It is currently Sun Jan 21, 2018 2:17 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Sun Jan 13, 2013 11:59 am
Had a fitting and bought a frame (Enigma Esprit, titanium with horizontal TT) - How best to deal with the recommended 30mm spacers...
Thomson X2 100mm stem / spacer combo:
+10deg, 30mm spacers
+17deg, 15mm spacers
Doing the maths either of the above options will work for my fit but now to choose which is going to look better - Anyone got photos of a frame running a Thomson X2 at +17degree (prefereably a titanium frame)?
PostPosted: Sun Jan 13, 2013 12:43 pm
None of your options are going to look good :D :D
You will have to do a lot of stretching this winter like this: http://www.bikeradar.com/fitness/articl ... sts-26074/
And then slam that stem! :beerchug:
Bring the mountains to Denmark!!
PostPosted: Sun Jan 13, 2013 1:03 pm
Thanks for the link tcramer. Pretty flexible already but would rather be comfortable with 30mm spacers than slammed and in pain!
Might have to start a one man crusade against the slammed stem!
PostPosted: Sun Jan 13, 2013 1:37 pm
Whoops, misread your question, sorry.
  • 2011 Cannondale Flash F1
  • 2010 Cannondale Caad9
  • 2000 Caad 4 aero
PostPosted: Sun Jan 13, 2013 2:22 pm
Ew.....yeah, this is gonna be tough to pull off. I would have to say that the 30mm of spacers with the less vertical looking stem would look best to me.
What's the stem length recommendation for each?
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sun Jan 13, 2013 2:32 pm
The correct option here would be to return that frame and get one with a taller head tube :mrgreen:
If you can't do that, I vote for +17 with less spacers; it will be lighter that way.
My Bikes
My Photoblog
PostPosted: Sun Jan 13, 2013 2:53 pm
quattrings - Don't worry, that was mean looking TT rig! Was good to see the 17deg stem on a bike.
btompkins0112 - A 100mm stem in either would work. Would make up the diference in fit by moving the saddle fore/aft a couple of mm.
fa63 - Custom version of the frame was an option but that was a considerable price difference for 30mm of spacers! Looking around I was getting a longer toptube than I wanted for the taller HT.
Was hoping the 17deg stem would work as well as on GGG's Baum you've both also commented on - pretty nice setup there.
PostPosted: Sun Jan 13, 2013 3:00 pm
Yeah, the difference is going to be the horizontal TT, I think. We shall see!
Mosaic RS-1
PostPosted: Sun Jan 13, 2013 7:31 pm
Putting the design degree to good use, here's an illustration of each option...
(Added a cheeky 5mm spacer on top of the stem as per the ENVE recommendation).
Is there a standout favourite?
PostPosted: Sun Jan 13, 2013 7:59 pm
I agree, I am not sure a positive rise stem looks as good with a horizontal top tube.
My Bikes
My Photoblog
PostPosted: Sun Jan 13, 2013 8:30 pm
Start here:
http://www.brightspoke.com/t/bike-stem-calculator.html" onclick="window.open(this.href);return false;
...actually, if you have to ride with that many spacers and flipped stems, you are not flexible. Are you sure you have the correct frame size?
EM3
______________
PostPosted: Sun Jan 13, 2013 8:43 pm
The only thing that really looks good with a horizontal top tube is a -17° Stem. I know because I have one.
HOWEVER, I really wouldn't worry about lots of spacers. I ran up to 40mm with mine. It looks and works just fine. The only people who worry about the number of spacers and "slammed stems" are a small fraction of the WW crowd. :thumbup:
PostPosted: Sun Jan 13, 2013 8:45 pm
Usually I'll try and match the angle of my stem to the angle of my top tube. It's really just preference though.
PostPosted: Sun Jan 13, 2013 9:05 pm
Less stem rise and more spacers looks a tad better, it also allows you to keep a longer steerer tube just in case you might need it later.
PostPosted: Sun Jan 13, 2013 9:24 pm
+1
or get stretching
if it has to be one of those then I'd say the +10 option, then try to reduce the spacers as you become more flexible.
There are no new unread posts for this topic. The best height of spacers?
[ Go to page: 1 2 3 4 5 ]
Aya
65
3465
Sat Jan 20, 2018 4:25 pm
IrrelevantD View the latest post
There are no new unread posts for this topic. Spacers for SRAM GXP team BB
leicaman
Mon Mar 13, 2017 4:21 pm
leicaman View the latest post
There are no new unread posts for this topic. Spacers and front end stifness...
3Pio
Thu Aug 31, 2017 1:44 pm
hannawald View the latest post
There are no new unread posts for this topic. Attachment(s) Spacers with Hollowtech 2 for Stages Clearance
goatie999
13
1172
Thu Nov 16, 2017 6:34 pm
BikeAnon View the latest post
There are no new unread posts for this topic. Attachment(s) Chain length for running both 12-25 and 12-29 Campy
Alexandrumarian
Fri Aug 25, 2017 7:57 am
TobinHatesYou View the latest post
Users browsing this forum: arthurf, bobones, Digger90, edroc73rp, srshaw, wicz and 36 guests
cron
