It is currently Mon Dec 18, 2017 12:40 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: Steel WW projects
PostPosted: Wed Dec 12, 2012 10:34 pm
Ok, I know a lot of you guys out there have some really nice high end carbon set ups that are down in the 9 lbs range. Nothing wrong with that at all. Hell, if I had the money, I would have one myself. Since that isn't the case I have to work with what I got, an 09 Bianchi Pinella. Yep STEEL. Nice steel mind you but still steel.
When I got my bike (used) it weighed in at 19.5 lbs. Today I weighed it at my local shop and was surprised to see it at 16 lbs 11 oz (7569.30 g). My goal was to hit 16 which I have and I actually still have a new bar, seat post, and skewers in the mail. I don't think that will get me down to 15 mind you but it will shed maybe another 100g or so if my calculations are correct. I'll post up some specs and pics later but in the mean time, I am curious what some of you guys have gotten your steel bikes down to. I know I have seen a few Master Lites on here w/ SR set ups. Sort of makes me wish I had never gotten rid of mine some 5 years ago. So post them up. I'd love to see what you guys have done and maybe get some more ideas of where I can go with mine.
Cannondale Synapse (alu)...it works
 Post subject: Re: Steel WW projects
PostPosted: Wed Dec 12, 2012 10:46 pm
On a no-budget cervelo prodigy, just using take offs mine is still like 21lbs
PostPosted: Thu Dec 13, 2012 12:21 am
I have a custom Reynolds 653 frame that I am rebuilding in the new year.
I have had this frame over 20 years, originally had Shimano 105 with downtube shifters, a few years ago was upgraded to Dura Ace 7700
The plan is to have it professionally repainted - deciding between 2 well know bike paint specialists as I want if to be something really special
Upgrade to DA 7800 including DA pedals (Speedplays on my other bikes) - filtering down as my Parlee got new SRAM Red, old red onto my training bike and now 7800 onto my steel bike.
Part of the upgrade will be Chris King BB and headset and King stainless bottle cages.
To standardise saddles I am going with a San Marco Regal as I have the carbon Regale on my other bikes.
And to top off the build a new set of wheels - Ambrosio Nemesis tubulars on Chris King hubs.
The crazy thing is the rebuild will cost more than an entry level carbon race bike or CAAD 10 in parts and paint, but the finished product should be around for another 20 years of light use.
I will start a thread for this when I get started, I just need to finish the rebuild of my training bike and move house before I kick off on this project.
Ozrider - Western Australia
PostPosted: Thu Dec 13, 2012 12:44 am
6040g in the picture. If I went with his more simplistic frame it would have been lighter and sub 6000g easily. Rob is a master with steel.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Thu Dec 13, 2012 2:36 am
You might want to take a look at the following WW thread, about my steel project bike made by Chas Roberts in Croydon, England:
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=101178
The show spec is 4690g, but I would swap a few things out (like the track tubbies) for heavier-duty parts when I ride it, taking it to just under 5kg in total (On the road).
If you did without the couplings and you were a very lightweight rider, you might knock 200g off the frameset weight, and I reckon you could lose another 200g or so off the component spec. The extra weight loss would cost an inordinate amount of money, and I've run out of budget completely for the time being, so it won't be me setting any newer records!
Chas is a master builder - been in the business with his father for 50 years, on his own for almost 40. Builds very simple, very beautiful, comfortable and functional custom steel bicycles (of every stripe); took some doing to get him to build this one for me (but then I already had several of his frames by then!).
The beauty of steel is that, once you find the right frame spec, the frameset is for life - it can be fixed, resprayed, rebuilt...
PostPosted: Thu Dec 13, 2012 4:28 am
Forgot to mention the frame weight on its own. The frame with the ISP was 1302g painted so for a steel bike it was pretty light and could have been lighter and closer to 1240g if we did not do a few things but still ISP. Could realy have dropped it under 1200g if I went without the ISP.
BIG DADDY B FLOW
PostPosted: Thu Dec 13, 2012 4:42 am
Here's mine.
Note that I failed to bring it to below 6800g (swap my 912 gr RZR for the RZR Team and gained 300gr instead :lol: )
if I'm not mistaken the weight is north of 6900gr with the LW Std Gen3.
Weightweenie components in no particular order.
AX Orions with stock LW/Swisstop pads
Berk Combo, in 27.2mm and 75 deg seat angle, 25mm offset
Extralite OC Stem in 110mm
Rest of the parts are basically standard SR, with Look Keo Blade Ti and Easton SLX bars.
