It is currently Sat Nov 25, 2017 6:55 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu Jan 09, 2014 12:52 pm
audiojan wrote:
Let my understand this correctly… you're about to drop some serious money on a stunning bike, and you guessing what size you need?! Go and get a bike fit and then spend the money
When you order online is hard to get a fit.
I'm thinking about a Colnago C59 for next season. I'm 182cm and originally ride a 56cm TT on my Trek and Canyon. What size would you recommend. I'm guessing the one with 56cm TT, duh. But Colnago sizing can be a bit tricky. Is sizing down for a more aggressive fit (54-55 TT) and going with a longer stem (like 130mm+) an option here?
PostPosted: Thu Jan 09, 2014 1:12 pm
You should go for 52s. (M10) I am 182 a ride a 52s with 110 stem.
PostPosted: Thu Jan 09, 2014 2:00 pm
I am 180cm and have relatively longer torso, I ride a 56cm (55cm TT ) with a 120mm stem, the equivalent sloping is a 52s.
You could also go with a 58cm ( 56cm TT) or the equivalent 54s
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
PostPosted: Thu Jan 09, 2014 3:34 pm
I'm wondering if 54s would be right or bit too big as I prefer smaller and more aggressive nimble rides.
PostPosted: Thu Jan 09, 2014 3:38 pm
178cm ride at 50s with 120mm stem
PostPosted: Thu Jan 09, 2014 3:52 pm
I'm 5'11" (71" or about 182cm) tall with a 31.5" inseam. I have owned a CX-1, M10 and C59 all in 52s. I have a long torso and use a 135-140mm stem.
That said, go to a Colnago dealer and get fitted... It's worth it with such a large expenditure.
-J
PostPosted: Thu Jan 09, 2014 4:26 pm
I'm 184cm and ride a 54s with 130mm stem, I think 52s would be too small for someone 182cm...
tumblr
PostPosted: Thu Jan 09, 2014 8:31 pm
Njet. 8)
PostPosted: Thu Jan 09, 2014 8:51 pm
6: Is it correct that the frame comes in electronic version and "normal"shifting version? When buying the electronic frame version, you cannot use normal shifting groups anymore?
The C59 comes drilled for electronic and can ALSO be used for a mechanical setup. Covers all bases.
There is no option except that you can "request" they don't drill the holes in the frame if you run mechanical as I do. However,when I ordered my C59 they came back to me with a $1000. charge NOT to drill holes in the carbon!!!
PostPosted: Thu Jan 09, 2014 10:00 pm
The M10 is a fine bike, but if you're plopping down that much money you might as well go all out to the C59.
PostPosted: Fri Jan 10, 2014 10:27 am
180 cm , 52s with 120 mm stem
PostPosted: Sat Jan 11, 2014 8:13 am
Shop Wrench
170cm, 50s, 110mm stem :)
www.southwestbikebuilders.co.uk
https://www.facebook.com/pages/South-We ... 4745587802
PostPosted: Sat Jan 11, 2014 5:52 pm
Any traditional users here? I see that sloping version is more popular here. I'm thinking about 57 or 58cm model or a 54s just need to figure out if I want sloping or not traditional versions look nicer imo but compact might suit me better. Thoughts?
PostPosted: Sat Jan 11, 2014 11:33 pm
Why do you think sloping might suit you better, clearance problems or something else?
BTW, what size stem do you have on your current 56cm TT bicycle(s)? And what saddle to bar drop, how tall is the spacer stack?
PostPosted: Sun Jan 26, 2014 11:36 pm
Would a C59 size 58t with a 120mm stem will be too big for an average build person with 181cm height?
I'm on a verge of buying my first Colnago. Curently I'm riding Trek 3.5 size 56cm with effective TT 56cm (c59 has 56.5cm TT but is different geo).
My friend told me that 58 in Colnago is and equivalent of size 56 on most frames (Canyon, Trek, Giant).
There are no new unread posts for this topic. Another Colnago C60 sizing...sorry
Boshk
16
1045
Fri Sep 01, 2017 1:18 am
Boshk View the latest post
There are no new unread posts for this topic. Colnago C60 Sizing Guide for short leg
bryrene
33
2916
Sat Aug 19, 2017 9:06 pm
cdkoo View the latest post
There are no new unread posts for this topic. Colnago C60 Sizing help - Slope or Traditional?
Nejmann
27
2334
Mon Jul 17, 2017 7:15 pm
Calnago View the latest post
There are no new unread posts for this topic. Colnago C60 vs. Pinarello F10 (or F8): geometry & sizing?
TonyM
20
1742
Fri Oct 27, 2017 4:34 am
TonyM View the latest post
There are no new unread posts for this topic. Colnago Concept? Limited sizing options... max 58s
Tommo
Fri Jun 23, 2017 11:42 am
samuelcfadams1986 View the latest post
Users browsing this forum: beanbiken, Bing [Bot], Chris3g and 37 guests
