It is currently Tue Jan 16, 2018 4:53 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page 1 2 3 Next
PostPosted: Sun Mar 10, 2013 9:46 am
Because I am curious about this Colnago frame and I can't figure out the sizing, I have some questions.
I hope that some Colnago fans overhere can help me out.
1: Is it correct that this frame comes in two versions. A slooping version and a traditional version?
2: If the answer to the first question is yes, how can I see the difference in the geometry and sizing. I see some frames that have a small "s" behind the size. Is this the slooping version?
3: When looking at the slooping version the size that gives the best information about the right size is the "top tube lenght center to center" and the size of the "head tube lenght"?
4: How can you compare the C59 when it comes to stiffness to weight and comfort? Is it good?
5: Why prefere the c59 over the M10?
6: Is it correct that the frame comes in electronic version and "normal"shifting version? When buying the electronic frame version, you cannot use normal shifting groups anymore?
:noidea:
thanks!
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
http://i891.photobucket.com/albums/ac11 ... 87f433.jpg
PostPosted: Sun Mar 10, 2013 10:20 am
1. Yes. C59 does.
2. "S" means sloping. Colnago sizing is special. You have to go up 2 sizes. I am a 56" guy and I needed 52" on my M10.
3. Check on Colnagos homepage.
4. I cannot tell. But people seem to like it.
5. C59 has a "soul" because it is made by hand in Italy. How ever the M10 is lighter, stiffer and has a modern monococ-design. (Frame made in Taiwan).
6. Yes that is correct.
PostPosted: Sun Mar 10, 2013 3:09 pm
I think you've had most of your questions answered. Standard level top tube Colnagos are measured on the seat tube C-T as opposed to C-C like many brands. Look at the top tube length instead. For example, a person who rides a typical "56" from many brands with a ~56 cm top tube would ride a 58 C-T on a Colnago level top tube frame. For sloping top tube models, you would get the same top tube length on the 54s size.
PostPosted: Sun Mar 10, 2013 7:24 pm
Re: Question 5
5. To a limited extent, you have opportunity to order custom sizing with
the lugged construction of the C59.
Ive both a C59 and a M10 and find them comparable in the ride stiffness with comfort and performance.
Honestly, havent been able to discern the difference of lugged vs monocoque construction- but am finding putting more miles on the C 59 of late- maybe because the finish goes w/ our new kits better? :wink:
The "soul" attribute of a frame is generally a subjective and personal preference item but should you enter in the world of Colnago affecianados, you will definitely get more props with a made in Italia Colnago. :thumbup:
Good luck on your selection!
PostPosted: Sun Mar 10, 2013 8:27 pm
enr1co wrote:
Re: Question 5
Amen. ;)
PostPosted: Sun Mar 10, 2013 9:37 pm
Thanks for the information guys!
PostPosted: Wed Oct 30, 2013 3:32 pm
Hi,
First off all, sorry for my english, I only speak a little english.
I am thinking to buy a Colnago C59, and I hava a doubt about the size. I think that my correct size is 52s, i don´t like tradicional sizes.
My height is 1,81 m. The distance from botton bracket center to top of the saddle in my actual bike, a Trek Madone H2 size 56, is 76,5. I have fear that the distance from the seatpost out of the frame is very long.
Somebody has a 52s C59 or similar with my measures? Could see a 52s with 76,5 from bb to top of saddle?
Will my size 52?
Thank you.
PostPosted: Wed Oct 30, 2013 3:38 pm
Why not just compare the Colnago and Trek geometry charts?
PostPosted: Wed Oct 30, 2013 4:04 pm
This is the problem, I have compared and i think colnago is smaller than trek, or at least, different. Also,colnago doesn t show reach and stack...it is a very éxpensive frame and I need to be sure. Thank you.
PostPosted: Wed Oct 30, 2013 4:56 pm
Shop Wrench
Hi Martinez
So , seat tube shouldn't be so crucial - assuming you are using a Colnago C59 Carbon Seatpost, they are 350mm long of which 250mm is usable
The 52s is 52cm from BB to seat clamp, so plus 25cm, gives you total 77cm + the height the saddle sits above the seatpost clamp (on average 4cm), so worst case you should have at least 80cm capable from BB to top of saddle
With a 54s, you get an extra 2cm, so worst case upto 82cm from BB to top of saddle
Your Trek currently has a 56cm top tube, the C59 52s has an effective top tube of 55cm and the 54s has an effective top tube of 56.5cm
The 52s will be a lower front end than your Trek (which I personally quite like!), whereas the 54s would be higher
If it were me, I'd have the 52s, as I like to ride feeling compact and low down!
Good luck
regards, Ian
www.southwestbikebuilders.co.uk
https://www.facebook.com/pages/South-We ... 4745587802
PostPosted: Wed Oct 30, 2013 11:36 pm
What is your drop, top saddle to top or center bars?
What is your setback?
What is your reach nose of saddle to center bars?
I have a similar saddle height on a 52s/56t.
I have a 7cm setback, 76 saddle height, reach I think is 58.5cm. I use a 130mm stem on the large cone spacer and the drop in 10cm to center bars. That should give you an idea.
The bike with this setup rides like a dream, personally I would never want to go for a bigger frame. I've had a 57cm and didn't like as much.
My girlfriend rides a 52s with 78cm saddle height. Seatpost is fine.
PostPosted: Thu Oct 31, 2013 12:05 am
Ian, my fear is to see too much seat post out the frame.
Crazyerrol, i think my drop is 6cm now, although now I use 2 spacers that I dont really need. My setback is 7,5cm. Between the front part of the saddle and de center of the bar I have 55cm, is perfect for me, I think that I need 110 stem.
Do you have any photos of your bike and girlfriend´s bike?
thank you
PostPosted: Thu Oct 31, 2013 4:10 am
Martinez, this bike has 76.4 cms from bb center to top of saddle, just like urs would look, and its a 52slope
PostPosted: Thu Oct 31, 2013 1:46 pm
Thank you Willy, tris photos is perfect!
PostPosted: Fri Nov 01, 2013 12:24 am
Let my understand this correctly… you're about to drop some serious money on a stunning bike, and you guessing what size you need?! Go and get a bike fit and then spend the money
There are no new unread posts for this topic. Another Colnago C60 sizing...sorry
Boshk
16
1302
Fri Sep 01, 2017 1:18 am
Boshk View the latest post
There are no new unread posts for this topic. Colnago C60 vs. Pinarello F10 (or F8): geometry & sizing?
TonyM
20
1995
Fri Oct 27, 2017 4:34 am
TonyM View the latest post
There are no new unread posts for this topic. Colnago C60 Sizing Guide for short leg
bryrene
33
3541
Sat Aug 19, 2017 9:06 pm
cdkoo View the latest post
There are no new unread posts for this topic. Colnago C60 Sizing help - Slope or Traditional?
Nejmann
27
2846
Mon Jul 17, 2017 7:15 pm
Calnago View the latest post
There are no new unread posts for this topic. Colnago Concept? Limited sizing options... max 58s
Tommo
Fri Jun 23, 2017 11:42 am
samuelcfadams1986 View the latest post
Users browsing this forum: benjaminm3, joeg26er, mrtkcmz, Yahoo [Bot] and 41 guests
cron
