Kettle Cycles Carbon Rotors
go4custom
by go4custom
These just arrived for the bike going to NAHBS.
160mm-F/R Formula 1 piece rotors they're replacing were 118g each!
crohnsy
by crohnsy
Sick! I should be receiving mine sometime this month!
limba
by limba
Give us a review once you've abused them.
krzysiekmz
by krzysiekmz
Yes a review would be nice, but I'm also interested how these look on a bike. Thinking about a set as well.
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
devinci
by devinci
very interested in a review of their performance and durability.
giantdale
by giantdale
Same here :D
But, how do I mount them in a centric position? That is easy with round holes for the bolts, but these only have slots ...
ms6073
by ms6073
Sweet. I jumped in right at the beginning of the KickStarter campaign and am hoping to receive my 160s but have not heard/seen anything since I was prompted for shipping information while I was at CX Masters Worlds.
crohnsy
by crohnsy
giantdale wrote:Same here :D
My guess is they will be mounted at the end of each slot so keeping them concentric to the axle shouldn't be a problem..
stephen@fibre-lyte
by stephen@fibre-lyte
I'm curious as to how these work as well. We've done carbon rotors but the limiting factor is the operating temperature of the resin. Carbon-carbon or preferably carbon-ceramic would be the way to go but they're usually very expensive. I'm curious as to the structure of these discs.
youngs_modulus
by youngs_modulus
I have the same question you do, Stephen. In all the coverage/discussion, I haven't seen a full description of the materials involved. Maybe the Kettle Cycles guys will be a bit more forthcoming once they've shipped some product.
Cheers,
Jason
crohnsy
by crohnsy
Here's the description off their website, http://kettlecycles.com
One piece SiCCC SFL rotors
There are two versions of this amazing brake rotor.
The lightest being the single piece SFL SiCCC Rotor.
And the more economical, more customizable two piece SiCCC rotor.
The two piece features a carbon fiber spider and a SiCCC braking outer ring.
SiCCC material, what you need to know:
- Silicon Carbide for bite, Ceramic for heat management, Carbon fiber for strength.
- Dial in the initial bite you want depending on pad selection.
- Wonderful modulation.
- Drilled holes or vents have no performance benefit.
- No glazing or material property changes under even the heaviest use.
go4custom
by go4custom
Waiting for Ashima alloy bolts, but just mocked up with one bolt so you can see they fit like any other rotor.
youngs_modulus
by youngs_modulus
crohnsy wrote:Here's the description off their website, http://kettlecycles.com
Yeah, thanks. I've seen that, though I appreciate your posting it. What I haven't seen is an explanation of why the exterior looks like a plain carbon weave. Neither silicon carbide nor most ceramics are transparent, but most resin systems *are* transparent. I would expect a mottled appearance, but what I see looks exactly like a disc laid up with a standard epoxy resin.
I'm not saying that's damning in any way. I'm just saying I still haven't seen a full description of the materials and construction, and I stand by that for now. I'm sure everything will be illuminated post haste.
Cheers,
Jason
doccoraje
by doccoraje
go4custom wrote: Waiting for Ashima alloy bolts, but just mocked up with one bolt so you can see they fit like any other rotor.
That's a place I wouldn't use alloy bolts, just for peace of mind.
The storm rotors I'm currently using came with alloy bolts, anyway I did use Ti bolts on them, weight savings are minimal.
I'm waiting for the second batch of SICCC rotors.
