Yokozuna brake cables with 2012 SRAM Red Brifters
Cleaner
by Cleaner
I have used Yokozuna Reaction brake cables with the first generation SRAM Red shifters and was able to install their ferrule and fully seat it in the shifter housing and they work quite well. I just built up a new bike with the latest gen SRAM Red and the Yokozuna brake ferrules will not insert in to the bore in the shifter housing. Does anyone know of a ferrule of the proper dimensions that fit the shifter body bore and will accommodate the Yokozuna cables? Jagwire and SRAM ferrules fit and seat in the bore but are too small on the open end for the Yokozuna cable O.D.
NWSAlpine
by NWSAlpine
You are not suppose to use ferrules on the shift cables entering the shifters with 2012 Red. The ferrule is built into the lever. The manual clearly states this. I use the reaction cables with 2012 Red and it works really well.
Cleaner
by Cleaner
I did refer to the documentation from SRAM before posting here, maybe you have something different than what I am holding or is posted on the SRAM website, if so please share.
See this picture from the installation manual there is clearly a ferrule indicated in the assembly of the brake housing. The 4 mm ferrule in the housing body is for the shift cables.
NWSAlpine
by NWSAlpine
Sorry not sure how I misread you post so wrong. Anyways I used the Yokozuna ferrules on the brake cables and it was tight but it works. You need to just push it in a little harder and it will go all the way.
Elrey
by Elrey
NWSAlpine wrote:You need to just push it in a little harder and it will go all the way.
Sorry...
:lol:
NWSAlpine
by NWSAlpine
Sorry...
:lol:
Works on your mom too :thumbup:
Elrey
by Elrey
HAHA. Classic. Sorry for highjack.
