Quo vadis tyre?
Tubbie Guru
by fdegrove
As a little preamble:
Now that the tone is set, I know that some of you do dream up their own ideal* tyres overnight so I wonder what they would need to be like for you so you could perform at your peak?
*I'm having racing tyres in mind and not much else. Clincher, tubular, tubeless (where are you?) round or square I do not care. Rimes doesn't it... :P
Ciao, ;)
by thisisatest
Black chili compound. High thread count, I'm thinking along the lines of Vittoria's polycotton blend, but maybe poly-silk? Vectran breaker, carbon bead to go with the tubeless bead profile. No butyl airtight liner, though. Completely round tread profile, no center peak. Tread pattern like Competitions, but a little finer. 23.3mm front, 25.5mm rear, because a little bigger is a little better!