Fellow ww, cmh has the lightest Master Xlight built in this forum so far, with his Saronni.
PostPosted: Thu Dec 13, 2012 4:45 am
That bike is just dead sexy. wow.
BIG DADDY B FLOW
PostPosted: Thu Dec 13, 2012 6:05 am
Unbelievable bike there.
PostPosted: Thu Dec 13, 2012 6:18 am
I concur
Quoting George Constanza from Seinfeld..
"I think it moved" :lol:
PostPosted: Thu Dec 13, 2012 9:17 am
Here is mine... http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=79009&hilit=custom+steel
PostPosted: Thu Dec 13, 2012 9:50 am
Still my favourite modern steel bike :thumbup:
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu Dec 13, 2012 12:35 pm
My slightly too big serotta 6.9kgs, clinchers and a whole bunch of stuff I hadn't learned yet..
Image[/QUOTE]
Skunkworks Bikes
PostPosted: Thu Dec 13, 2012 1:12 pm
xnavalav8r, wow, Sweet Wings! You don't see a lot of those any more. I suspect yours are holding up pretty well to have been around this long.
Well here are some pictures of what I'm working with. One of them is pretty much how it looked when I got it and the others are what it looks like right now. I have swapped out quite a few parts on this thing since picking it up in late July. A lot of it was to make it fit me better and of course shed some weight in the process. As mentioned earlier, started at about 19.5 and am now at 16 lbs 11 oz w/ more to do.
Build list so far:
09 Pinella w/ full carbon fork
Record 10spd R der.
Record 10 spd f der
Record skeleton brake calipers
Centaur levers (prior owner liked the V3 shape and the Centaur's were the only newer design levers available in 10 spd-at least they are the carbon version)
Chorus CT crank (50/34)
FSA headset
Ebay special seat post clamp (8g and only cost me $11)
Zipp Service Corse SL stem 100mm
ITM 101 bar (being replaced by ITM Pathom as noted)
Record carbon top cap
Tune Gum Gum compression set up
Zipp 1/4" spacer
San Marco Aspide (ti rails) or SLR XP (vanox rails) eventually a Berk Combo (by early spring I hope)
KCNC seat post (on loan-Hylix in the mail)
Jag wire der cables
iLink brake cables
Sepcialized bar tape (Lizard Skin dimpled when new bars show up)
Specialized carbon bottle cages w/ nylon skrews
Speedplay X1 ti pedals
C-10 chain
Chorus cassette 11-25
wheels (I have two sets, similar yet different)
Heavier set is: Velocity Deep V rims, brass nips, Sapim spokes, White Industries hubs (black spokes w/ black hubs), Hutchinson tires
Lighter set is: Velocity Aero Head (oc in rear) w/ Silver Sapim spokes, brass nips, silver WI hubs, Velo Flex Corsa tires
I have not really started tuning the bike as of yet. Since owning it (bought back in late July) I have pretty much been spending my time picking up parts that make it fit me better and of course buying replacement parts that were lighter than what was coming off. It has a long way to go really but building it up and tuning everything is the fun part, next to riding it of course.
File comment: Pretty much the way I got it
PostPosted: Thu Dec 13, 2012 1:23 pm
Sorry, was having image issues. Here's how it sits right now.
7569.30g as it sits now. Man that thing is a frickn pig compared to some of yalls set ups! Wow, I got a long way to go! :idea: Someone send money!!!
There are no new unread posts for this topic. Show us your intern projects
rpowell
Thu Sep 21, 2017 4:14 pm
C36 View the latest post
There are no new unread posts for this topic. Men of Steel
Tinea Pedis
29
3581
Fri Apr 14, 2017 10:43 pm
Tinea Pedis View the latest post
There are no new unread posts for this topic. 1980~ Steel classic.
Littlemad
Tue Nov 21, 2017 11:50 am
Littlemad View the latest post
There are no new unread posts for this topic. Colnago steel - From 10s to 11s .. what to watch out for ?
Kupepe
Wed Mar 29, 2017 8:24 pm
shimmeD View the latest post
There are no new unread posts for this topic. Steel OR Carbon / Calipers or Disc
stevenak
16
1277
Mon May 22, 2017 11:46 am
Fixie82 View the latest post
Users browsing this forum: bm0p700f and 19 guests
