It is currently Mon Jan 22, 2018 11:22 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Wed Feb 27, 2013 8:31 pm
I have been using the alu version for about 2 years now. I have never felt my stem to have any undesirable flex. I am 170 lbs and a "sprinter" in cat-4.
I would recommend making your decision based on weight and price rather than stem stiffness.
PostPosted: Thu Feb 28, 2013 3:51 pm
If it's only $30 more, I'd get the carbon... just for the bling factor.
Both are very stiff and the weight is basically the same.
PostPosted: Thu Feb 28, 2013 6:16 pm
Carbon fiber is not the best material for every application. A stem is a good example of an application where carbon fiber is not ideal. Stems go through a great deal of stress and they are rather small in shape. Metal has always been a better choice as the appropriate material for a stem. Don't misunderstand me...carbon fiber stems work just fine. But carbon is better suited to larger items....that way the incurred stress can be distributed across a larger area and a larger number of carbon strands. It's really all about the resin of course.....the carbon fibers themselves can withstand a great deal of tension.
Addressing your specific question, it would not surprise me at all if the aluminum stem was stiffer than the carbon stem. But as other responses have noted, there's probably not enough difference between the two for you to notice. So the best advice is that you simply buy the one that looks best.
PostPosted: Fri Mar 01, 2013 1:55 am
Not sure is you can still get this, but this stem has double the stiffness of the Pro vibe carbon stem.
http://www.pro-bikegear.com/publish/con ... _mark.html
PostPosted: Sun Mar 03, 2013 2:08 am
The alloy Vibe 7s is really stiff. I would recommend an alloy bar, too.
There are no new unread posts for this topic. Attachment(s) Gluing SW-R9150 to Pro Vibe carbon bars
salesguy
7
688
Sun Oct 22, 2017 11:30 pm
MoreRideTime View the latest post
There are no new unread posts for this topic. Paging those with a Pro Vibe Sprint Carbon stem
tharmor
Sat Aug 26, 2017 4:06 pm
Ezra View the latest post
There are no new unread posts for this topic. Pro Vibe Seatpost w/ di2 battery
raggi
Tue Oct 24, 2017 10:44 pm
raggi View the latest post
There are no new unread posts for this topic. Attachment(s) PRO Vibe Aero bars
Schulbub
37
7406
Wed Nov 15, 2017 4:27 am
TonyM View the latest post
There are no new unread posts for this topic. Pro Vibe stem and handlebars
cho00010
Wed Jul 26, 2017 5:05 pm
djwalker View the latest post
Users browsing this forum: dricked, JoshMA87, trimenc and 38 guests
