It is currently Fri Dec 15, 2017 9:28 am
Post new topic  Reply to topic  [ 61 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Jun 08, 2013 8:31 pm
Tubeless tape is already installed on the rims, so you only have to consider inner tube vs sealant + valve. I'm quite sure the tubes are around 150 grams, and I use around 90 grams of Stan's in each tire. So still a bit of weight savings there.
I ordered this saddle: http://smud-carbon.eu/saddle.html" onclick="window.open(this.href);return false;. It should weigh around 70 grams, so 120 grams lighter than the Fizik saddle.
I know people who use the XG-1099 without complaints. I don't (yet), because I also think it looks fragile and sounds expensive, and I'm not sure whether I'm going 1 x 11 next year.
I'm thinking about going 1 x 10 for some races, with a 34T chainring, using a spiderless ring like this: http://www.absoluteblack.cc/sram-spiderless.html" onclick="window.open(this.href);return false;
PS. I also saved 100 grams going from 180/160 discs to 160/140. I have plenty of stopping power for my needs (68 kgs). See here: viewtopic.php?f=1&t=112417
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Wed Jun 19, 2013 4:42 pm
Hi marsbar,
I have a couple of new questions if you don't mind :
1. I converted the wheels to tubeless but I noticed that the air escapes near the valve. The valve from Reynolds had a small rubber ring, this ring fits external or internal regarding the rim?
2. I noticed also that the hubs are really "slow" (small wheel inertia) compared to the Sun-Ringle hubs on my other bike). I recorded this :
http://www.youtube.com/embed/xzVjjvVh2ik?html5=1&fs=1
http://www.youtube.com/embed/0e_towfMDuQ?html5=1&fs=1
Did yours move also the same?
3. I turned the bike upside down and then during a ride I noticed a green liquid (oil?) leaking though /near the lefty's rebound (on top)... Did this or something similar happened to you?
Kind regards,
Alex
Sent from my GT-I9300 using Tapatalk 2
Scott Foil Team Issue
PostPosted: Wed Jun 19, 2013 4:51 pm
Sure, no problem.
1) I didn't have problems setting up the rims tubeless. I put the rubber ring on the outside of the rim, but actually I think it might work better on the inside!
2) Hard to say. It could have something to do with the Reynolds wheel being new, having fresh, thick grease in the bearings. I'm not sure. I don't have another wheel to compare mine with, sorry. It could also be the brake pads rubbing the disc slightly, since it's two different bikes...
3) I haven't experienced what you're describing. I think you should talk to you LBS about that. Oil shouldn't be leaking!
PostPosted: Wed Jun 19, 2013 5:19 pm
Thanks for your quick (as always) answer!
1. I put also the ring on the outside. The air is leaking only when the valve is in a certain position. I don't know what to do, and the process to inflate the tubeless is impossible without a CO2 cartridge (the tyre doesn't stay "up" to the rim as I had on Stan's rims)
2. Yes, it might be to the hubs being new, I removed the XO brake to be sure the rotor doesn't touch the pads (the video with the front wheel is with the brake removed). But on your bike if you rotate the wheels do they have the same behavior as in my movie, or they move much easier?
3. Yes, I will go these days but I don't expect to much, let's say that they lack of experience with Cannondale products...
PostPosted: Wed Jun 19, 2013 5:23 pm
Try to put the rubber ring on the inside. I can't explain why you have those problems. Maybe try to find an air compressor somewhere? Inflate the tire, rotate the wheel.
I can't really compare to your video. As mentioned, I don't have any problems with my wheels, they roll perfectly.
They should still be able to tell that what you're experiencing is wrong. Oil should not leak from a brand new fork. They can contact Cannondale if they're in doubt. Or take it to another Cannondale retailer.
PostPosted: Wed Jun 19, 2013 9:02 pm
I will try also this if somehow it doesn't solve by itself on the next ride.. :)
If yours rolls ok, then it might be that mine are new and need more riding time, because I hardly find that both hubs could have problems.
PostPosted: Mon Jun 24, 2013 2:19 pm
Received the Smud saddle. Weight: 71 g on my scale.
The Fizik saddle I took off weighed 205 g on the same scale...
PostPosted: Mon Jun 24, 2013 2:35 pm
Pictures and some riding feedback :-) ?
PostPosted: Mon Jun 24, 2013 6:04 pm
Haven't ridden it yet, but it looks really nice, the finish is impressive.
PostPosted: Mon Jun 24, 2013 8:53 pm
Looks really good, curious to see how looks also on bike, give it a ride and share your impressions.. :-)
PostPosted: Tue Jun 25, 2013 7:24 pm
Nice saddle - how long did you wait? I'm thinking about ordering one :-)
My blog
PostPosted: Tue Jun 25, 2013 9:16 pm
I transferred the money in the middle of March, so almost 3.5 months. Apparently he was hospitalized at some point and fell behind his schedule. Order it before you need it :)
The shape is very much like the Speedneedle I had on my 26" hardtail. I really like it. It feels much more comfortable than the Fizik Tundra it replaced.
EDIT: I updated the first post with a summer photo :)
PostPosted: Thu Jul 11, 2013 2:55 pm
Hi marsbar,
Again I come to you asking if you had encountered braking issues on front wheel, meaning that when you brake (moderate/high speed) the front wheel starts vibrate a lot?
Thanks
Alex
PostPosted: Fri Jul 12, 2013 8:06 am
I have. I think it's the combination if brake discs and pads. Unfortunately Avid brakes are known to be noisy as far as I know.
PostPosted: Fri Jul 12, 2013 12:56 pm
Yes, I previously had Elixir 7, never encountered vibrations but they were awfully noisy.
At the beginning I has very happy with the X0 brakes, no noise, but now they started to make noise, a lot of vibrations reaching the handlebar and also noticed that the braking power dropped.
I will try replacing the pads and maybe the rotor, maybe they got contaminated
Do you know what kind of pads are stock, organic or sintered?
Regards,
Alex
There are no new unread posts for this topic. 2013 Cannondale Supersix Evo Race Edition - widest tire
G6612
Sat Mar 18, 2017 12:12 pm
dmtevo View the latest post
There are no new unread posts for this topic. Cannondale save carbon seat post
Hammersss
Sun Oct 01, 2017 10:54 pm
kevhogaz View the latest post
There are no new unread posts for this topic. Cannondale CAAD10 - Stem Torque for Carbon Steer
steelandbananas
9
998
Sat Feb 11, 2017 6:11 pm
Hamfist View the latest post
There are no new unread posts for this topic. Cannondale Save Carbon Seat Post 25.4 clamp bolt
freshlegs
Tue Aug 01, 2017 5:06 pm
jinnie799 View the latest post
There are no new unread posts for this topic. SRAM Red 22 Crankset in a Cannondale Synapse Carbon 2015 with BB30A?
odessouky
25
1939
Tue Apr 04, 2017 11:50 am
odessouky View the latest post
Users browsing this forum: Google [Bot], Google Adsense [Bot], jbentley, Jimbo1983 and 21 guests
