It is currently Fri Sep 22, 2017 9:48 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Sun Jan 13, 2013 6:30 pm
Hello everyone,
I'm new here and I have a question. I did search for similar post first, but I didn't find it. So here it goes.
I'm about to buy a new bike, a specialized tarmac sl-4 red. My objective is to become the best climber I can be, so I chose this bike.
I was offered to replace the original Roval CLX40 wheels with a pair of Zipp 202 Firecrest wheels, for extra 600 dolars. Is it worth it? Are the zipps really better? Their weight is very similar, but the higher profile of the CLX40 seems to indicate that it's going to be better on the flat. Is that true? Are the zipps really supposed to be better on the mountains? Why?
Help me out guys, I don't know what to do.
Thanks.
PostPosted: Sun Jan 13, 2013 6:56 pm
For what it's worth the Zipp 202 Firecrest clinchers are getting very good reviews:
http://www.pezcyclingnews.com/?pg=fulls ... ech%20News
PostPosted: Sun Jan 13, 2013 7:00 pm
the rovals are deeper, with a traditional looking profile
the zipps have the wider firecrest profile which is supposed to give drag comparable to deeper rims
unless you can find comparable windtunnel data on the roval it is really a guess, but the 202 fc is reported to give better performance than the much deeper 2009 404s ( http://www.pezcyclingnews.com/?pg=fullstory&id=11045" onclick="window.open(this.href);return false; ), so i'd bet the zipps will outperform the rovals
at 0 degree yaw, there'll be little in it, as yaw increases i think the zipps will have less drag and be more stable
if you spend a lot of time solo at >40kph the lower drag could be worthwhile, also if you're a light rider and it's often windy where you ride then that'd be a good reason too
PostPosted: Sun Jan 13, 2013 7:18 pm
I haven't ridden the 202 FC but have ridden the 404FCC and the clx40 and if I was between the two off the rack - my money would go the the CLX. Those are about the best carbon wheels I've ridden and brake better than my alloy HED rims.
Current:
Blue
Retired:
Project C6.0 | Felt AR FRD | Colnago C59 NERO | 2014 S-Works Tarmac | S-Works Venge | Wilier Cento Uno SL | Tarmac SL2
PostPosted: Sun Jan 13, 2013 7:54 pm
You should read the last Roadbike Action Magazine where they wrote about the wheels. Very good review.
PostPosted: Sun Jan 13, 2013 11:31 pm
In my experience Zipp's hubs have been fantastic to work on which combined with an already outstanding product makes them hard to beat for me. I'm considering a set of 202 FC clinchers as training wheels simply because of how serviceable they are. Sure the rims are expensive but I don't see them being an issue and if I do crack one (I'd likely break any rim in that event) I'll pay the difference because for me as a wheelset to live with they are worth the premium.
Hope that makes sense :|
PostPosted: Mon Jan 14, 2013 1:49 am
The Zipp 202 Firecrest is a really good wheel. Way nicer than the Roval wheel that you speak of.
Do you have an aluminum wheel that you can train on everyday? No way I would train on the Zipp 202.
Even though it is a nice wheel- it is a race wheel. You will wear out the brake tracks by riding it daily, if not damage the wheel on a pothole or something. Also, carbon wheels are no fun in the rain.
PostPosted: Mon Jan 14, 2013 1:54 am
I understand what your saying from a cost perspective however for me I'm offsetting this against the enjoyment of riding that wheel set. I'm not saying it's impervious to wear. It's a personal opinion and I completely accept and understand others will see it differently. It also depends on your purchase price. Hope that makes sense :thumbup:
PostPosted: Mon Jan 14, 2013 3:50 am
Have you ever ridden the new CLX40? Everything you said is basically common Internet folklore.
I vote for the CLX... Or sell them to me ;)
Everyone rides Zipp... Be different.
Current:
Blue
Retired:
PostPosted: Mon Jan 14, 2013 5:07 am
I dont know about the Roval. I've seen them in my LBS and my LBS says they're gonna be the cat's meow once they get out there. Brake tract is suppose to be the shet. Hubs are DT. All not too bad.
