It is currently Tue Jan 16, 2018 11:09 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Sat Jan 19, 2013 3:16 pm
Hello I'm thinking about upgrading my bike with a new frame, and been reading and found out that stack and reach is the best information to have when looking for new frame candidates. I currently own a Scott Cr1 2008 model in size XXL (virtual 61cm).
The original geometry spec doesn't tell Stack and reach. But I've found this page: http://bb2stem.blogspot.se which can help you to calculate the values. But I'm missing some numbers. Could someone help med get the correct numbers for the frame?
The geo specs:
PostPosted: Sat Jan 19, 2013 4:38 pm
A fellow Weenie posted this one a while ago, and I've been using it with success ever since:
viewtopic.php?f=3&t=94384&hilit=calculator
PostPosted: Sun Jan 20, 2013 12:17 am
That's the very same page that I was referring to, and what I'm having trouble to fit all the values into. To get the "correct" result out of. Namely the measurements named:
BB DROP
FORK LENGTH
FORK RAKE
In the spread sheet.
PostPosted: Sun Jan 20, 2013 1:50 am
If you currently own the frame in question, measure it. Place it with the front wheel against a hard vertical surface, steered straight. Take two measurements, one from the head tube top and center to the wall, and the second from the center of the bb to the floor. Now measure from the wall to the bb center. Subtract the headtube to wall figure and that leaves reach. Next measure from headtube center top to the floor. Subtract bb center to floor figure and that leaves stack. Done. The more accurate you are with your centers, the better your figures will compare to published numbers.
PostPosted: Sun Jan 20, 2013 4:58 am
If you get the numbers will you post them here? I have the same frame and size, but forgot my tape measure several hours away..
PostPosted: Sun Jan 20, 2013 11:58 am
This is what I have in my database
blue values are calculated
red numbers are assumed
I note that I'd entered 380 as the fork length for the next generation of CR1 and I think that may be a better figure for the original as I don't recall the fork changing.
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
There are no new unread posts for this topic. Frame Stack and Reach sizing- What is your tolerance?
davidalone
20
1043
Wed Jan 10, 2018 7:51 pm
djwalker View the latest post
There are no new unread posts for this topic. Stack and Reach question
Lookryder
11
1049
Fri Sep 01, 2017 12:23 pm
silvalis View the latest post
There are no new unread posts for this topic. 2016 TCR Advanced M Size Stack and Reach different?
MagicShite
7
697
Fri Dec 29, 2017 3:51 am
Mr.Gib View the latest post
There are no new unread posts for this topic. Scott CR1 frame size?
sanfairyanne
Mon Nov 20, 2017 11:20 am
jekyll man View the latest post
There are no new unread posts for this topic. Scott foil frame finish
toastie
Mon Apr 03, 2017 6:18 pm
toastie View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Digger90, jever98, stevod, Wookski and 40 guests
cron
