It is currently Thu Jan 18, 2018 9:15 pm
PostPosted: Mon Jan 28, 2013 10:51 pm
I'm switching from triggers to SRAM XX gripshift and looking for alternatives to the heavy (80g) lock-on grips.
Are there good options that can compete with my old 19g Procraft that I used with the triggers? The problem is that these don't match well with the large diameter of the gripshift...
All suggestions are welcomed. Thanks.
PostPosted: Mon Jan 28, 2013 11:46 pm
I'm using normal bar tape and it feels good, then you can get the thickness you want and is pretty light.
/jonas l
PostPosted: Tue Jan 29, 2013 12:33 am
I use the ESI racer edge and they are very nice, the diameter is a bit smaller then the grip shifter, you would have a pretty perfect fit going with ESI chunky I think
PostPosted: Tue Jan 29, 2013 10:41 pm
Thanks for the replies.
At this point I'm considering either the ESI chunks or the Bontrager x-lite. Both seem to fit well, after cutting them down, with gripshifts.
Has anyone tried both?
PostPosted: Fri Feb 01, 2013 6:08 am
I've tried both, and prefer the ESI grips. They have more grip while wet, and I think they provide a little more cushioning as well. The diameter is just right for grip shift too. Plus, so many fun colors!
PostPosted: Sun Feb 03, 2013 5:02 am
Bontrager Race X Lite is only 17g when cut to 92mm. However, they do NOT like dirt, excessive sweat, mud or crashing. Expect them to last about a full riding season, before they start slipping off the bars.
Due to the urging of all the ladies...I do NOT shave my legs!
PostPosted: Sun Feb 03, 2013 6:29 am
ESI Chunky are a perfect fit.
Sent from my iPad using Tapatalk HD
PostPosted: Sun Feb 03, 2013 10:53 pm
so far, esi grips chunky is by far the best you can get with grip shift, and i´ve tried many many grips...
now there is an extra thick version, the extra chunky, but that would be a little bit too wide for gripshifts. racer edge esi are too thin. chunky is the best i guess
PostPosted: Mon Jul 08, 2013 1:29 am
Bontrager RXXXL foam grips weigh 20g for the pair, cut down to 82mm.
PostPosted: Mon Jul 08, 2013 8:27 am
Holy thread resurrection......
I run KCNC/Porkrinds/Avenir AGG406 (all the same grip) cut down with my gripshifts.
There are no new unread posts for this topic. SRAM Red eTap Shift Kit - $1,299
dudemanppl
Wed Oct 18, 2017 6:50 pm
dudemanppl View the latest post
There are no new unread posts for this topic. Shimano vs. Sram cassette shift quality
vinuneuro
13
1255
Fri Aug 25, 2017 3:47 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Current gen SRAM cassette shift quality
morganb
7
935
Sun Mar 19, 2017 8:13 pm
evan326 View the latest post
There are no new unread posts for this topic. Sram S500 aero shifter very hard to shift
LouisN
Fri Feb 10, 2017 11:19 pm
hack View the latest post
There are no new unread posts for this topic. grips - once again
in MTB
02GF74
Tue Oct 31, 2017 9:26 pm
02GF74 View the latest post
Users browsing this forum: No registered users and 7 guests
