It is currently Sat Jan 20, 2018 10:04 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Mon Feb 25, 2013 1:44 am
Like the title says, is it possible to replace the 130 mm axle on a rear road hub, and go to a 135 mm axle ?
I'd like at least to be able to do this on my Ultegra hubs, so they fit on my new commuter/cyclocross project...
Any brand doing it ?...
Louis :)
PostPosted: Mon Feb 25, 2013 1:53 am
Chainline might not be optimal, but could you find two 2.5mm spacers and put them on each side of the lock nuts?
Bike: Felt FC
Strava
PostPosted: Mon Feb 25, 2013 2:26 am
A 135mm shimano mtb axle should work no? You'll need additional spacers but it should work.
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Mon Feb 25, 2013 3:11 am
Mmost Shimano Mtb axles will work. Also need a single 5mm axle spacer. it goes on the left side, and you will need to redish the wheel to the left 2.5mm. Do not try to add two 2.5mm spacers to each side.
PostPosted: Mon Feb 25, 2013 3:50 am
How are you going to fit it into the frame?
PostPosted: Mon Feb 25, 2013 3:54 am
My CX frame has 135 mm spacing...
thisisatest, why wouldn't adding spacers work ? I guess not enough axle lenght resting on the droppouts ?
Are there any cheap road rim brake rear hub options with 135 mm axle, like BHS for example...?
Louis :)
PostPosted: Mon Feb 25, 2013 5:13 am
Shop Owner / Manufacturer
^^^Yes. But it will be a MTB hub.
How many holes?
BDop Cycling Co., Ltd.
www.bdopcycling.com
PostPosted: Mon Feb 25, 2013 2:03 pm
I can't believe I'll build another wheel.... :lol:
I guess 28 holes...you're out of A741SB...
Louis :)
PostPosted: Mon Feb 25, 2013 3:33 pm
Shop Wrench
Sure. It will work!
Ultegra hubs just use plain threaded axle's (no oversized stuff), bike shops usually have them laying around somewhere, or else buy a replacement XT rear axle. I've done it on a couple of beach race MTB's. Just swap the axles out and install a 2.5 mm spacer behind the locknuts on both sides.
thisisatest is reffering to the chainline, I think. But this was the easiest solution, it worked just fine and looks clean.
PostPosted: Mon Feb 25, 2013 5:41 pm
I've made a Dura Ace 7700 135mm before with an XTR axle swap. If you already have the wheel, the axle/spacer swap is the cheapest way to go and it's completely functional. Add spacer to the left side. No, there isn't enough axle length to add 5mm total to the existing axle and still have enough left in the dropouts.
www.ergottwheels.com
PostPosted: Mon Feb 25, 2013 10:26 pm
Thanks for the reply,
I ordered an XT axle this morning (from what I read, they're all chrome-moly anyways).
I'll redish the wheel, give the proper L/R spacing.
Now I'll have to use another rear wheel as my everyday/spring/crappy weather road bike wheel...:( Wait, I'm just building this bike so the road bike will be resting inside on those particular days...:D
Louis :)
There are no new unread posts for this topic. One Bike to Rule/Replace Them All...
[ Go to page: 1 2 3 4 5 ]
markgoldstein
71
6394
Tue Sep 12, 2017 3:12 pm
bearsdidit View the latest post
There are no new unread posts for this topic. Thru axle adapter
markyboy
7
436
Wed Dec 13, 2017 12:42 pm
ms6073 View the latest post
There are no new unread posts for this topic. Mag 150 with Carbon Axle?
whydobearsxplod
Fri Sep 29, 2017 11:30 am
There are no new unread posts for this topic. What shoes to replace shimanos 131s
kelih
Thu Jun 29, 2017 2:18 pm
kelih View the latest post
There are no new unread posts for this topic. BSA 68 support for 30[mm] crank axle
Shmitt
10
946
Sun May 07, 2017 1:13 pm
bikerjulio View the latest post
Users browsing this forum: Bing [Bot], blueturtle, Google [Bot], kgibbo1868, spud, Wallis and 46 guests
cron
