It is currently Fri Jan 19, 2018 5:07 am
Post new topic  Reply to topic  [ 3 posts ]
 Post subject: Bontrager XXX seat post
PostPosted: Sat Jan 19, 2013 10:58 am
Got one of these, 31.6 x 400 that weighs 171g !!! :shock:
I plan to fit it to a FS bike, Ibis Mojo SL and not being the lightest rider out there, should I be concerned about breakage? Post will be 1 cm from min insertion so a lot of leverage.
From a review:
{USERNAME} wrote:
Great for road use; off-road probably best restricted to use by waif-like cross-country whippets. :?
Big, rough riders may want to steer clear. Bontrager lists this post on both its road and mountain bike component websites, although in the blurb it does say it’s for “road use only”, which may be worrying for some.
Bontrager doesn’t give a rider weight limit, though. Our 80kg road test pilot had no worries, with thicker post walls at the front and rear compared to the sides helping to keep flex within normal limits.
Many Trek pro cross-country racers already use this post, so if you're hitting the dirt it’s up to you to decide whether you’re light/careful enough to live in harmony with this lightweight carbon masterpiece.
PostPosted: Sat Jan 19, 2013 4:29 pm
I have 3 of these posts and I am 205 lbs. They have held up well plus if you bought it from a dealer you get a 3 year warranty. I have run mine on both hard tails and full suspension with quite a bit of post showing and have not had one issue. Do make sure you torque the seat rail ears to the specified 16NM or you will have a lot of creaking and slipping. Also make sure you have 8 to 10 cm of the post in your frame to make sure you do not damage your frame or post. Enjoy.
PostPosted: Mon Jan 21, 2013 7:42 am
It is actually 2 years, anyways I ran one of these on my HiFi for a couple years and never had any issues. Haven't seen any come into the shop broken either. A torque wrench is your friend with any carbon seatpost.
There are no new unread posts for this topic. go pro mount seat post
nohands
Sat Jul 15, 2017 5:28 am
mpulsiv View the latest post
There are no new unread posts for this topic. worn seat post
sungod
Sun Oct 29, 2017 5:57 pm
srshaw View the latest post
There are no new unread posts for this topic. Seat Post Question
KCookie
Thu Feb 09, 2017 1:36 am
KCookie View the latest post
There are no new unread posts for this topic. Minimum seat post length
Monkeychunki
Wed Jul 26, 2017 2:52 am
Wingnut View the latest post
There are no new unread posts for this topic. Light weight seat post collar?
stockae92
11
1069
Fri May 12, 2017 6:49 pm
stockae92 View the latest post
Users browsing this forum: No registered users and 15 guests