As for the Zipp's, I've been on the 303 FC for a year. I train, race, climb...everything. They never come off. What I dont like is the constant hub adjustment required, at least for the rear. Nothing is more annoying than the brake pads grazing the brake tract in the midst of a double century! I've blown 3 tubes on some crazy downhills. Scarey stuff, granted I use latex tubes. What I'm sold on now and going to order is the Enve SES 3.4. Those hoops combined with Alchemy hubs (Tune would be the lightest, but not the stiffest) and Sapim spokes. Ultimate climbers in my book and from what I've been told. I can't wait until Alchemy finishes their Shimano 11sp hub, then I'll be all over it.
It might be bye-bye Zipps.
PostPosted: Mon Jan 14, 2013 5:52 am
Interesting post Horacio, thank you.
Could you elaborate a little more on how the Latex tubes where failing?
PostPosted: Mon Jan 14, 2013 6:10 am
Heat build up from the brake tracts causing tube pressure to rise beyond limit evidenced by tube seam failure.
Aka the brown drawers effect.
PostPosted: Mon Jan 14, 2013 9:29 am
This is a good question as I'm going through the same myself.
I know the CLX40 has ceramic bearings, I've held the bearings and they spin, spin, spin, but also the spoke nipples are not accessable for service unless you remove the rubber, maybe an issue for you or not. Currently, Zipp Firecrest are pretty much the Gold standard for carbon rims, heat tollerance and braking performance, the Enve's are up there as well. To me the CLX are unproven, they may be the best, they may not be, but its doing my head in trying to decide. I've heard there have been issues with Zipp hubs, but then again the latest version of them are supposed to be pretty good.
Fortunately the shop I'm buying my S-Works through have said they will let me test ride their demo sets of Zipp 202 FC, Zipp 303 FC, CLX40 and Enve 3.4, so should have a pretty good idea by the end of it. None of them are cheap wheels, but the Enve's will cost me a bit more over the other three builds. I guess its nice problem to have, really :).
PostPosted: Mon Jan 14, 2013 9:53 am
I don't disagree with anything you have said above but if I may offer an opinion on the ceramic bearings based on quite a lot of personal experience and trial & error. OEM ceramic bearings that I have come across are hybrid bearings and are not worth swaying your wheel decision over. Hybrid bearings have there own strengths and benifits although I'm no bearing engineer so I won't waffle on. They usually are over lubricated and normally have fairly standard seals which drag, its the combination of playing with these two variables that manufacturers use to adjust how they feel in your hands. If I stripped all the grease and removed the seals they would be radically different and although they would now be much closer to a full ceramic bearing performance wise (by feel) they will not survive being used in that state. Ceramic bearings can, contamination aside, be run dry or with a very very light lube. This isn't their only advantage and they where not designed for cycling so their heat tolerance for example is irrelevant but choose a wheelset based on other merits. You can upgrade to higher quality bearings should you wish at a later time very easily.
Hope that helps someone
PostPosted: Mon Jan 14, 2013 2:48 pm
There are huge difs in bearing quality... Having a portion be ceramic isn't the last word.
As for carbon clincher brake track heat resistance, I don't believe there are better rims and pads available than Zipp right now...
But if the op really wants to climb, it may be better to try for a set of tubulars... You can go to deeper set of zipps for the same weight as the new 202 clinchers.
charles@pezcyclingnews.com
There are no new unread posts for this topic. Real world use of ZIpp 404 firecrest - I am struggling. Advice req.
[ Go to page: 1 2 3 4 ]
diegogarcia
57
4613
Thu Apr 27, 2017 8:51 am
yongdaeok View the latest post
There are no new unread posts for this topic. Roval CLX 32 vs. Mavic COSMIC PRO CARBON SL C
christofersmith
Wed Nov 02, 2016 5:04 am
thedonnydino View the latest post
There are no new unread posts for this topic. Do Roval Disc CLX 50's fit Canyon Ultimate CF SLX Disc?
dvearn
Thu Jun 01, 2017 6:32 am
hannawald View the latest post
There are no new unread posts for this topic. Zipp SL-88 vs. Zipp SLC2 TB
TSJ
Thu Sep 21, 2017 8:55 pm
TSJ View the latest post
There are no new unread posts for this topic. Zipp 303 vs Zipp 404 chainstay rub
nemeseri
Thu Feb 16, 2017 6:01 am
are View the latest post
Users browsing this forum: andrey, iamalex, kookie, mriddle and 37 guests
