It is currently Wed Jan 24, 2018 3:19 am
Post new topic  Reply to topic  [ 104 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Thu Jan 03, 2013 10:44 pm
Awesome project! I'll be following closely.
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Fri Jan 04, 2013 7:22 am
Wheel parts arrived yesterday. I'll build up a set of the Kinlins this weekend and post weights, photos, etc. I haven't made any modifications to the frame yet. That could be a weekend project too. I have to find a place to have the frame sandblasted after I've drilled the holes and removed the cable stops. Depending on how it looks when stripped, I'll decide if it is worth polishing or if I am going to have it resprayed.
This will be a pretty slow project. I expect at least another month before I am ready to unveil the completed bike. In the meantime, my son has been having a blast on his mountain bike.
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=108562&hilit=alpinestars
PostPosted: Sat Jan 05, 2013 9:09 am
removed
PostPosted: Sat Jan 05, 2013 7:59 pm
I've spent the past few hours building wheels. 3 of 4 complete. I never weighed the carbon rims before now and was disappointed to find them way overweight. Advertised weight was 380g but mine weighed 402g (20h) and 432g (24h). Very strange. The Kinlins came in at 399g (20h) and 389g (24h). So while the 20h rims only differed by 3g (between alloy and carbon) the 24h rims differed by 43g!
The Kinlins built up into a 1279g wheelset (567g F / 712g R) with Dati hubs and 20/24 CX-ray spokes. Pretty good for the money (US$352.00). That means the carbon clinchers should come out to 1322g which is still pretty light but at a higher price (US$520.00). The front is finished and weighs 569g. I will say though, the carbon rims are very nice in appearance. We'll see how they hold up.
Once I've finished the final wheel, trued and dished them all, I'll post some photos.
PostPosted: Sun Jan 06, 2013 9:41 am
Nice project,
What's size frame is it?
I have here a 13" Independent collecting dust .
Intressted?
weight weenie wannabee
PostPosted: Mon Jan 07, 2013 6:01 am
Frame is 40cm with a 49cm top tube.
PM sent.
PostPosted: Wed Jan 16, 2013 10:22 pm
Miscellaneous bits and pieces are arriving. This weekend's project will be to finalize cable/wire routing and drill necessary holes. Once that is completed, I'll send the frame/fork out for paint.
PostPosted: Fri Jan 18, 2013 3:02 pm
I have removed all the cable stops and am working out where to drill for the internal routing. Unfortunately, the front derailleur mount hasn't arrived yet so that is holding things up a bit. I was hoping to mount the battery under the chainstay, but I think it will be better to mount it under the downtube. My concern is that it will be directly in any spray from the front wheel. Because the frame is so small, there is no space to mount it inside the front triangle without losing a water bottle mount.
PostPosted: Wed Feb 06, 2013 9:18 am
Just a quick update...
All parts are in hand. This weekend I'll finally be drilling the holes for the internal wiring. Then taking the frame to be sand-blasted and resprayed. I've been toying with the idea of a really slick custom paint job as my son should be on this bike for a couple of seasons and his younger brother will be able to ride it later on. Otherwise, I'll go with a basic black to keep it simple.
Hopefully I'll have it built and ready for photos by the end of the month.
PostPosted: Fri Feb 08, 2013 3:52 pm
All the holes are drilled for the internal wiring, except for the battery. I think I am going to run the battery cable up through the seat tube, out the top of the post and to the battery mounted on the back of the seatpost using these Specialized water bottle mounts. This saves me drilling three more holes in the frame. Tomorrow I'll post some photos of the drilled frame and mocked up wiring. Then I'm going to run it out for sandblasting and paint. Due to budget constraints, it looks like I'm just going with a straight black spray at the local auto repair shop.
PostPosted: Tue Feb 12, 2013 7:51 pm
Getting the bike professionally sand-blasted and repainted is a non-starter. Cheapest I can find is nearly 300 euros for a single color. Tomorrow I break out the paint stripper and a can each of primer and metallic black spray paint. Gotta stay in budget...
PostPosted: Wed Feb 13, 2013 12:57 pm
Hmmm... that didn't work. I tried an industrial paint stripper and it didn't do anything after 4 hours. I may wind up hand-sanding this frame. Not my idea of a fun day....
PostPosted: Wed Feb 13, 2013 2:54 pm
What about blasting it (should only cost around $50) and then painting it yourself.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Wed Feb 13, 2013 4:46 pm
Until a few minutes ago I couldn't find anyone to sandblast it locally. But I just got a note from a guy who can sandblast and powdercoat (single color) for 80 euros. He does restorations of vintage motorcycles, scooters, and cars. I'll be bringing it by on Friday.
:beerchug:
PostPosted: Wed Feb 13, 2013 5:11 pm
Great news and that is a great price if I do say so myself.
BIG DADDY B FLOW
There are no new unread posts for this topic. Kinesis Racelight Gran Fondo Ti V3 Disc with 50mm carbon clinchers
fivethirtyonepm
Wed Aug 16, 2017 4:49 pm
sawyer View the latest post
There are no new unread posts for this topic. Lightest dual suspension Mountain Bike for Kids
carbonXScycles
Fri Oct 27, 2017 12:19 pm
JScycle View the latest post
There are no new unread posts for this topic. My Kinesis Aithein
powenb
Thu Jun 01, 2017 5:33 am
powenb View the latest post
There are no new unread posts for this topic. Kinesis 4S disc - opinions?
Multebear
11
1167
Sun Aug 20, 2017 8:15 pm
Multebear View the latest post
There are no new unread posts for this topic. New Kinesis Aithein Evo frame
LM7805
14
2331
Thu Sep 21, 2017 1:50 pm
MayhemSWE View the latest post
Users browsing this forum: genesis692 and 11 guests
