It is currently Fri Jan 19, 2018 6:32 pm
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Sat Jan 19, 2013 1:22 am
Frame has unnecessary cable stops removed and was repainted
Battery in the seat post
S-Works Crankset (forgot weight but was lighter than SRAM Red crankset I bought)
SRAM Red brakes
Dura-Ace Di2 Dérailleurs
Zipp SL Speed Carbon Road Stem (102g)
Easton EC90 Carbon Handle Bars
Stan's Notubes Alpha 340 Pro Wheel (decals removed)
    Front wheel bare with factory yellow strip (498g)
    Forte light tube (68g)
    S-Works Turbo Tire (200g)
    Zipp Aero Ti Quick Release (26g)
Same wheel in back
    Back wheel with factory yellow strip (702g)
    SRAM Red 11-25 cassette (165g)
    Zipp Aero Ti Quick Release (28g)
Specialized S-Works TOUPE CARBON SADDLE 143 mm (115g)
SRAM PC 1091R PowerChain (255g)
Specialized S-Works SL Carbon 2-Bolt Seatpost (200g)
Specialized Rib Cage Carbon Water Bottle Cages (23g x 2)
K-Edge Garmin Mount (45g)
Speedplay Zero Ti Pedals (164g)
Suggestions or style tips appreciated...
PostPosted: Sat Jan 19, 2013 4:15 am
Nice build. Someone is going to comment on the stack height so it might as well be me. That is a lot of spacers and an upturned stem. With a lot of seatpost (which is okay) but it means you would probably be better with a larger frame size with a shorter stem, or a frame that naturally comes with a higher headtube. I think the maximum recommended spacer height is 4cm and you have got to be on that if not over.
The di2 conversion looks seamless by the way.
PostPosted: Sat Jan 19, 2013 4:20 am
Yes, what should I do? I'm kind of locked into this custom conversion frame without dropping a lot of cash. I tried briefly a quick ride with the stem turned down and really couldn't feel much difference, if that says anything. What's the harm with the excess spacer height?
PostPosted: Sat Jan 19, 2013 4:36 am
Get a proper fit session and then decide: seems like a waste to spend so much money on the parts but then not spending a couple of hundred bucks to make sure they work perfectly with you, for you. A good fit is more important than pandering to us all on here. But we'll still flame you :lol:
PostPosted: Mon Jan 21, 2013 8:14 am
...what they said.
Plus your chain is too short.
EM3
______________
PostPosted: Mon Jan 21, 2013 12:21 pm
The manufacturer specifies a maximum height about the headset as theoretically that is unsupported steerer and is more prone to flex and failure than supported steerer (ie in the headtube) Thus you risk failure (highly unlikely) and less responsive handling (more likely) running that much above the headtube.
Now i am sure that unless you are at the upper limit of the weight scale that it is unlikely to happen to you as the forks are universal and designed to cope with size 49 - 61 and that weights expected weight.
Most importantly, especially on this forum, it looks a bit unsightly.
PostPosted: Mon Jan 21, 2013 4:23 pm
Ok. I'm 185lbs and apparently a 57 by the online bike calculator. All feels quite comfortable, but my fitter has indeed not seen this rig yet...
PostPosted: Mon Jan 21, 2013 5:00 pm
I think you could slam the stem and get some new bars. The way the shifters are positioned could be matched and the drop similar with a new compact bar. Basically your stem goes way up then your bars come way down to the placement of the shifters. Would look much better and not have potential flex in the steerer.
PostPosted: Mon Jan 21, 2013 5:04 pm
Any chance I could just flip the stem and maybe rotate bars up a tad and get a good look with nearly similar position?
PostPosted: Thu Jan 24, 2013 6:57 pm
OK, time for an update. I know you have been on the edge of your seat. Spent 90 mins yesterday with my professional fitter. Told him I love this bike: light as hell; shifts by itself; and I've dropped all my buddies. It *feels* very comfortable to me but I dropped from a 58 to this 56 and want to make sure I'm not making a grave mistake. My neck also started hurting, but I think (hope) this is unrelated to new bike fit. And here's the result.
He raised the seat, rotated the bars, and slid the shifters up a bit on the bars (and retaped). He said this fit looks great on me but doesn't want to change stem just for aesthetics. He didn't mention stack on the cockpit so hopefully I will not crash. So here you go:
Yes, Calfee Design did the Di2 integration work.
PostPosted: Thu Jan 24, 2013 8:28 pm
I did somewhat of the same on my Tarmac. I have the same kind of bars on the bike temporarily and rotating them makes the ergo drop unridable for me.
PostPosted: Thu Jan 24, 2013 11:13 pm
As CBJ mentioned, those drops look unusable now because of the angle, especially in the ergo position.
What kind of fit was it? Retul? BG?
Specialized S-Works Tarmac Sagan Superstar Edition
Specialized S-Works Tarmac Sagan WC Edition
Salsa Warbird Brooks Limited Edition
PostPosted: Thu Jan 24, 2013 11:20 pm
Good questions, and you guys are over my head here. I haven't ridden for real on it yet. But, in the drops long part (whatever that's called) it *feels* ok... I mean, not uncomfortable and i can just reach the brakes. The part on the drops under the long part is tiny to begin with, so I won't be down there.
As for kind of fit, um, just an experienced guy looking at me taking measurements and such -- not computerized.
PostPosted: Fri Jan 25, 2013 3:28 am
So you had
viewtopic.php?f=10&t=111288
And now you moved to 56?
:roll:
PostPosted: Fri Jan 25, 2013 3:34 am
linus wrote:
So you had
viewtopic.php?f=10&t=111288" onclick="window.open(this.href);return false;
:roll:
Well, got 3 bikes at the moment. Trying the electronic thing.
There are no new unread posts for this topic. Attachment(s) Question about sram hidden bolt/non hidden bolt
Chans1ee
Thu Jan 04, 2018 8:42 am
Chans1ee View the latest post
There are no new unread posts for this topic. Specialized S-Works Tarmac SL5
teebs
Mon Jan 23, 2017 11:15 am
teebs View the latest post
There are no new unread posts for this topic. Attachment(s) S-works Tarmac Ideas
Toddbaldwin00
Fri Sep 15, 2017 12:34 pm
Toddbaldwin00 View the latest post
There are no new unread posts for this topic. SL4 Tarmac S-Works with Dura Ace : 6.435 KG
FireRedSL4
16
3165
Wed May 10, 2017 6:12 pm
FireRedSL4 View the latest post
There are no new unread posts for this topic. Tune Gum Gum in an S-Works Tarmac fork
morganb
Thu Nov 09, 2017 6:10 pm
4ibanez View the latest post
Users browsing this forum: Google Adsense [Bot], lone wheeler and 16 guests
cron
