Jun 24, 2017 5:34 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Deda SuperZero and Garmin
jbrandt
21
3049
Mon Jun 19, 2017 3:59 pm
5 8 5 View the latest post
Users browsing this forum: joeg26er, Malammik and 40 guests
cron
