It is currently Fri Dec 15, 2017 12:09 am
PostPosted: Sun Mar 24, 2013 8:55 pm
Hey Guy's,
I'm just about to build up a new to me SL4 Tarmac with 7970 Di2.
I went to the LBS and saw the new under BB battery mount on the Roubaix's. It looks like it's a simple job of removing the existing cable guide and screwing in the mount. Does anyone know the part # and cost to buy it from Specialized?
I know I can go with internal battery kit for $160, but want to keep the funds down and don't want to invest too much into what is becoming a obsolete group. Furthermore, the Specialized mount will work perfectly with my existing internal wire set-up (switching from a 2010 Madone 6.9).
Thanks,
Bill
PostPosted: Mon Mar 25, 2013 1:13 am
I have the madone under BB mount laying around. Let me find it. We can work out a deal. It uses a flatter bolt head to allow the battery to slide off and on. PM me and I can send photos
PostPosted: Mon Mar 25, 2013 5:29 pm
Thanks for the response, but I already have the Madone under BB mount. Looking to pick-up a Specialized under mount for the Tarmac SL4 that I'm building.
Cheers, Bill
PostPosted: Mon Mar 25, 2013 10:16 pm
If you are using 7970 then put the battery in the seatpost or seat tube- this may not be pretty, but it's good for 1,500 km:
Total cost is ~£10
PostPosted: Tue Mar 26, 2013 5:59 am
So if you are stripping the Madone, won't the Madone mount probably bolt to the Tarmac? Unless you are planning on selling the Madone... But if you are hanging on to it, just use that mount for now. If you upgrade to 9070 and E-tube wiring with internal battery in the future you can put the mount back on the Madone
PostPosted: Tue Mar 26, 2013 6:09 am
Thanks for the suggestion. I might go that route. If you've seen the Specialized though, you will see that it's a nicely made mount to fit perfectly under the BB.
PostPosted: Wed Mar 27, 2013 8:52 am
I do understand the appeal of those perfectly made parts. Good luck with this project!
PostPosted: Mon Apr 01, 2013 10:53 pm
FYI, just got the part from the LBS today.
Part#S139900038 - Msc my13 SL4 BB Electronic Mount Kit for Di2.
It replaces the shift wire guide and cleanly mounts the Di2 battery under the BB.
PostPosted: Sat Apr 13, 2013 11:57 pm
Would you please post a pic of it? I asked my LBS to order one of these, should be here next week.
PostPosted: Sun Apr 14, 2013 3:47 am
That is pretty cool the solution including the zip tie on the SL4 is a joke. You have to post pictures and show up the install.
There are no new unread posts for this topic. Help with 2018 Specialized S-Works Roubaix build
Vandit
Fri Nov 10, 2017 7:50 pm
Vandit View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
There are no new unread posts for this topic. EW-WU111 with a SM-BTR2 battery for only ANT+?
Gearhead65
10
1574
Tue Mar 07, 2017 8:05 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Campagnolo EPS V2 Battery Repair
Diverse
Sun Mar 19, 2017 5:11 pm
ferrarista View the latest post
There are no new unread posts for this topic. Di2 battery drain problem
quango2k
Tue Feb 21, 2017 1:30 pm
Users browsing this forum: coachboyd, Dowks, dvq, euan, TobinHatesYou, tyty, wiRIDEfast, Yahoo [Bot] and 29 guests
