It is currently Sat Nov 25, 2017 5:17 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
 Post subject: KCNC X7 or Magura MT-8 ?
PostPosted: Mon Dec 31, 2012 12:29 pm
Hi
I have just searched for some info / reviews of the KCNC X7 disc brake and have come up with nada :(
Can someone provide me with a link / clicky please as I'm sure this has been covered somewhere on here :thumbup:
Also what are the Magura MT-8 brakes like in comparison to the KCNC's or any other brakes for that matter ?
Are there any other suggestions as to reliable , powerful alternatives ?
I would like something reasonable light at around or close to the same price as the Magura's or KCNC's but I don't want to be adjusting pads / discs every other ride or bleeding them once a week .
TIA guys
Fattrucker
PostPosted: Mon Dec 31, 2012 12:53 pm
amongst the lightest are Formula R1
not sure where you are based but you can get a pair of these new for £ 300 - a lot less than the price of the KCNC brakes. (also see ebay and you can get closer to £ 200)
http://www.chainreactioncycles.com/Mode ... elID=69866
although only rear is listed, buy 2 sets and shorten the hose for the front lever - levers are symmetrical. :thumbup:
apart from not being able to use these with Hope SAW rotors, I have not come across any problems or complaints about Formula R1 brakes.
... I dare say others will suggest alternatives - one to avoid is the earlier Avid XX - google and there is no end of problems. (I have the latest model and not had any problems but not done many miles - they are 50g heavier than R1 and for me, the lever is not in an ideal position).
PostPosted: Mon Dec 31, 2012 2:02 pm
Thanks O2GF74 , I keep forgetting about the Formula brakes . From recollection didn't they have some sort of leaking seal issue (was this related to just one model of brake or the entire line ?) or has this been resolved on the newer models ?
P.S. I have managed to get the price of the KCNC X7 down to around £340 delivered iirc :wink:
Fattrucker
PostPosted: Thu Jan 03, 2013 11:23 pm
i would stay away from the KCNC's I've purchased 4 items from them over the years and have had 2 of them brake on me. On top of that they never returned my emails, when i tried to get the situation resolved. I'd look at the Magura's if these are the only 2 you are looking for.
I personally just got a set of the new XTR's and love them, and all of my other bikes I run Hope. So I would recommend looking at those guys as well.
Rapha cycling's Ed Hardy
PostPosted: Fri Jan 04, 2013 1:03 am
XTR is my top choice. Then Magura, then formula.
I have yet to find a downside to the XTR. maybe the weight, I've never actually weighed them (what?!). MT8 are just a little soft feeling at the lever. It reminds me of the Sram 9.0sl v-brake levers from back in the day. they were composite as well, and even though they supposedly tested as stiff as others, there was a sense of give at the lever. biggest gripe with the formulas is the pads run pretty close so they're more likely to rub, and in the US or around here at least, formula pads aren't often stocked.
As for avids, well:
PostPosted: Fri Jan 04, 2013 4:28 am
XTR brakes are great, but in typical Shimano fashion they are not the lightest. They have great power and modulation--some of which is due to the fantastic IceTech rotors (heavy).
I just got a set of MT8 levers with a bike, but I'm planning to sell them. They are light, but I have other bikes with Formulas (equally light, if not a hair lighter) and would rather keep things consistent.
The OP won't go wrong with newer formulas. Also, word is that the 2013s have pads that retract a bit more than earlier models, which will help with setup and reduce drag. I have found it was often challenging (not impossible, just harder than with other brakes) to get to a situation with no rub. Add in lightweight rotors which are subject to more warping and you've got a problem.
PostPosted: Thu Jan 17, 2013 2:53 am
Thanks guys , no other lightweight good performing stoppers I should be looking at then other than formulas ?
PostPosted: Thu Jan 17, 2013 5:47 am
My vote is for Magura MT.
Mainly cos i prefer mineral oil as compared to dot.
the the MTs are good performers
PostPosted: Fri Jan 18, 2013 4:27 am
R1, the new Racing with ECT.
Cheaper than the Magura, and far better. Forget the KCNC.
PostPosted: Sat Jan 19, 2013 3:42 pm
I've recently bought an MT6 and am looking to sell it already.
I would consider something like the Shimano XTR's or Hope X2 Race if you don't mind a tad extra weight although i'll be going down this route.Extra weight is worth it if it's reliable kit.
PostPosted: Sun Jan 20, 2013 7:05 pm
@Bradley What's the problem with the MT6's ? I've heard of a seal problem on the first MT8's (too hard of a durometer on the piston seal allowing air to seep in and a re-bleed)
PostPosted: Mon Jan 21, 2013 8:24 pm
It wasn't a seal issue with the MT6,I'm a pretty particular mechanic/cyclist and like everything spot on on my bikes.I found it frustrating to use, the lever pulled back far too close to the handlebars,i tried the new bleed procedure found on the Magura Forum that alot of the MT6/8 owners were doing to improve the lever feel which worked but the lever slowly seemed to creep back after a few rides.The main thing was how poor of a fit the small bush that holds the Piston rod in the lever blade was,this was such a bad fit the first 4-5mm of lever movement was just taking up the play/slack in the bush then the brake would start to work.For how much the brakes cost this is a very simple part that shouldn't have such an issue.
It has been my first Magura brake on my own bike and I don't think I'll be using them again for a while.I have decided to use a Hope Stealth Race X2 instead now.
Hope this was of some help.
PostPosted: Tue Jan 22, 2013 6:20 pm
Thanks Bradley , yeah , I tend to like a shorter lever stroke before the brake bites too . So the experience you've had would be a deal breaker for me :(
Just wondering if anyone has actually used the X7 at all to provide feedback ? I realise that the other suggestions are good quality and folks have had experience with these recommended products .
But nobody even has a friend of a friend who heard someone had once used a set of KCNC X7 brakes ?
Thanks guys
PostPosted: Wed Jan 23, 2013 7:57 am
Not sure if the KCNC X-7 had a shorter lever stroke compared to other brakes, but I noticed flex on the MC like it is also pulled in by the lever when squeezed. I haven't even built my bike completely when I sold mine after I compared the X-7 with Formula R-1. I think too much CNC work was done one the lever-MC-Handlebar mount unit like their VB-1 brake levers, but the calipers are really cool and the pads had better distance from the rotors compared to my R1s. I wish you could combine the calipers to other levers out there. Also, the MC reservoir cap bolts are very tiny and made of aluminum. I stripped one when I tried to take pictures to ask somebody to make a custom carbon version, so I replaced them all with Ti which made the whole system 1 gram heavier, but more reliable, but I didn't feel it was solid enough because of the flex, hence the reason for selling it. Hope this helped...
PostPosted: Thu Jan 24, 2013 4:28 pm
Take the MT8 !
You only own a bike when you've violated every single term of guarantee.
There are no new unread posts for this topic. Magura brakes & DI2
Thepants
Wed Aug 23, 2017 10:59 am
Thepants View the latest post
There are no new unread posts for this topic. Attachment(s) Magura MT8 brakeset w/ rotors NEW,Cannondale HM fork
bikemaniack
Mon Sep 18, 2017 11:55 am
bikemaniack View the latest post
There are no new unread posts for this topic. KCNC Silverbone questions
in MTB
flangefrog
Wed May 03, 2017 11:25 am
weeracerweenie View the latest post
There are no new unread posts for this topic. 31.6 x 400 seatpost - KCNC or Aerozine?
in MTB
02GF74
Fri Jan 27, 2017 8:13 pm
bikesmad View the latest post
Users browsing this forum: No registered users and 11 guests
