It is currently Wed Jan 17, 2018 11:27 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Mon Feb 11, 2013 2:55 am
Hi.
I'm building a dedicated hill climb bike for Mt. Washington where the time penalty is about 30 seconds per pound.
I'm going to run either a single 20 or 22T chain ring which requires 64mm BCD. Obviously shift quality and bearing durability are not issues. loose or broken cranks would be.
Frame will be a PF-30
The Extralite e-bones W (479 grams advertised) look pretty good to me.
Any experience as far as quality?
Any better alternatives?
PostPosted: Mon Feb 11, 2013 8:11 am
They are not extralite's finest work. The company builds good gear but the e-bones are quite an old design. See madcow's review on cranks...it is VERY comprehensive.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Mon Feb 11, 2013 8:55 am
no
PostPosted: Mon Feb 11, 2013 9:43 am
Tried the search but can't seem to find the review. Could you link me please
PostPosted: Mon Feb 11, 2013 6:27 pm
The MTB E Bones have a Qfactor more than 20mm wider than the road version. Is that an issue for you? Other than that, nothing to worry about.
Have you thought about Lightning or Specialized road cranks and using a Lightning 104/64 spider?
PostPosted: Mon Feb 11, 2013 6:57 pm
http://fairwheelbikes.com/forum/viewtop ... =77&t=7916
http://www.hackracer.com/
PostPosted: Mon Feb 11, 2013 8:11 pm
I hadn't- traditionally I just use Shimano stuff for my road and mountain bikes- but I'm inspired to build a ~10 pound bike for this ride.
Q factor isn't an issue- I use MTB triples on everything pretty much.
I'll look into those- thanks for the reference.
PostPosted: Mon Feb 11, 2013 8:20 pm
Necessary research:
viewtopic.php?f=3&t=76357
PostPosted: Mon Feb 11, 2013 8:33 pm
prendrefeu wrote:
Necessary research:
viewtopic.php?f=3&t=76357" onclick="window.open(this.href);return false;
Thanks!
PostPosted: Tue Feb 12, 2013 1:36 pm
I have the road version and can't fault them. Madcow's test doesn't seem too critical of them to me - they are among the lightest in the test, and while the stiffness to weight ratio doesn't seem very impressive I don't notice any flex in mine.
PostPosted: Tue Feb 12, 2013 5:52 pm
Thought about fixed gear?
formerly rruff...
PostPosted: Tue Feb 12, 2013 7:12 pm
Hollowgram SiSL with a one-piece chainring?
/jonas l
PostPosted: Tue Feb 12, 2013 10:22 pm
Yes, but rejected it immediately- the grade varies enough (8% to 22%) to require different gears. Any time gained from weight reduction ( 1 rear cog and no brakes, rear derailer) you (or at least I) more than give back with less than optimal gears at certain spots.
I'm going to run the 4 top cogs from a 9 speed XTR cassette (34/30/26/23) which shoudl give me the proper range of speeds with a 20 or 22T front.
Good thought though
PostPosted: Tue Feb 12, 2013 10:37 pm
I assume that I would have to have such a chainring custom made or is there one currently produced?
PostPosted: Tue Feb 12, 2013 10:59 pm
They're available via HomeBrewed Components (or Fibrelyte, but contact them)
Homebrewed Components.
There are no new unread posts for this topic. Oval chainrings specifically doval brand
wouldyourather
Fri Jan 27, 2017 4:03 pm
ooo View the latest post
There are no new unread posts for this topic. Gearing questions - specifically about putting larger cassettes on road bikes.
alcatraz
9
1223
Fri Nov 03, 2017 10:27 am
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1289
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Canyon Endurace Di2 parts
JayUK
9
1124
Tue Jul 11, 2017 11:26 pm
JayUK View the latest post
There are no new unread posts for this topic. Got $2000 To Spend on FSA Parts - What should I Buy??
joeg26er
18
1952
Thu Jul 06, 2017 3:14 pm
jeffy View the latest post
Users browsing this forum: Bing [Bot], corky, Google [Bot], grouk, lrdunc and 45 guests
